NMA notify my android
Begonnen von Lectere, 29 Mai 2013, 08:40:30
Lectere
Hey Guys,
I've came up with and idea, might be nice to have a support for NMA, push notification for android. Since Notifry is stopping its services soon, NMA is the only push notification service.
I've googled their page and for an other system there is curretly a perl script:
#!/usr/bin/perl -w
# NMAScript, to communicate with the Notify My Android server.
# Copyright (c) 2010, Zachary West
# All rights reserved.
# Rafactoring to Notify My Android: Adriano Maia
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
#     * Redistributions of source code must retain the above copyright
#       notice, this list of conditions and the following disclaimer.
#     * Redistributions in binary form must reproduce the above copyright
#       notice, this list of conditions and the following disclaimer in the
#       documentation and/or other materials provided with the distribution.
#     * Neither the name of Zachary West nor the
#       names of its contributors may be used to endorse or promote products
#       derived from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY Zachary West ''AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL Zachary West BE LIABLE FOR ANY
# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# NOTIFY MY ANDROID (NMA) IS NOT RELATED TO PROWL OR ZACHARY WEST. TWO SEPARATE PROJECTS WITH A SIMILAR API.
# This requires running Notify My Android on your device.
# See the NMA website <http://www.notifymyandroid.com>
use strict;
use LWP::UserAgent;
use Getopt::Long;
use Pod::Usage;
# Grab our options.
my %options = ();
GetOptions(\%options, 'apikey=s', 'apikeyfile=s',
 'developerkey=s',
 'application=s', 'event=s', 'notification=s',
 'priority:i', 'help|?') or pod2usage(2);
$options{'application'} ||= "NMAScript";
$options{'priority'} ||= 0;
pod2usage(-verbose => 2) if (exists($options{'help'}));
pod2usage(-message => "$0: Event name is required") if (!exists($options{'event'}));
pod2usage(-message => "$0: Notification text is required") if (!exists($options{'notification'}));
pod2usage(-priority => "$0: Priority must be in the range [-2, 2]") if ($options{'priority'} < -2 || $options{'priority'} > 2);
# Get the API key from STDIN if one isn't provided via a file or from the command line.
if (!exists($options{'apikey'}) && !exists($options{'apikeyfile'})) {
print "API key: ";
$options{'apikey'} = <STDIN>;
chomp $options{'apikey'};
} elsif (exists($options{'apikeyfile'})) {
open(APIKEYFILE, $options{'apikeyfile'}) or die($!);
$options{'apikey'} = <APIKEYFILE>;
close(APIKEYFILE);
# URL encode our arguments
$options{'application'} =~ s/([^A-Za-z0-9])/sprintf("%%%02X", ord($1))/seg;
$options{'event'} =~ s/([^A-Za-z0-9])/sprintf("%%%02X", ord($1))/seg;
$options{'notification'} =~ s/([^A-Za-z0-9])/sprintf("%%%02X", ord($1))/seg;
# Generate our HTTP request.
my ($userAgent, $request, $response, $requestURL);
$userAgent = LWP::UserAgent->new;
$userAgent->agent("NMAScript/1.0");
$userAgent->env_proxy();
my $developerKeyString = "";
if(exists($options{'developerkey'})) {
$developerKeyString = sprintf("&developerkey=%s", $options{'developerkey'});
$requestURL = sprintf("https://www.notifymyandroid.com/publicapi/notify?apikey=%s&application=%s&event=%s&description=%s&priority=%d%s",
$options{'apikey'},
$options{'application'},
$options{'event'},
$options{'notification'},
$options{'priority'},
$developerKeyString);
$request = HTTP::Request->new(GET => $requestURL);
$response = $userAgent->request($request);
if ($response->is_success) {
print "Notification successfully posted.\n";
} else {
print STDERR "Notification not posted: " . $response->content . "\n";
__END__
=head1 NAME
nma - Send NotifyMyAndroid notifications
=head1 SYNOPSIS
nma.pl [options] event_information
 Options:
   -help              Display all help information.
   -apikey=...        Your NotifyMyAndroid API key.
   -apikeyfile=...    A file containing your NMA API key.
   -developerkey=...   Your developer key (optional)
 Event information:
   -application=...   The name of the application.
   -event=...         The name of the event.
   -notification=...  The text of the notification.
   -priority=...      The priority of the notification.
                      An integer in the range [-2, 2].
=head1 OPTIONS
=over 8
=item B<-apikey>
Your NMA API key. It is not recommend you use this, use the apikeyfile option.
=item B<-developerkey>
Your NMA developer key. This is an optional argument, and should be used if you were provided one for whitelisting reasons.
=item B<-apikeyfile>
A file containing one line, which has your NMA API key on it.
=item B<-application>
The name of the Application part of the notification. If none is provided, NMAScript is used.
=item B<-event>
The name of the Event part of the notification. This is generally the action which occurs, such as "disk partitioning completed."
=item B<-notification>
The text of the notification, which has more details for a particular event. This is generally the description of the action which occurs, such as "The disk /dev/abc was successfully partitioned."
=item B<-priority>
The priority level of the notification. An integer value ranging [-2, 2] with meanings Very Low, Moderate, Normal, High, Emergency.
=back
=head1 DESCRIPTION
B<This program> sends a notification to the NMA server, which is then forwarded to your device running the NMA application.
=head1 HELP
For more assistance, visit the NMA website at <http://www.notifymyandroid.com>.
=cut
SMSPassword redundant two-factor authentication for Netscaler, Vmware View, Cisco, Juniper, etc via SMS
http://www.smspassword.com
OiledAmoeba
currently there is no direct support for NMA through fhem.
But user fhem86 programmed an app for users without NMA (see Link).
If you owned NMA Premium you can use code snippets from me (see Link) or from user kossmann (see Link).
But beware: With NMA Free you can only use 5 notifications per day. NMA Pro charges you with an one time fee. So if you don't owned NMA Pro, it's maybe good for you to use the app I've linked first.
Florian
Jail auf XigmaNAS (freeBSD); CCU2 mit CULv3, nanoCUL868 und JeeLink-Clone; div. FS20-Komponenten; andFHEM; div. hm- und hmip-Komponenten; div. IT+
