Tesla Wall Connector Gen 3 API
Begonnen von Black7king, 23 Mai 2021, 10:00:03
Black7king
Hallo zusammen
kann jemand aus den Daten ein Modul für FHEM bauen?
Wenn noch irgendwelche Daten oder Hilfe gebraucht wird stehe ich gerne zur Hilfe.
Mit freundlichen Grüßen
http://,,ip-adresse im heimnetzwerk der Wallbox"/api/1/vitals
{"contactor_closed":false
"vehicle_connected":false
"session_s":0
"grid_v":230.1
"grid_hz":49.928
"vehicle_current_a":0.1
"currentA_a":0.0
"currentB_a":0.1
"currentC_a":0.0
"currentN_a":0.0
"voltageA_v":0.0
"voltageB_v":0.0
"voltageC_v":0.0
"relay_coil_v":11.8
"pcba_temp_c":19.2
"handle_temp_c":15.3
"mcu_temp_c":25.1
"uptime_s":831580
"input_thermopile_uv":-233
"prox_v":0.0
"pilot_high_v":11.9
"pilot_low_v":11.9
"session_energy_wh":22864.699
"config_status":5
"evse_state":1
"current_alerts":[]}
http://,,ip-adresse im heimnetzwerk der Wallbox"/api/1/wifi_status
{"wifi_ssid":"RlJJVFoh4565464IEZvbiBXTE456IDczOTA="
"wifi_signal_strength":100
"wifi_rssi":-35
"wifi_snr":62
"wifi_connected":true
"wifi_infra_ip":"192.168.178.149"
"internet":true
"wifi_mac":"98:ED:5C:8C:77:21"}
http://,,ip-adresse im heimnetzwerk der Wallbox"/api/1/version
{"firmware_version":"21.8.5+g51eba2369815d7"
"part_number":"1529455-02-D"
"serial_number":"PGT21106012345"}
http://,,ip-adresse im heimnetzwerk der Wallbox"/api/1/lifetime
{"contactor_cycles":32
"contactor_cycles_loaded":0
"alert_count":5
"thermal_foldbacks":0
"avg_startup_temp":5199147.0
"charge_starts":32
"energy_wh":89012
"connector_cycles":5
"uptime_s":1297280
"charging_time_s":33152}
{"contactor_closed":false,"vehicle_connected":false,"session_s":0,"grid_v":230.1,"grid_hz":49.928,"vehicle_current_a":0.1,"currentA_a":0.0,"currentB_a":0.1,"currentC_a":0.0,"currentN_a":0.0,"voltageA_v":0.0,"voltageB_v":0.0,"voltageC_v":0.0,"relay_coil_v":11.8,"pcba_temp_c":19.2,"handle_temp_c":15.3,"mcu_temp_c":25.1,"uptime_s":831580,"input_thermopile_uv":-233,"prox_v":0.0,"pilot_high_v":11.9,"pilot_low_v":11.9,"session_energy_wh":22864.699,"config_status":5,"evse_state":1,"current_alerts":[]}
{"wifi_ssid":"RlIIVFohQm94IEZvbiXBTEFOIDczOTA=","wifi_signal_strength":100,"wifi_rssi":-35,"wifi_snr":62,"wifi_connected":true,"wifi_infra_ip":"192.168.178.149","internet":true,"wifi_mac":"98:ED:5C:8C:12:34"}
{"firmware_version":"21.8.5+g51eba2369815d7","part_number":"1529455-02-D","serial_number":"PGT21106012345"}
{"contactor_cycles":32,"contactor_cycles_loaded":0,"alert_count":5,"thermal_foldbacks":0,"avg_startup_temp":5199147.0,"charge_starts":32,"energy_wh":89012,"connector_cycles":5,"uptime_s":1297280,"charging_time_s":33152}
CoolTux
Ok hab gefunden was Du meinst mit genauer anschauen  ;D
Das TuxNet Wiki:
https://www.cooltux.net
Black7king
und kann mann draus ein Modul bauen? ist das viel Arbeit? müsste ja des gleiche wie bei den Powerwalls sein
CoolTux
Ein Modul kann man draus bauen. Viel Arbeit ist relativ. Es ist immer mit Zeitaufwand verbunden.
Das TuxNet Wiki:
Oliver Vallant
Hallo Black7king,
die Gen3 kann ja einfach mittels Rest API ausgelesen werden, dazu braucht man gar kein eigenes Modul.
define wallbox HTTPMOD http://<IP-Adresse_der_Station>/api/1/vitals 30
attr wallbox extractAllJSON 1
Das Modul HTTPMOD erzeugt dann für jeden JSON-Tag ein Reading und auf diese kannst du dann mit notifys reagieren et cetera.
Derzeit liefert die Gen3 folgende data-sets:
    http://>IP address</api/1/vitals
    http://>IP address</api/1/wifi_status
    http://>IP address</api/1/lifetime
    http://>IP address</api/1/version
    http://>IP address</tedapi/v1
LG Oliver
