HM-TC-IT-WM-W-EU und measured-temp
Begonnen von maxritti, 07 November 2022, 15:44:09
maxritti
es macht mal wieder ein HM-TC-IT-WM-W-EU Problemchen.
Und zeigt der auf dem Display eine andere Temperatur an, als im Reading measured-temp.
Ich habe da zwar mal was mit tempOffset rumgespielt, kann das ggf. das Problem sein?
Anbei mal list vom Device und vom Climate Channel.
   .AttrList  .devInfo .mId .stc IODev IOgrp actCycle actStatus aesCommReq:1,0 aesKey:5,4,3,2,1,0 autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto commStInCh:on,off do_not_notify:1,0 dummy:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none firmware hmKey hmKey2 hmKey3 hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger ignore:1,0 model modelForce:ACTIONDETECTOR,ACTIONDETECTOR,ASH550,ASH550I,CCU-FHEM,CMM,DORMA_ATENT,DORMA_BRC-H,DORMA_RC-H,HM-CC-RT-DN,HM-CC-RT-DN-BOM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-DIS-EP-WM55,HM-DIS-TD-T,HM-DIS-WM55,HM-DW-WM,HM-ES-PMSW1-DR,HM-ES-PMSW1-PL,HM-ES-PMSW1-PL-DN-R1,HM-ES-PMSW1-PL-DN-R2,HM-ES-PMSW1-PL-DN-R3,HM-ES-PMSW1-PL-DN-R4,HM-ES-PMSW1-PL-DN-R5,HM-ES-PMSW1-SM,HM-ES-TX-WM,HM-HM-LC-DW-WM,HM-LC-AO-SM,HM-LC-BL1-FM,HM-LC-BL1-FM-2,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-BL1-SM-2,HM-LC-BL1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-CV-2,HM-LC-DIM1L-CV-644,HM-LC-DIM1L-PL,HM-LC-DIM1L-PL-2,HM-LC-DIM1L-PL-3,HM-LC-DIM1L-PL-644,HM-LC-DIM1PWM-CV,HM-LC-DIM1PWM-CV-2,HM-LC-DIM1T-CV,HM-LC-DIM1T-CV-2,HM-LC-DIM1T-CV-644,HM-LC-DIM1T-DR,HM-LC-DIM1T-FM,HM-LC-DIM1T-FM-2,HM-LC-DIM1T-FM-644,HM-LC-DIM1T-FM-LF,HM-LC-DIM1T-PL,HM-LC-DIM1T-PL-2,HM-LC-DIM1T-PL-3,HM-LC-DIM1T-PL-644,HM-LC-DIM1TPBU-FM,HM-LC-DIM1TPBU-FM-2,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2L-SM-2,HM-LC-DIM2L-SM-644,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM-2,HM-LC-JA1PBU-FM,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-DR,HM-LC-SW1-FM,HM-LC-SW1-FM-2,HM-LC-SW1-PB-FM,HM-LC-SW1-PCB,HM-LC-SW1-PL,HM-LC-SW1-PL-3,HM-LC-SW1-PL-CT-R1,HM-LC-SW1-PL-CT-R2,HM-LC-SW1-PL-CT-R3,HM-LC-SW1-PL-CT-R4,HM-LC-SW1-PL-CT-R5,HM-LC-SW1-PL-DN-R1,HM-LC-SW1-PL-DN-R2,HM-LC-SW1-PL-DN-R3,HM-LC-SW1-PL-DN-R4,HM-LC-SW1-PL-DN-R5,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-2,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW1PBU-FM,HM-LC-SW2-DR,HM-LC-SW2-DR-2,HM-LC-SW2-FM,HM-LC-SW2-FM-2,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW2PBU-FM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-DR-2,HM-LC-SW4-PCB,HM-LC-SW4-PCB-2,HM-LC-SW4-SM,HM-LC-SW4-SM-2,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-SW4-WM-2,HM-MOD-EM-8,HM-MOD-EM-8BIT,HM-MOD-RE-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-2-PBU-FM-2,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-DIS-H-X-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-KEY4-2,HM-RC-KEY4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-SEC4-2,HM-RC-SEC4-3,HM-SCI-3-FM,HM-SEC-CEN,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCO,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-SIR-WM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-DB-PCB,HM-SEN-EP,HM-SEN-LI-O,HM-SEN-MDIR-O,HM-SEN-MDIR-O-2,HM-SEN-MDIR-O-3,HM-SEN-MDIR-SM,HM-SEN-MDIR-WM55,HM-SEN-RD-O,HM-SEN-WA-OD,HM-SWI-3-FM,HM-SYS-SRP-PL,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550TECH,IS-WDS-TH-OD-S-R3,KFM-DISPLAY,KFM-SENSOR,KS550,KS550LC,KS550TECH,KS888,OLIGO-SMART-IQ-HM,PS-SWITCH,PS-TH-SENS,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FFK,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FSS-UP3,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,S550IA,SCHUECO_263-130,SCHUECO_263-131,SCHUECO_263-132,SCHUECO_263-133,SCHUECO_263-134,SCHUECO_263-135,SCHUECO_263-144,SCHUECO_263-145,SCHUECO_263-146,SCHUECO_263-147,SCHUECO_263-155,SCHUECO_263-157,SCHUECO_263-158,SCHUECO_263-160,SCHUECO_263-162,SCHUECO_263-167,SCHUECO_263-XXX,SENSOTIMER-ST-6,VIRTUAL,WDF-SOLAR,WS888 msgRepeat oldreadings param readOnly:0,1 readingOnDead:multiple,noChange,state,periodValues,periodString,channels rssiLog:1,0 serialNr showtime:1,0 stateFormat:textField-long subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,display,keyMatic,motionAndBtn,motionDetector,no,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic timestamp-on-change-reading
   .lastTimemeasured-temp 1667830516.53428
   .triggerUsed 1
   DEF        303ABC
   FUUID      63307ceb-f33f-7b3d-db6f-76840c875e8f7615
   IODev      myHMLGW_Schlafzimmer
   LASTInputDev myHMLGW_Schlafzimmer
   MSGCNT     50553
   NAME       HM_303ABC
   NR         269
   NTFY_ORDER 48-HM_303ABC
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 HM_303ABC_Weather
   channel_02 HM_303ABC_Climate
   channel_03 HM_303ABC_WindowRec
   channel_06 HM_303ABC_remote
   channel_07 HM_303ABC_SwitchTr
   disableNotifyFn 1
   eventCount 1506
   lastMsg    No:47 - t:70 s:303ABC d:000000 00BD3E
   myHMLGW_MSGCNT 25268
   myHMLGW_RAWMSG 0500003E478470303ABC00000000BD3E
   myHMLGW_RSSI -62
   myHMLGW_Schlafzimmer_MSGCNT 25285
   myHMLGW_Schlafzimmer_RAWMSG 05000042478470303ABC00000000BD3E
   myHMLGW_Schlafzimmer_RSSI -66
   myHMLGW_Schlafzimmer_TIME 2022-11-07 15:41:03
   myHMLGW_TIME 2022-11-07 15:41:03
   protCmdDel 3
   protLastRcv 2022-11-07 15:41:03
   protNack   3 last_at:2022-10-22 17:39:51
   protRcv    25314 last_at:2022-11-07 15:41:03
   protSnd    292 last_at:2022-11-07 12:52:26
   protSndB   30 last_at:2022-11-07 12:52:25
   protState  CMDs_done
   rssi_at_myHMLGW cnt:25268 min:-92 max:-33 avg:-66.64 lst:-62
   rssi_at_myHMLGW_Schlafzimmer cnt:25285 min:-93 max:-55 avg:-64.13 lst:-66
   rssi_myHMLGW_Schlafzimmer cnt:30 min:-62 max:-52 avg:-56.7 lst:-58
   .attraggr:
   .attrminint:
     measured-temp:60
   CL:
     Authenticated 0
     BUF
     FD         22
     FW_ID      252523
     LASTACCESS 1667832147.37085
     NAME       WEB_192.168.178.40_53284
     NR         252524
     PEER       192.168.178.40
     PORT       53284
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     encoding   UTF-8
     .attraggr:
     .attrminint:
       2022-11-07 15:42:22   state           Connected
     2022-10-22 09:24:59   .D-devInfo      03FFFF
     2022-10-22 09:24:59   .D-stc          58
     2022-09-27 17:33:28   .R-btnLock      off
     2022-09-27 17:33:28   .R-burstRx      on
     2022-09-27 17:33:28   .R-cyclicInfoMsg on
     2022-09-27 17:33:28   .R-cyclicInfoMsgDis 0
     2022-09-27 17:33:28   .R-globalBtnLock off
     2022-09-27 17:33:28   .R-localResDis  off
     2022-09-27 17:33:28   .R-lowBatLimitRT 2.2 V
     2022-09-27 17:33:28   .R-modusBtnLock off
     2022-10-22 19:19:24   .R-pairCentral  0x9A234E
     2022-10-22 10:48:32   .associatedWith HM_303ABC,HM_303ABC_Climate,HM_303ABC_SwitchTr,HM_303ABC_Weather,HM_303ABC_WindowRec,HM_303ABC_remote,HM_303ABC
     2022-11-07 15:41:03   .protLastRcv    20221107154103
     2022-11-07 12:52:26   CommandAccepted yes
     2022-10-22 09:24:59   D-firmware      1.3
     2022-10-22 09:24:59   D-serialNr      LEQ1215838
     2022-11-07 12:52:25   IODev           myHMLGW_Schlafzimmer
     2022-11-07 12:52:01   PairedTo        0x9A234E
     2022-11-07 12:52:01   RegL_00.         00:00 01:01 02:01 09:01 0A:9A 0B:23 0C:4E 0F:00 11:00 12:16 16:00 18:00 19:00 1A:00
     2022-11-07 15:15:16   battery         ok
     2022-11-07 15:15:16   batteryLevel    2.9
     2022-11-07 12:53:15   cfgState        ok
     2022-11-07 12:52:26   commState       CMDs_done
     2022-11-07 15:15:16   desired-temp    18.0
     2022-11-07 15:15:16   measured-temp   18.9
     2022-10-22 09:23:47   powerOn         2022-10-22 09:23:47
     2022-10-22 09:23:47   recentStateType info
     2022-11-07 12:52:26   state           CMDs_done
     2022-10-22 09:25:15   time-request    -
     RegL_07.:
       VAL
   helper:
     HM_CMDNR   71
     PONtest    1
     cSnd       119A234E303ABC860424,119A234E303ABC860224
     cfgChkResult No regs found for:HM_303ABC-ret--ret-
     cfgStateUpdt 0
     lastMsgTm  1667832063.54521
     mId        00AD
     peerFriend -
     peerOpt    -:thermostat
     regLst     0
     rxType     6
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    :no:1666428512.84309
       TmplTs     1666428512.84309
       cmdKey     0:1:0::HM_303ABC:00AD:00:
       cmdLst:
         assignHmKey noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         inhibit    [(on|{off})]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sysTime    noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         condition  slider,0,1,255
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +303ABC,00,00,00
       nextSend   1667832063.63968
       rxt        0
       vccu       myVCCU
       p:
         303ABC
         00
         00
         00
       prefIO:
     mRssi:
       mNo        47
       io:
         myHMLGW:
           -62
           -62
         myHMLGW_Schlafzimmer:
           -62
           -62
     peerIDsH:
     prt:
       awake      0
       bErr       0
       sProc      0
       tryMsg:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       dev        1
       prs        1
     rssi:
       at_myHMLGW:
         avg        -66.6427892987179
         cnt        25268
         lst        -62
         max        -33
         min        -92
       at_myHMLGW_Schlafzimmer:
         avg        -64.1393316195379
         cnt        25285
         lst        -66
         max        -55
         min        -93
         avg        -56.7
         cnt        30
         lst        -58
         max        -52
         min        -62
     shRegW:
       07         02
     shadowReg:
     tmpl:
   nb:
     cnt        1
   .mId       00AD
   IOgrp      myVCCU:myHMLGW_Schlafzimmer
   alias      Wohnzimmer
   autoReadReg 4_reqStatus
   event-min-interval measured-temp:60
   expert     rawReg
   firmware   1.3
   model      HM-TC-IT-WM-W-EU
   msgRepeat  1
   room       Temperatur
   serialNr   LEQ1215838
   subType    thermostat
   webCmd     getConfig:clear msgEvents
   .AttrList  aesCommReq:1,0 do_not_notify:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none levelMap levelRange model oldreadings param peerIDs readOnly:0,1 showtime:1,0 stateFormat:textField-long tempListTmpl timestamp-on-change-reading
   .lastTimemeasured-temp 1667832043.54624
   .triggerUsed 1
   DEF        303ABC02
   FUUID      63307ceb-f33f-7b3d-99a5-ace9d1096ecdebf2
   NAME       HM_303ABC_Climate
   NR         271
   NTFY_ORDER 48-HM_303ABC_Climate
   STATE      T: 18.9 desired: 18.0
   TYPE       CUL_HM
   chanNo     02
   device     HM_303ABC
   disableNotifyFn 1
   eventCount 10624
   .attraggr:
   .attrminint:
     measured-temp:300
   CL:
     Authenticated 0
     BUF
     FD         23
     FW_ID      252502
     LASTACCESS 1667832057.18528
     NAME       WEB_192.168.178.40_53242
     NR         252503
     PEER       192.168.178.40
     PORT       53242
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     encoding   UTF-8
     .attraggr:
     .attrminint:
       2022-11-07 15:40:50   state           Connected
     2022-09-27 17:33:33   .R-boostPeriod  5 min
     2022-09-27 17:33:33   .R-dayTemp      21 C
     2022-09-27 17:33:33   .R-daylightSaveTime on
     2022-09-27 17:33:33   .R-heatCool     heating
     2022-09-27 17:33:33   .R-modePrioManu all
     2022-09-27 17:33:33   .R-modePrioParty all
     2022-09-27 17:33:33   .R-nightTemp    17 C
     2022-09-27 17:33:33   .R-noMinMax4Manu off
     2022-11-07 12:51:28   .R-sendWeatherData on
     2022-11-07 12:51:28   .R-showHumidity temp
     2022-09-27 17:33:33   .R-showInfo     time
     2022-11-07 12:51:28   .R-showSetTemp  actTemp
     2022-09-27 17:33:33   .R-showWeekday  off
     2022-09-27 17:33:29   .R-sign         off
     2022-09-27 17:33:33   .R-tempMax      30.5 C
     2022-09-27 17:33:33   .R-tempMin      4.5 C
     2022-11-07 12:51:28   .R-tempOffset   0.0K
     2022-09-27 17:33:33   .R-weekPrgSel   prog1
     2022-09-27 17:33:33   .R-winOpnBoost  off
     2022-11-07 12:52:02   .associatedWith HM_303ABC,HM_303ABC_Climate,HM_303ABC_SwitchTr,HM_303ABC_Weather,HM_303ABC_WindowRec,HM_303ABC_remote,HM_303ABC
     2022-11-07 12:52:02   .peerListRDate  2022-11-07 12:52:02
     2022-11-07 12:52:06   R_P1_0_tempListSat  06:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_1_tempListSun  06:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_2_tempListMon  06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_3_tempListTue  06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_4_tempListWed  06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_5_tempListThu  06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_6_tempListFri  06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-11-07 12:52:06   R_P1_tempList_State verified
     2022-11-07 12:52:10   R_P2_0_tempListSat  24:00 17.0
     2022-11-07 12:52:10   R_P2_1_tempListSun  24:00 17.0
     2022-11-07 12:52:10   R_P2_2_tempListMon  24:00 17.0
     2022-11-07 12:52:10   R_P2_3_tempListTue  24:00 17.0
     2022-11-07 12:52:10   R_P2_4_tempListWed  24:00 17.0
     2022-11-07 12:52:10   R_P2_5_tempListThu  24:00 17.0
     2022-11-07 12:52:10   R_P2_6_tempListFri  24:00 17.0
     2022-11-07 12:52:10   R_P2_tempList_State verified
     2022-11-07 12:52:13   R_P3_0_tempListSat  24:00 17.0
     2022-11-07 12:52:13   R_P3_1_tempListSun  24:00 17.0
     2022-11-07 12:52:13   R_P3_2_tempListMon  24:00 17.0
     2022-11-07 12:52:13   R_P3_3_tempListTue  24:00 17.0
     2022-11-07 12:52:13   R_P3_4_tempListWed  24:00 17.0
     2022-11-07 12:52:13   R_P3_5_tempListThu  24:00 17.0
     2022-11-07 12:52:13   R_P3_6_tempListFri  24:00 17.0
     2022-11-07 12:52:13   R_P3_tempList_State verified
     2022-11-07 12:52:02   RegL_01.         00:00 08:00
     2022-11-07 12:52:06   RegL_07.         00:00 01:2A 02:22 03:09 04:3D 05:00 06:00 07:00 08:00 09:87 0A:30 0B:00 0C:00 0D:00 0E:01 0F:04 10:00 11:00 12:09 13:00 14:44 15:48 16:55 17:08 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:44 2F:48 30:55 31:08 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:44 49:48 4A:54 4B:6C 4C:44 4D:CC 4E:55 4F:08 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:44 63:48 64:54 65:6C 66:44 67:CC 68:55 69:08 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:44 7D:48 7E:54 7F:6C 80:44 81:CC 82:55 83:08 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:44 97:48 98:54 99:6C 9A:44 9B:CC 9C:55 9D:08 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:44 B1:48 B2:54 B3:6C B4:44 B5:CC B6:55 B7:08 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
     2022-11-07 12:52:10   RegL_08.         00:00 01:00 02:00 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:00 0D:00 0E:00 0F:00 10:00 11:00 12:00 13:00 14:45 15:20 16:45 17:20 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:45 2F:20 30:45 31:20 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:45 49:20 4A:45 4B:20 4C:45 4D:20 4E:45 4F:20 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:45 63:20 64:45 65:20 66:45 67:20 68:45 69:20 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:45 7D:20 7E:45 7F:20 80:45 81:20 82:45 83:20 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:45 97:20 98:45 99:20 9A:45 9B:20 9C:45 9D:20 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:45 B1:20 B2:45 B3:20 B4:45 B5:20 B6:45 B7:20 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
     2022-11-07 12:52:13   RegL_09.         00:00 01:00 02:00 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:00 0D:00 0E:00 0F:00 10:00 11:00 12:00 13:00 14:45 15:20 16:45 17:20 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:45 2F:20 30:45 31:20 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:45 49:20 4A:45 4B:20 4C:45 4D:20 4E:45 4F:20 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:45 63:20 64:45 65:20 66:45 67:20 68:45 69:20 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:45 7D:20 7E:45 7F:20 80:45 81:20 82:45 83:20 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:45 97:20 98:45 99:20 9A:45 9B:20 9C:45 9D:20 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:45 B1:20 B2:45 B3:20 B4:45 B5:20 B6:45 B7:20 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
     2022-11-07 15:15:16   boostTime       -
     2022-11-07 12:53:15   cfgState        TempChk
     2022-11-07 15:15:16   commReporting   off
     2022-11-07 15:15:16   controlMode     manual
     2022-11-07 15:40:43   desired-temp    18.0
     2022-11-07 15:40:43   humidity        62
     2022-11-07 15:40:43   measured-temp   18.9
     2022-11-07 12:52:26   recentStateType ack
     2022-11-07 15:40:43   state           T: 18.9 desired: 18.0
     2022-10-09 20:17:01   trigLast        fhem:80
     2022-11-07 15:15:16   winOpenReporting off
   helper:
     cfgChkResult No regs found for:-ret--ret-HM_303ABC_Climate type:thermostat - -ret-list:peer register         :value-ret-   1:      sign             :off-ret-   7:      boostPeriod      :5 min-ret-   7:      dayTemp          :21 C-ret-   7:      daylightSaveTime :on-ret-   7:      heatCool         :heating-ret-   7:      modePrioManu     :all-ret-   7:      modePrioParty    :all-ret-   7:      nightTemp        :17 C-ret-   7:      noMinMax4Manu    :off-ret-   7:      sendWeatherData  :set_on-ret-   7:      showHumidity     :set_temp-ret-   7:      showInfo         :time-ret-   7:      showSetTemp      :set_actTemp-ret-   7:      showWeekday      :off-ret-   7:      tempMax          :30.5 C-ret-   7:      tempMin          :4.5 C-ret-   7:      tempOffset       :set_-1.0K-ret-   7:      weekPrgSel       :prog1-ret-   7:      winOpnBoost      :off-ret-Temp set P2_: 0_Sat 24:00 17.0 C-ret-Temp set P2_: 1_Sun 24:00 17.0 C-ret-Temp set P2_: 2_Mon 24:00 17.0 C-ret-Temp set P2_: 3_Tue 24:00 17.0 C-ret-Temp set P2_: 4_Wed 24:00 17.0 C-ret-Temp set P2_: 5_Thu 24:00 17.0 C-ret-Temp set P2_: 6_Fri 24:00 17.0 C-ret-Temp set P3_: 0_Sat 24:00 17.0 C-ret-Temp set P3_: 1_Sun 24:00 17.0 C-ret-Temp set P3_: 2_Mon 24:00 17.0 C-ret-Temp set P3_: 3_Tue 24:00 17.0 C-ret-Temp set P3_: 4_Wed 24:00 17.0 C-ret-Temp set P3_: 5_Thu 24:00 17.0 C-ret-Temp set P3_: 6_Fri 24:00 17.0 C-ret-                       -ret-                       -ret-
     peerFriend peerRtTc
     peerIDsRaw ,00000000
     peerIDsState complete
     peerOpt    p:thermostat
     regLst     1,7,8,9
     cfgChk:
       idTp00     file: ./tempList.cfg error:Can't open ./tempList.cfg: No such file or directory
     cmds:
       TmplKey    :no:1666428512.8437
       TmplTs     1666428512.8437
       cmdKey     1:0:0::HM_303ABC:00AD:02:
       cmdLst:
         controlManu (on|off|5.0..30.0;0.5)
         controlMode (auto|manual|boost|day|night)
         controlParty -temp- -startDate- -startTime- -endDate- -endTime-
         desired-temp (on|off|5.0..30.0;0.5)
         getConfig  noArg
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single})] [({set}|unset)] [(actor|remote|{both})]
         sign       [(on|{off})]
         tempListFri [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempListMon [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempListSat [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempListSun [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempListThu [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempListTmpl [({verify}|restore)] [[-file-:]-templateName-]
         tempListTue [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempListWed [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
         tempTmplSet -tempTmpl-
         tplDel     -tplDel-
         tplSet_0   -tplChan-
       lst:
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     peerIDsH:
       00000000   broadcast
     regCollect:
     role:
       chn        1
     shRegR:
       07         00
     shadowReg:
     tmpl:
   nb:
     cnt        1
   alias      Wohnzimmer_Climate
   event-min-interval measured-temp:300
   peerIDs    00000000
   room       Temperatur
rvideobaer
da kann man doch einstellen ob er die gemessene Temp oder die eingestellte Temp anzeigt.
Gruß Rolf
Raspberry Pi 2, HM-Uart,1x HM-LC-Sw1PBU-FM, 1x HM-RC-2-PBU-FM,1x HM-LC-SW4-DR,1x HM-LC-Sw1-Pl-DN-R1,1x HM-TC-IT-WM-W-EU, 5x HM-CC-RT-DN und noch mehr
maxritti
Danke für die Idee.
Aber es ist halt weder die aktuelle (measured-temp 18.9) noch die eingestellte (desired-temp 18.0) Temperatur.
yersinia
viele Grüße, yersinia
FHEM 6.4 (SVN) on RPi 4B with RasPi OS Bookworm (perl 5.36.0) | FTUI
maxritti
Sorry, verstehe ich jetzt nicht.
Ist doch das gleiche wie rvideobear es meinte oder?
Es ist ja weder die aktuelle Temperatur (da im Reading measured-temp 18.9 steht) und auch nicht die Soll-Temperatur (da im Reading desired-Temp 18.0) steht.
Oder bin ich komplett auf dem falschen Weg?
yersinia
Neee, stimmt. Zumal der TC auch die aktuelle Temperatur (measured-temp imho) anzeigen soll:
Aber keine Ahnung woher die Diskrepanz zwischen Display-Anzeige und measured-temp kommen kann dann. Zeigt der TC ggf einen Messwert eines anderen Geräts an? :o
maxritti
Hat dazu keiner eine Idee?
Das Dingen schmeisse ich glaube ich in die Tonne.
Werksreset hat auch nichts gebracht.
Momentan steht auf dem Display 24.3° unter measured-temp allerdings 19.2°
frank
welche temp ist richtig?
vielleicht ein problem durch das update.
nach fw update mache ich grundsätzlich werkreset.
FHEM: 6.0(SVN) => Pi3(buster)
maxritti
Also Deine Idee war gar nicht soooo verkehrt. Problem ist gelöst, aber eigentlich darf ich gar nicht sagen, was es war.  ???
Denn ich habe ja 4 Thermostate auf einmal implementiert. Irgendwer hat mir wohl einen Streich gespielt und 2 vertauscht, so dass im Wohnzimmer das vom WC hing und umgekehrt. Klar, dass da die Angaben unterschiedlich sind.
Und im WC habe ich selten drauf geschaut.
Naja, nun ist es ja gelöst.
Wobei mit dem FW Update habe ich mir den einen wohl zerschossen.
Zeigt mein Reset ein "FUP" an und ist in FHEM auch nicht mehr richtig anzusprechen.
Gibt es da eine Möglichkeit, den wieder ins Leben zu rufen?
maxritti
Jetzt suche und google ich schon 15 Minuten nach der 1.3 FW.
Da hast du doch bestimmt auch einen Link unter der Maus.  8)
lag bei mir noch lokal - anhängend.
