perfmon/ freezemon Einträge
Begonnen von Flanders, 18 Dezember 2022, 13:01:01
Flanders
ich habe im Log diverse Perfmon/ Freezemon Einträge. Leider konnte ich keinen eindeutigen Schuldigen ausmachen...
Fhem läuft in einer Proxmox Maschine mit 4 Kernen und 4 GB. Da ist auch nicht viel Last drauf...
2022.12.18 12:49:53.010 1: Perfmon: possible freeze starting at 12:49:49, delay is 4.01
2022.12.18 12:49:53.010 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2022.12.18 12:49:53.010 ---------------------
2022.12.18 12:49:53.010 5: Freezemon: something went wrong FW_closeInactiveClients
2022.12.18 12:49:53.011 1: [Freezemon] myFreezemon: possible freeze starting at 12:49:49, delay is 4.01 possibly caused by: tmr-FW_closeInactiveClients(N/A) tmr-perfmon_ProcessTimer(N/A)
2022.12.18 12:49:53.011 5: Starting notify loop for myFreezemon, 5 event(s), first is s:12:49:49 e:12:49:53 f:4.01 d:tmr-FW_closeInactiveClients(N/A) tmr-perfmon_ProcessTimer(N/A)
2022.12.18 12:49:53.011 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceReadings, dev=myFreezemon, dev_regex=.* temp_name=temperature hum_name=humidity
2022.12.18 12:49:53.011 5: dewpoint_notify: s='s:12:49:49 e:12:49:53 f:4.01 d:tmr-FW_closeInactiveClients(N/A) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 12:49:53.011 5: dewpoint_notify: evName='s:12:49:49' val=e:12:49:53'
2022.12.18 12:49:53.011 5: dewpoint_notify: s='freezeTime: 4.01'
2022.12.18 12:49:53.011 5: dewpoint_notify: evName='freezeTime:' val=4.01'
2022.12.18 12:49:53.011 5: dewpoint_notify: s='fcDay: 60'
2022.12.18 12:49:53.011 5: dewpoint_notify: evName='fcDay:' val=60'
2022.12.18 12:49:53.011 5: dewpoint_notify: s='ftDay: 401.066'
2022.12.18 12:49:53.011 5: dewpoint_notify: evName='ftDay:' val=401.066'
2022.12.18 12:49:53.011 5: dewpoint_notify: s='freezeDevice: tmr-FW_closeInactiveClients(N/A) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 12:49:53.011 5: dewpoint_notify: evName='freezeDevice:' val=tmr-FW_closeInactiveClients(N/A)'
2022.12.18 12:49:53.011 5: dewpoint_notify: max_timediff=1
2022.12.18 12:49:53.011 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceStates, dev=myFreezemon, dev_regex=.* temp_name=T hum_name=H
2022.12.18 12:49:53.012 5: dewpoint_notify: evName='freezeDevice:' val=tmr-FW_closeInactiveClients(N/A)'
2022.12.18 12:49:53.012 5: dewpoint_notify: max_timediff=1
2022.12.18 12:49:53.012 5: ZE.Batterie: not on any display, ignoring notify
2022.12.18 12:49:53.029 5: End notify loop for myFreezemon
2022.12.18 12:49:53.029 5: [Freezemon] myFreezemon: ----------- Ending Freeze handling at 2022.12.18 12:49:53.029 after 0.018618 --------
2022.12.18 12:42:35.512 1: Perfmon: possible freeze starting at 12:42:34, delay is 1.512
2022.12.18 12:42:35.512 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2022.12.18 12:42:35.512 ---------------------
2022.12.18 12:42:35.512 1: [Freezemon] myFreezemon: possible freeze starting at 12:42:34, delay is 1.512 possibly caused by: tmr-perfmon_ProcessTimer(N/A)
2022.12.18 12:42:35.513 5: Starting notify loop for myFreezemon, 5 event(s), first is s:12:42:34 e:12:42:35 f:1.512 d:tmr-perfmon_ProcessTimer(N/A)
2022.12.18 12:42:35.513 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceReadings, dev=myFreezemon, dev_regex=.* temp_name=temperature hum_name=humidity
2022.12.18 12:42:35.513 5: dewpoint_notify: s='s:12:42:34 e:12:42:35 f:1.512 d:tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 12:42:35.513 5: dewpoint_notify: evName='s:12:42:34' val=e:12:42:35'
2022.12.18 12:42:35.513 5: dewpoint_notify: s='freezeTime: 1.512'
2022.12.18 12:42:35.513 5: dewpoint_notify: evName='freezeTime:' val=1.512'
2022.12.18 12:42:35.513 5: dewpoint_notify: s='fcDay: 59'
2022.12.18 12:42:35.513 5: dewpoint_notify: evName='fcDay:' val=59'
2022.12.18 12:42:35.513 5: dewpoint_notify: s='ftDay: 397.056'
2022.12.18 12:42:35.513 5: dewpoint_notify: evName='ftDay:' val=397.056'
2022.12.18 12:42:35.513 5: dewpoint_notify: s='freezeDevice: tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 12:42:35.513 5: dewpoint_notify: evName='freezeDevice:' val=tmr-perfmon_ProcessTimer(N/A)'
2022.12.18 12:42:35.514 5: dewpoint_notify: max_timediff=1
2022.12.18 12:42:35.514 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceStates, dev=myFreezemon, dev_regex=.* temp_name=T hum_name=H
2022.12.18 12:42:35.514 5: dewpoint_notify: s='s:12:42:34 e:12:42:35 f:1.512 d:tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 12:42:35.514 5: dewpoint_notify: evName='s:12:42:34' val=e:12:42:35'
2022.12.18 12:42:35.514 5: dewpoint_notify: s='freezeTime: 1.512'
2022.12.18 12:42:35.514 5: dewpoint_notify: evName='freezeTime:' val=1.512'
2022.12.18 12:42:35.514 5: dewpoint_notify: s='fcDay: 59'
2022.12.18 12:42:35.514 5: dewpoint_notify: evName='fcDay:' val=59'
2022.12.18 12:42:35.514 5: dewpoint_notify: s='ftDay: 397.056'
2022.12.18 12:42:35.514 5: dewpoint_notify: evName='ftDay:' val=397.056'
2022.12.18 12:42:35.514 5: dewpoint_notify: s='freezeDevice: tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 12:42:35.514 5: dewpoint_notify: evName='freezeDevice:' val=tmr-perfmon_ProcessTimer(N/A)'
2022.12.18 12:42:35.515 5: ZE.Batterie: not on any display, ignoring notify
2022.12.18 12:42:35.532 5: End notify loop for myFreezemon
2022.12.18 12:42:35.532 5: [Freezemon] myFreezemon: ----------- Ending Freeze handling at 2022.12.18 12:42:35.532 after 0.02025 --------
2022.12.18 11:36:47.553 1: Perfmon: possible freeze starting at 11:35:12, delay is 95.553
2022.12.18 11:36:47.554 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2022.12.18 11:36:47.554 ---------------------
2022.12.18 11:36:47.554 1: [Freezemon] myFreezemon: possible freeze starting at 11:35:12, delay is 95.553 possibly caused by: tmr-SONOS_IsSubprocessAliveChecker(Sonos) tmr-perfmon_ProcessTimer(N/A)
2022.12.18 11:36:47.555 5: Starting notify loop for myFreezemon, 5 event(s), first is s:11:35:12 e:11:36:47 f:95.553 d:tmr-SONOS_IsSubprocessAliveChecker(Sonos) tmr-perfmon_ProcessTimer(N/A)
2022.12.18 11:36:47.555 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceReadings, dev=myFreezemon, dev_regex=.* temp_name=temperature hum_name=humidity
2022.12.18 11:36:47.555 5: dewpoint_notify: s='s:11:35:12 e:11:36:47 f:95.553 d:tmr-SONOS_IsSubprocessAliveChecker(Sonos) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:36:47.555 5: dewpoint_notify: evName='s:11:35:12' val=e:11:36:47'
2022.12.18 11:36:47.555 5: dewpoint_notify: s='freezeTime: 95.553'
2022.12.18 11:36:47.555 5: dewpoint_notify: evName='freezeTime:' val=95.553'
2022.12.18 11:36:47.555 5: dewpoint_notify: s='fcDay: 56'
2022.12.18 11:36:47.555 5: dewpoint_notify: evName='fcDay:' val=56'
2022.12.18 11:36:47.555 5: dewpoint_notify: s='ftDay: 392.84'
2022.12.18 11:36:47.555 5: dewpoint_notify: evName='ftDay:' val=392.84'
2022.12.18 11:36:47.555 5: dewpoint_notify: s='freezeDevice: tmr-SONOS_IsSubprocessAliveChecker(Sonos) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:36:47.555 5: dewpoint_notify: evName='freezeDevice:' val=tmr-SONOS_IsSubprocessAliveChecker(Sonos)'
2022.12.18 11:36:47.555 5: dewpoint_notify: max_timediff=1
2022.12.18 11:36:47.556 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceStates, dev=myFreezemon, dev_regex=.* temp_name=T hum_name=H
2022.12.18 11:36:47.556 5: dewpoint_notify: s='s:11:35:12 e:11:36:47 f:95.553 d:tmr-SONOS_IsSubprocessAliveChecker(Sonos) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:36:47.556 5: dewpoint_notify: evName='s:11:35:12' val=e:11:36:47'
2022.12.18 11:36:47.556 5: dewpoint_notify: s='freezeTime: 95.553'
2022.12.18 11:36:47.556 5: dewpoint_notify: evName='freezeTime:' val=95.553'
2022.12.18 11:36:47.556 5: dewpoint_notify: s='fcDay: 56'
2022.12.18 11:36:47.556 5: dewpoint_notify: evName='fcDay:' val=56'
2022.12.18 11:36:47.556 5: dewpoint_notify: s='ftDay: 392.84'
2022.12.18 11:36:47.556 5: dewpoint_notify: evName='ftDay:' val=392.84'
2022.12.18 11:36:47.556 5: dewpoint_notify: s='freezeDevice: tmr-SONOS_IsSubprocessAliveChecker(Sonos) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:36:47.556 5: dewpoint_notify: evName='freezeDevice:' val=tmr-SONOS_IsSubprocessAliveChecker(Sonos)'
2022.12.18 11:36:47.556 5: dewpoint_notify: max_timediff=1
2022.12.18 11:36:47.557 5: ZE.Batterie: not on any display, ignoring notify
2022.12.18 11:36:47.578 5: End notify loop for myFreezemon
2022.12.18 11:36:47.578 5: [Freezemon] myFreezemon: ----------- Ending Freeze handling at 2022.12.18 11:36:47.578 after 0.024241 --------
2022.12.18 11:34:46.444 1: Perfmon: possible freeze starting at 11:34:44, delay is 2.444
2022.12.18 11:34:46.444 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2022.12.18 11:34:46.444 ---------------------
2022.12.18 11:34:46.444 1: [Freezemon] myFreezemon: possible freeze starting at 11:34:44, delay is 2.444 possibly caused by: tmr-perfmon_ProcessTimer(N/A)
2022.12.18 11:34:46.444 5: Starting notify loop for myFreezemon, 5 event(s), first is s:11:34:44 e:11:34:46 f:2.444 d:tmr-perfmon_ProcessTimer(N/A)
2022.12.18 11:34:46.444 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceReadings, dev=myFreezemon, dev_regex=.* temp_name=temperature hum_name=humidity
2022.12.18 11:34:46.444 5: dewpoint_notify: s='s:11:34:44 e:11:34:46 f:2.444 d:tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:46.444 5: dewpoint_notify: evName='s:11:34:44' val=e:11:34:46'
2022.12.18 11:34:46.444 5: dewpoint_notify: s='freezeTime: 2.444'
2022.12.18 11:34:46.444 5: dewpoint_notify: evName='freezeTime:' val=2.444'
2022.12.18 11:34:46.444 5: dewpoint_notify: s='fcDay: 55'
2022.12.18 11:34:46.444 5: dewpoint_notify: evName='fcDay:' val=55'
2022.12.18 11:34:46.445 5: dewpoint_notify: s='ftDay: 297.287'
2022.12.18 11:34:46.445 5: dewpoint_notify: evName='ftDay:' val=297.287'
2022.12.18 11:34:46.445 5: dewpoint_notify: s='freezeDevice: tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:46.445 5: dewpoint_notify: evName='freezeDevice:' val=tmr-perfmon_ProcessTimer(N/A)'
2022.12.18 11:34:46.445 5: dewpoint_notify: max_timediff=1
2022.12.18 11:34:46.445 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceStates, dev=myFreezemon, dev_regex=.* temp_name=T hum_name=H
2022.12.18 11:34:46.445 5: dewpoint_notify: s='s:11:34:44 e:11:34:46 f:2.444 d:tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:46.445 5: dewpoint_notify: evName='s:11:34:44' val=e:11:34:46'
2022.12.18 11:34:46.445 5: dewpoint_notify: s='freezeTime: 2.444'
2022.12.18 11:34:46.445 5: dewpoint_notify: evName='freezeTime:' val=2.444'
2022.12.18 11:34:46.445 5: dewpoint_notify: s='fcDay: 55'
2022.12.18 11:34:46.445 5: dewpoint_notify: evName='fcDay:' val=55'
2022.12.18 11:34:46.445 5: ZE.Batterie: not on any display, ignoring notify
2022.12.18 11:34:46.462 5: End notify loop for myFreezemon
2022.12.18 11:34:46.463 5: [Freezemon] myFreezemon: ----------- Ending Freeze handling at 2022.12.18 11:34:46.463 after 0.018755 --------
2022.12.18 11:34:19.100 1: Perfmon: possible freeze starting at 11:34:18, delay is 1.1
2022.12.18 11:34:19.100 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2022.12.18 11:34:19.100 ---------------------
2022.12.18 11:34:19.100 5: Freezemon: something went wrong FW_closeInactiveClients
2022.12.18 11:34:19.101 1: [Freezemon] myFreezemon: possible freeze starting at 11:34:18, delay is 1.1 possibly caused by: tmr-FW_closeInactiveClients(N/A) tmr-NUT_PollTimer(USV_Keller) tmr-MQTT2_SERVER_keepaliveChecker(MQTT2_FHEM_Server) tmr-withings_poll(withings_D11696753) tmr-perfmon_ProcessTimer(N/A)
2022.12.18 11:34:19.101 5: Starting notify loop for myFreezemon, 5 event(s), first is s:11:34:18 e:11:34:19 f:1.1 d:tmr-FW_closeInactiveClients(N/A) tmr-NUT_PollTimer(USV_Keller) tmr-MQTT2_SERVER_keepaliveChecker(MQTT2_FHEM_Server) tmr-withings_poll(withings_D11696753) tmr-perfmon_ProcessTimer(N/A)
2022.12.18 11:34:19.101 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceReadings, dev=myFreezemon, dev_regex=.* temp_name=temperature hum_name=humidity
2022.12.18 11:34:19.101 5: dewpoint_notify: s='s:11:34:18 e:11:34:19 f:1.1 d:tmr-FW_closeInactiveClients(N/A) tmr-NUT_PollTimer(USV_Keller) tmr-MQTT2_SERVER_keepaliveChecker(MQTT2_FHEM_Server) tmr-withings_poll(withings_D11696753) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:19.101 5: dewpoint_notify: evName='s:11:34:18' val=e:11:34:19'
2022.12.18 11:34:19.101 5: dewpoint_notify: s='freezeTime: 1.1'
2022.12.18 11:34:19.101 5: dewpoint_notify: evName='freezeTime:' val=1.1'
2022.12.18 11:34:19.101 5: dewpoint_notify: s='fcDay: 54'
2022.12.18 11:34:19.101 5: dewpoint_notify: evName='fcDay:' val=54'
2022.12.18 11:34:19.101 5: dewpoint_notify: s='ftDay: 294.843'
2022.12.18 11:34:19.101 5: dewpoint_notify: evName='ftDay:' val=294.843'
2022.12.18 11:34:19.101 5: dewpoint_notify: s='freezeDevice: tmr-FW_closeInactiveClients(N/A) tmr-NUT_PollTimer(USV_Keller) tmr-MQTT2_SERVER_keepaliveChecker(MQTT2_FHEM_Server) tmr-withings_poll(withings_D11696753) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:19.101 5: dewpoint_notify: evName='freezeDevice:' val=tmr-FW_closeInactiveClients(N/A)'
2022.12.18 11:34:19.102 5: dewpoint_notify: max_timediff=1
2022.12.18 11:34:19.102 4: dewpoint_notify: cmd_type=dewpoint devname=myFreezemon dewname=dewpointToAllDeviceStates, dev=myFreezemon, dev_regex=.* temp_name=T hum_name=H
2022.12.18 11:34:19.102 5: dewpoint_notify: s='s:11:34:18 e:11:34:19 f:1.1 d:tmr-FW_closeInactiveClients(N/A) tmr-NUT_PollTimer(USV_Keller) tmr-MQTT2_SERVER_keepaliveChecker(MQTT2_FHEM_Server) tmr-withings_poll(withings_D11696753) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:19.102 5: dewpoint_notify: evName='s:11:34:18' val=e:11:34:19'
2022.12.18 11:34:19.102 5: dewpoint_notify: s='freezeTime: 1.1'
2022.12.18 11:34:19.102 5: dewpoint_notify: evName='freezeTime:' val=1.1'
2022.12.18 11:34:19.102 5: dewpoint_notify: s='fcDay: 54'
2022.12.18 11:34:19.102 5: dewpoint_notify: evName='fcDay:' val=54'
2022.12.18 11:34:19.102 5: dewpoint_notify: s='ftDay: 294.843'
2022.12.18 11:34:19.102 5: dewpoint_notify: evName='ftDay:' val=294.843'
2022.12.18 11:34:19.102 5: dewpoint_notify: s='freezeDevice: tmr-FW_closeInactiveClients(N/A) tmr-NUT_PollTimer(USV_Keller) tmr-MQTT2_SERVER_keepaliveChecker(MQTT2_FHEM_Server) tmr-withings_poll(withings_D11696753) tmr-perfmon_ProcessTimer(N/A) '
2022.12.18 11:34:19.102 5: dewpoint_notify: evName='freezeDevice:' val=tmr-FW_closeInactiveClients(N/A)'
2022.12.18 11:34:19.103 5: ZE.Batterie: not on any display, ignoring notify
2022.12.18 11:34:19.121 5: End notify loop for myFreezemon
2022.12.18 11:34:19.121 5: [Freezemon] myFreezemon: ----------- Ending Freeze handling at 2022.12.18 11:34:19.121 after 0.021173 --------
Greets
