Problem mit zigbee2mqtt
Begonnen von morrpheus, 16 März 2023, 21:47:07
morrpheus
Moin Moin.
Durch einen Unfall muss ich fhem komplett neu aufsetzen.
Leider bekomme ich es nicht hin zigbee2mqtt zum laufen zu bekommen.
Ich habe es nach dieser Anleitung installiert.
Der Dienst läuft auch. In fhem hab ich allerdings als Status nur ??? und Geräte werden nicht erkannt.
defmod MQTT2_zigbee_pi MQTT2_DEVICE zigbee_pi
attr MQTT2_zigbee_pi IODev MQTT2_FHEM_Server
attr MQTT2_zigbee_pi bridgeRegexp zigbee2mqtt/([A-Za-z0-9._]+)[/]?.*:.* "zigbee_$1"
attr MQTT2_zigbee_pi comment To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
attr MQTT2_zigbee_pi devicetopic zigbee2mqtt
attr MQTT2_zigbee_pi getList networkmap_raw:noArg raw $DEVICETOPIC/bridge/request/networkmap raw\
  networkmap_graphviz:noArg graphviz $DEVICETOPIC/bridge/request/networkmap graphviz
attr MQTT2_zigbee_pi icon mqtt
attr MQTT2_zigbee_pi model zigbee2mqtt_bridge
attr MQTT2_zigbee_pi readingList $DEVICETOPIC/bridge/state:.* state\
  $DEVICETOPIC/bridge/config/devices:.* {}\
  $DEVICETOPIC/bridge/config/log_level:.* log_level\
  $DEVICETOPIC/bridge/config/permit_join:.* permit_join\
  $DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }\
  $DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }\
  $DEVICETOPIC/bridge/log:.*\"type\".\"devices\".\"message\".* devices\
  $DEVICETOPIC/bridge/log:.* log\
  $DEVICETOPIC/bridge/logging:.* { json2nameValue($EVENT,'log_') }\
  $DEVICETOPIC/bridge/response/networkmap:.* { my $type = $EVENT =~ m/.*,"type":"(raw|graphviz)",.*/ ? $1 : 'networkmap';; $EVENT =~ m/{"data":\{.*"value":"?(.*[^"])"?\},"status":"ok"\}/ ? { $type=>$1 } : {} }\
  $DEVICETOPIC/bridge/devices:.* devices\
  $DEVICETOPIC/bridge/info:.* info\
  $DEVICETOPIC/bridge/groups:.* groups\
  $DEVICETOPIC/bridge/event:.* { json2nameValue($EVENT) }\
  $DEVICETOPIC/bridge/extensions:.* extensions
attr MQTT2_zigbee_pi setList log_level:debug,info,warn,error $DEVICETOPIC/bridge/config/log_level $EVTPART1\
  permit_join:true,false $DEVICETOPIC/bridge/request/permit_join $EVTPART1\
  remove:textField $DEVICETOPIC/bridge/config/remove $EVTPART1\
  ota_update:textField $DEVICETOPIC/bridge/ota_update/update $EVTPART1\
  ota_update_check:textField $DEVICETOPIC/bridge/ota_update/check $EVTPART1\
  y_device_setting:textField $DEVICETOPIC/$EVTPART1/set {"$EVTPART2": "$EVTPART3"}\
  x_bind:textField $DEVICETOPIC/bridge/bind/$EVTPART1 $EVTPART2\
  x_bind_unbind:textField $DEVICETOPIC/bridge/unbind/$EVTPART1 $EVTPART2\
  x_device_options:textField $DEVICETOPIC/bridge/config/device_options {"friendly_name":"$EVTPART1","options": {"$EVTPART2": "$EVTPART3"}}\
  x_group_add_to:textField $DEVICETOPIC/bridge/group/$EVTPART1/add $EVTPART2\
  x_group_rm_from:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove $EVTPART2\
  x_group_rm_from_all:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove_all $EVTPART2\
  x_group_add_group:textField $DEVICETOPIC/bridge/config/add_group $EVTPART1\
  x_group_rm_group:textField $DEVICETOPIC/bridge/config/remove_group $EVTPART1\
  z_elapsed:textField $DEVICETOPIC/bridge/config/elapsed $EVTPART1\
  z_last_seen:disable,ISO_8601,epoch,ISO_8601_local $DEVICETOPIC/bridge/config/last_seen $EVTPART1\
  z_ban:textField $DEVICETOPIC/bridge/config/ban $EVTPART1\
  z_rename:textField $DEVICETOPIC/bridge/config/rename  {"old":"$EVTPART1","new":"$EVTPART2"}\
  z_reset_CC:noArg $DEVICETOPIC/bridge/config/reset
attr MQTT2_zigbee_pi setStateList on off
defmod MQTT2_FHEM_Server MQTT2_SERVER 1883 global
attr MQTT2_FHEM_Server autocreate complex
setstate MQTT2_FHEM_Server 2023-03-16 20:19:21 nrclients 0
setstate MQTT2_FHEM_Server 2023-03-16 20:31:31 state Initialized
Wo liegt denn mein Fehler, ausser dass ich kein Backup habe?
Vermutlich ist das keine Anfängerfrage, sondern wäre besser im ZigBee-Bereich aufgehoben, aber soweit ich das in Erinnerung habe, hat zigbee2mqtt die bekannten Geräte in einer eigenen Datenbank gespeichert - und die ist vermutlich auch weg bzw. noch nicht wieder aufgebaut.
In FHEM kann man das afaik daran erkennen, dass kein "Riesenreading" in der z2m-bridge auftaucht, in dem alle möglichen und unmöglichen Daten über deine ganzen Geräte drin sind?
Wenn du kein backup davon hast, wirst du vermutlich alle ZigBee-Geräte neu anlernen müssen, und wenn du dann "Glück" hast und keine "friendly names" vergeben hattest, sollte dann auch wieder FHEM wissen, was was ist. Sonst musst du ggf. schauen, welches "devicetopic" zu welchem ("neuen") Gerät gehört.
