[gelöst] mehrere versch. Attribute gleichzeitig eintragen
Begonnen von rhoffm34, 27 August 2023, 20:02:34
rhoffm34
gibt es einen Trick mehrere verschiedene Attr. gleichzeitig einzutragen?
attr Sun2000 obj-h32016-expr $val/10
attr Sun2000 obj-h32016-len 1
attr Sun2000 obj-h32016-poll 1
attr Sun2000 obj-h32016-reading PV1_voltage
attr Sun2000 obj-h32016-unpack n!
attr Sun2000 obj-h32017-expr $val/100
attr Sun2000 obj-h32017-len 1
attr Sun2000 obj-h32017-poll 1
attr Sun2000 obj-h32017-reading PV1_current
attr Sun2000 obj-h32017-unpack n!
attr Sun2000 obj-h32018-expr $val/10
attr Sun2000 obj-h32018-len 1
attr Sun2000 obj-h32018-poll 1
attr Sun2000 obj-h32018-reading PV2_voltage
attr Sun2000 obj-h32018-unpack n!
attr Sun2000 obj-h32019-expr $val/100
attr Sun2000 obj-h32019-len 1
attr Sun2000 obj-h32019-poll 1
attr Sun2000 obj-h32019-reading PV2_current
attr Sun2000 obj-h32019-unpack n!
attr Sun2000 obj-h32064-len 2
attr Sun2000 obj-h32064-poll 1
attr Sun2000 obj-h32064-reading WR_Eingangsleistung_Solar_W
attr Sun2000 obj-h32064-unpack N!
attr Sun2000 obj-h32069-expr $val/10
attr Sun2000 obj-h32069-len 1
attr Sun2000 obj-h32069-poll 1
attr Sun2000 obj-h32069-reading WR_Phase_A_Voltage
attr Sun2000 obj-h32069-unpack n!
attr Sun2000 obj-h32070-expr $val/10
attr Sun2000 obj-h32070-len 1
attr Sun2000 obj-h32070-poll 1
attr Sun2000 obj-h32070-reading WR_Phase_B_Voltage
attr Sun2000 obj-h32070-unpack n!
attr Sun2000 obj-h32071-expr $val/10
attr Sun2000 obj-h32071-len 1
attr Sun2000 obj-h32071-poll 1
attr Sun2000 obj-h32071-reading WR_Phase_C_Voltage
attr Sun2000 obj-h32071-unpack n!
attr Sun2000 obj-h32072-expr $val/1000
attr Sun2000 obj-h32072-len 2
attr Sun2000 obj-h32072-poll 1
attr Sun2000 obj-h32072-reading WR_Phase_A_Current
attr Sun2000 obj-h32072-unpack N!
attr Sun2000 obj-h32074-expr $val/1000
attr Sun2000 obj-h32074-len 2
attr Sun2000 obj-h32074-poll 1
attr Sun2000 obj-h32074-reading WR_Phase_B_Current
attr Sun2000 obj-h32074-unpack N!
attr Sun2000 obj-h32076-expr $val/1000
attr Sun2000 obj-h32076-len 2
attr Sun2000 obj-h32076-poll 1
attr Sun2000 obj-h32076-reading WR_Phase_C_Current
attr Sun2000 obj-h32076-unpack N!
attr Sun2000 obj-h32078-len 2
attr Sun2000 obj-h32078-poll 1
attr Sun2000 obj-h32078-reading WR_Maximalleistung_Tag_W
attr Sun2000 obj-h32078-unpack N!
attr Sun2000 obj-h32080-len 2
attr Sun2000 obj-h32080-poll 1
attr Sun2000 obj-h32080-reading WR_Momentanleistung_W
attr Sun2000 obj-h32080-unpack N!
attr Sun2000 obj-h32086-expr $val/100
attr Sun2000 obj-h32086-len 1
attr Sun2000 obj-h32086-poll 1
attr Sun2000 obj-h32086-reading WR_Efficiency
attr Sun2000 obj-h32086-unpack n
attr Sun2000 obj-h32087-expr $val/10
attr Sun2000 obj-h32087-len 1
attr Sun2000 obj-h32087-poll 1
attr Sun2000 obj-h32087-reading WR_Internal_temperature
attr Sun2000 obj-h32087-unpack n!
attr Sun2000 obj-h32089-len 1
attr Sun2000 obj-h32089-map 0:standby, 1:standby, 2:standby, 3:standby, 256:starting, 512:on_grid, 513:power_limited, 514:self_derating, 768:shutdown_fault, 769:shutdown_command, 770:shutdown_OVGR, 771:shutdown_comm_disconn, 772:shutdown_power_limited, 773:shutdown_manual_startup_required, 774:shutdown_DC_switches_disconn, 775:shutdown_rapid_cutoff, 776:shutdown_input_underpower, 1025:Grid_scheduling_cosφ-P_curve, 1026:Grid_scheduling_Q-U_curve, 1027:Grid_scheduling_PF-U_curve, 1028:Grid_scheduling_dry_contact, 1029:Grid_scheduling_Q-P_curve, 1280:Spot-check_ready, 1281:Spot-checking, 1536:Inspecting, 1792:AFCI_self_check, 2048:I-V_scanning, 2304:DC_input_detection, 2560:Running_off-grid_charging, 40960:Standby_no_irradiation
attr Sun2000 obj-h32089-poll 1
attr Sun2000 obj-h32089-reading WR_Device_status
attr Sun2000 obj-h32089-unpack n
attr Sun2000 obj-h32091-len 2
attr Sun2000 obj-h32091-poll 1
attr Sun2000 obj-h32091-reading WR_Startup_Time
attr Sun2000 obj-h32091-unpack N!
attr Sun2000 obj-h32093-len 2
attr Sun2000 obj-h32093-poll 1
attr Sun2000 obj-h32093-reading WR_Shutdown_Time
attr Sun2000 obj-h32093-unpack N!
attr Sun2000 obj-h32106-expr $val/100
attr Sun2000 obj-h32106-len 2
attr Sun2000 obj-h32106-poll 1
attr Sun2000 obj-h32106-polldelay 3600
attr Sun2000 obj-h32106-reading WR_Gesamtertrag_kWh
attr Sun2000 obj-h32106-unpack N
attr Sun2000 obj-h32114-expr $val/100
attr Sun2000 obj-h32114-len 2
attr Sun2000 obj-h32114-poll 1
attr Sun2000 obj-h32114-reading WR_Energie_Tag_kWh
attr Sun2000 obj-h32114-unpack N
attr Sun2000 obj-h37000-len 1
attr Sun2000 obj-h37000-map 0:offline, 1:standby, 2:running, 3:fault, 4:sleep_mode
attr Sun2000 obj-h37000-poll 1
attr Sun2000 obj-h37000-reading ESU1_Status
attr Sun2000 obj-h37000-unpack n
attr Sun2000 obj-h37001-expr $val/1
attr Sun2000 obj-h37001-len 2
attr Sun2000 obj-h37001-poll 1
attr Sun2000 obj-h37001-reading ESU1_Momentanleistung_W
attr Sun2000 obj-h37001-unpack N!
attr Sun2000 obj-h37004-expr $val/10
attr Sun2000 obj-h37004-len 1
attr Sun2000 obj-h37004-poll 1
attr Sun2000 obj-h37004-reading ESU1_SoC
attr Sun2000 obj-h37004-unpack n
attr Sun2000 obj-h37015-expr $val/100
attr Sun2000 obj-h37015-len 2
attr Sun2000 obj-h37015-poll 1
attr Sun2000 obj-h37015-reading ESU1_Energie_Ladung_Tag_kWh
attr Sun2000 obj-h37015-unpack N
attr Sun2000 obj-h37017-expr $val/100
attr Sun2000 obj-h37017-len 2
attr Sun2000 obj-h37017-poll 1
attr Sun2000 obj-h37017-reading ESU1_Energie_Entladung_Tag_kWh
attr Sun2000 obj-h37017-unpack N
attr Sun2000 obj-h370177-expr $val/100
attr Sun2000 obj-h37022-expr $val/10
attr Sun2000 obj-h37022-len 1
attr Sun2000 obj-h37022-poll 1
attr Sun2000 obj-h37022-reading ESU1_Temperatur
attr Sun2000 obj-h37022-unpack n!
attr Sun2000 obj-h37066-expr $val/100
attr Sun2000 obj-h37066-len 2
attr Sun2000 obj-h37066-poll 1
attr Sun2000 obj-h37066-reading ESU1_Gesamtenergie_Ladung_kWh
attr Sun2000 obj-h37066-unpack N
attr Sun2000 obj-h37068-expr $val/100
attr Sun2000 obj-h37068-len 2
attr Sun2000 obj-h37068-poll 1
attr Sun2000 obj-h37068-reading ESU1_Gesamtenergie_Entladung_kWh
attr Sun2000 obj-h37068-unpack N
attr Sun2000 obj-h37100-expr $val/100
attr Sun2000 obj-h37100-len 1
attr Sun2000 obj-h37100-poll 1
attr Sun2000 obj-h37100-reading PM_Meter_Status
attr Sun2000 obj-h37100-unpack n
attr Sun2000 obj-h37101-expr $val/10
attr Sun2000 obj-h37101-len 2
attr Sun2000 obj-h37101-poll 1
attr Sun2000 obj-h37101-reading PM_GridVoltage_A
attr Sun2000 obj-h37101-unpack N!
attr Sun2000 obj-h37103-expr $val/10
attr Sun2000 obj-h37103-len 2
attr Sun2000 obj-h37103-poll 1
attr Sun2000 obj-h37103-reading PM_GridVoltage_B
attr Sun2000 obj-h37103-unpack N!
attr Sun2000 obj-h37105-expr $val/10
attr Sun2000 obj-h37105-len 2
attr Sun2000 obj-h37105-poll 1
attr Sun2000 obj-h37105-reading PM_GridVoltage_C
attr Sun2000 obj-h37105-unpack N!
attr Sun2000 obj-h37107-expr $val/100
attr Sun2000 obj-h37107-len 2
attr Sun2000 obj-h37107-poll 1
attr Sun2000 obj-h37107-reading PM_GridCurrent_A
attr Sun2000 obj-h37107-unpack N!
attr Sun2000 obj-h37109-expr $val/100
attr Sun2000 obj-h37109-len 2
attr Sun2000 obj-h37109-poll 1
attr Sun2000 obj-h37109-reading PM_GridCurrent_B
attr Sun2000 obj-h37109-unpack N!
attr Sun2000 obj-h37111-expr $val/100
attr Sun2000 obj-h37111-len 2
attr Sun2000 obj-h37111-poll 1
attr Sun2000 obj-h37111-reading PM_GridCurrent_C
attr Sun2000 obj-h37111-unpack N!
attr Sun2000 obj-h37113-len 2
attr Sun2000 obj-h37113-poll 1
attr Sun2000 obj-h37113-reading PM_Momentanleistung_W
attr Sun2000 obj-h37113-unpack N!
attr Sun2000 obj-h37119-expr $val/100
attr Sun2000 obj-h37119-len 2
attr Sun2000 obj-h37119-poll 1
attr Sun2000 obj-h37119-reading PM_Einspeisung_kWh
attr Sun2000 obj-h37119-unpack N!
attr Sun2000 obj-h37121-expr $val/100
attr Sun2000 obj-h37121-len 2
attr Sun2000 obj-h37121-poll 1
attr Sun2000 obj-h37121-reading PM_Netzbezug_kWh
attr Sun2000 obj-h37121-unpack N!
attr Sun2000 obj-h37132-len 2
attr Sun2000 obj-h37132-poll 1
attr Sun2000 obj-h37132-reading PM_ActivePower_A
attr Sun2000 obj-h37132-unpack N!
attr Sun2000 obj-h37134-len 2
attr Sun2000 obj-h37134-poll 1
attr Sun2000 obj-h37134-reading PM_ActivePower_B
attr Sun2000 obj-h37134-unpack N!
attr Sun2000 obj-h37136-len 2
attr Sun2000 obj-h37136-poll 1
attr Sun2000 obj-h37136-reading PM_ActivePower_C
attr Sun2000 obj-h37136-unpack N!
attr Sun2000 obj-h37738-expr $val/10
attr Sun2000 obj-h37738-len 1
attr Sun2000 obj-h37738-poll 1
attr Sun2000 obj-h37738-reading ESU2_SoC
attr Sun2000 obj-h37738-unpack n
attr Sun2000 obj-h37741-len 1
attr Sun2000 obj-h37741-map 0:offline, 1:standby, 2:running, 3:fault, 4:sleep_mode
attr Sun2000 obj-h37741-poll 1
attr Sun2000 obj-h37741-reading ESU2_Status
attr Sun2000 obj-h37741-unpack n
attr Sun2000 obj-h37743-expr $val/1
attr Sun2000 obj-h37743-len 2
attr Sun2000 obj-h37743-poll 1
attr Sun2000 obj-h37743-reading ESU2_Momentanleistung_W
attr Sun2000 obj-h37743-unpack N!
attr Sun2000 obj-h37746-expr $val/100
attr Sun2000 obj-h37746-len 2
attr Sun2000 obj-h37746-poll 1
attr Sun2000 obj-h37746-reading ESU2_Energie_Ladung_Tag_kWh
attr Sun2000 obj-h37746-unpack N
attr Sun2000 obj-h37748-expr $val/100
attr Sun2000 obj-h37748-len 2
attr Sun2000 obj-h37748-poll 1
attr Sun2000 obj-h37748-reading ESU2_Energie_Entladung_Tag_kWh
attr Sun2000 obj-h37748-unpack N
attr Sun2000 obj-h37752-expr $val/10
attr Sun2000 obj-h37752-len 1
attr Sun2000 obj-h37752-poll 1
attr Sun2000 obj-h37752-reading ESU2_Temperatur
attr Sun2000 obj-h37752-unpack n!
attr Sun2000 obj-h37753-expr $val/100
attr Sun2000 obj-h37753-len 2
attr Sun2000 obj-h37753-poll 1
attr Sun2000 obj-h37753-reading ESU2_Gesamtenergie_Ladung_kWh
attr Sun2000 obj-h37753-unpack N
attr Sun2000 obj-h37755-expr $val/100
attr Sun2000 obj-h37755-len 2
attr Sun2000 obj-h37755-poll 1
attr Sun2000 obj-h37755-reading ESU2_Gesamtenergie_Entladung_kWh
attr Sun2000 obj-h37755-unpack N
attr Sun2000 obj-h37760-expr $val/10
attr Sun2000 obj-h37760-len 1
attr Sun2000 obj-h37760-poll 1
attr Sun2000 obj-h37760-reading ESS_SoC
attr Sun2000 obj-h37760-unpack n
attr Sun2000 obj-h37762-len 1
attr Sun2000 obj-h37762-map 0:offline, 1:standby, 2:running, 3:fault, 4:sleep_mode
attr Sun2000 obj-h37762-poll 1
attr Sun2000 obj-h37762-reading ESS_Status
attr Sun2000 obj-h37762-unpack n
attr Sun2000 obj-h37784-expr $val/100
attr Sun2000 obj-h37784-len 2
attr Sun2000 obj-h37784-poll 1
attr Sun2000 obj-h37784-reading ESS_Energie_Ladung_Tag_kWh
attr Sun2000 obj-h37784-unpack N
attr Sun2000 obj-h37786-expr $val/100
attr Sun2000 obj-h37786-len 2
attr Sun2000 obj-h37786-poll 1
attr Sun2000 obj-h37786-reading ESS_Energie_Entladung_Tag_kWh
attr Sun2000 obj-h37786-unpack N
attr Sun2000 obj-h47081-expr $val/10
attr Sun2000 obj-h47081-len 1
attr Sun2000 obj-h47081-poll 1
attr Sun2000 obj-h47081-reading ESS_Ladegrenze_Prozent
attr Sun2000 obj-h47081-unpack n
attr Sun2000 obj-h47082-expr $val/10
attr Sun2000 obj-h47082-len 1
attr Sun2000 obj-h47082-poll 1
attr Sun2000 obj-h47082-reading ESS_Entladegrenze_Prozent
attr Sun2000 obj-h47082-unpack n
attr Sun2000 obj-h47415-len 1
attr Sun2000 obj-h47415-map 0:unlimited, 1:DI_active_scheduling, 5:zero_power_grid_connection, 6:power_limited_grid_connection_kw, 7:power_limited_grid_connection_percent
attr Sun2000 obj-h47415-poll 1
attr Sun2000 obj-h47415-reading WR_Modus_Leistungsbegrenzung
attr Sun2000 obj-h47415-unpack n
attr Sun2000 room Wechselrichter
attr Sun2000 stateFormat {sprintf("Status: %s, Temp: %.1f, Aktuell %.1f Watt, Heute gesamt %.2f KWh", ReadingsVal($name,"WR_Device_status",0), ReadingsVal($name,"WR_Internal_temperature",0), ReadingsVal($name,"WR_Momentanleistung_W",0), ReadingsVal($name,"WR_Energie_Tag_kWh",0))}
mit copy/paste die einzeln einzutragen, Zeile für Zeile ist mühsam.
RalfRog
Wenn ich dein Anliegen richtig verstehe kannst alle attr Befehle in die Raw-Definition kopieren und "ausführen".
Siehe https://wiki.fhem.de/wiki/Import_von_Code_Snippets
rhoffm34
Sehr geil, das habe ich gesucht. Danke Ralf.
Viele Grüße,
Ralf
