Keine Updates mehr vom HomeMatic devices
Begonnen von thinman, 19 Oktober 2023, 18:18:50
thinman
Seit einigen Tagen gibt es keine Updates mehr von meine HM Devices.
Nach eine Neustart habe diese Eintrag im Log:
2023.10.19 18:05:19 1: HMCCU [d_ccu] Reading device config from CCU. This may take a couple of seconds ...
2023.10.19 18:05:19 2: HMCCU [d_ccu] Reading device configuration for interfaces BidCos-RF,HmIP-RF
2023.10.19 18:05:49 2: HMCCU [d_ccu] Read descriptions of 160 devices, 435 paramsets, 1 links
2023.10.19 18:05:49 2: HMCCU [d_ccu] Detecting devices of interfaces BidCos-RF,HmIP-RF
2023.10.19 18:05:49 2: HMCCU [d_ccu] Read device configuration in 30.4891729354858 seconds: devices/channels=160 parametersets=435 links=1
2023.10.19 18:05:49 2: HMCCU [d_ccu] RPC device for interface BidCos-RF: d_rpc010040BidCos_RF
2023.10.19 18:05:49 2: HMCCU [d_ccu] RPC device for interface HmIP-RF: d_rpc010040HmIP_RF
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] RPC server process started for interface BidCos-RF with PID=15942
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] Initializing RPC server CB2001010012010040 for interface BidCos-RF
2023.10.19 18:05:49 1: HMCCURPCPROC [d_rpc010040BidCos_RF] RPC server starting
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040HmIP_RF] RPC server process started for interface HmIP-RF with PID=15943
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040HmIP_RF] Initializing RPC server CB2010010012010040 for interface HmIP-RF
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] Callback server CB2001010012010040 created. Listening on port 7411
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] CB2001010012010040 accepting connections. PID=15942
2023.10.19 18:05:49 1: HMCCURPCPROC [d_rpc010040HmIP_RF] RPC server starting
2023.10.19 18:05:49 2: HMCCU [d_ccu] RPC server start: 2 started, 0 already running, 0 failed to start
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] RPC server CB2001010012010040 enters server loop
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] Registering callback http://192.168.10.12:7411/fh2001 of type A with ID CB2001010012010040 at http://192.168.10.40:2001
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040HmIP_RF] Callback server CB2010010012010040 created. Listening on port 7420
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040HmIP_RF] CB2010010012010040 accepting connections. PID=15943
2023.10.19 18:05:49 1: HMCCURPCPROC [d_rpc010040BidCos_RF] RPC server CB2001010012010040 running
2023.10.19 18:05:49 1: HMCCURPCPROC [d_rpc010040BidCos_RF] Scheduled CCU ping every 300 seconds
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040HmIP_RF] RPC server CB2010010012010040 enters server loop
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040HmIP_RF] Registering callback http://192.168.10.12:7420/fh2010 of type A with ID CB2010010012010040 at http://192.168.10.40:2010
2023.10.19 18:05:49 2: HMCCURPCPROC [d_rpc010040BidCos_RF] CB2001010012010040 NewDevice received 72 device and channel specifications
2023.10.19 18:05:49 1: HMCCURPCPROC [d_rpc010040HmIP_RF] RPC server CB2010010012010040 running
2023.10.19 18:05:49 1: HMCCU [d_ccu] All RPC servers running
2023.10.19 18:05:49 2: HMCCU [d_ccu] Updating 11 of 11 client devices matching devexp=.* filter=ccudevstate=active,ccuif=BidCos-RF|HmIP-RF
2023.10.19 18:05:51 2: HMCCURPCPROC [d_rpc010040HmIP_RF] CB2010010012010040 NewDevice received 88 device and channel specifications
2023.10.19 18:05:54 2: HMCCU [d_ccu] Error during CCU request. read from http://192.168.10.40:8181 timed out
Das sind die Internals:
   CCUNum     1
   Clients    :HMCCUDEV:HMCCUCHN:HMCCURPCPROC:
   DEF        192.168.10.40
   FUUID      5cb05790-f33f-0963-3284-3487cf13c8fb0f06
   NAME       d_ccu
   NOTIFYDEV  global
   NR         456
   NTFY_ORDER 50-d_ccu
   RPCState   running
   STATE      running/OK
   TYPE       HMCCU
   authentication off
   ccuaddr    BidCoS-RF
   ccuchannels 148
   ccudevices 12
   ccuif      BidCos-RF
   ccuinterfaces HmIP-RF,VirtualDevices,BidCos-RF
   ccuip      192.168.10.40
   ccuname    HM-RCV-50 BidCoS-RF
   ccustate   active
   ccutype    CCU2/3
   config     5.0
   eventCount 4
   firmware   2.61.7
   host       192.168.10.40
   prot       http
   version    5.0 232691829
Readings:
     2023-10-19 18:05:01   VERSION         2.61.7
     2023-10-19 18:05:01   count_channels  148
     2023-10-19 18:05:01   count_devices   12
     2023-10-19 18:05:01   count_groups    0
     2023-10-19 18:05:01   count_interfaces 3
     2023-10-19 18:05:01   count_programs  16
     2023-10-19 18:05:49   rpcstate        running
     2023-10-19 18:05:49   state           OK
   ccuflags   procrpc
   ccuget     State
   room       HomeMatic
   rpcinterfaces BidCos-RF,HmIP-RF
   rpcserver  on
   stateFormat rpcstate/state
   stripnumber 2
Ich hab keine Ahnung woran der Fehlerhafte Connection (Time Out) liegt. Könnte jemand helfen?
Vielen Dank.
