DBlog errors "DBD::mysql::st execute_array failed:" DBD::mysql::st execute_a
Begonnen von GeZi3560, 21 Januar 2024, 15:59:52
GeZi3560
Help,  ich bekomme diese DBlog Errors ( zum Glück nun bei meinem Testsystem)
Es werden dennoch daten in die DB geschreiben.
Was kann das sein ?
2024.01.21 15:53:21 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5789 generated 24 errors [for Statement "DBD::mysql::st execute_array failed: (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
2024.01.21 15:53:29 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5803 generated 25 errors [for Statement "INSERT INTO history (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
2024.01.21 15:53:38 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5804 generated 25 errors [for Statement "INSERT INTO history (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
2024.01.21 15:53:47 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5805 generated 25 errors [for Statement "INSERT INTO history (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
2024.01.21 15:53:56 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5806 generated 25 errors [for Statement "INSERT INTO history (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
2024.01.21 15:54:05 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5807 generated 25 errors [for Statement "INSERT INTO history (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
2024.01.21 15:54:14 2: logdb - Error table history - DBD::mysql::st execute_array failed: executing 5808 generated 25 errors [for Statement "INSERT INTO history (TIMESTAMP, DEVICE, TYPE, EVENT, READING, VALUE, UNIT) VALUES (?,?,?,?,?,?,?)"] at ./FHEM/93_DbLog.pm line 3238.
Danke und Gruss
Gerd
Raspberry Pi 4 4GB, MariaDB,2 Cul V3 868 ,1 Cul V3, 433, Zwave-USB, Conbee2, DeConz, MAX WT und Ventile,HM, Somfy, Fibaro, Shellys, Tradfri, Lidl Zigbee
Das sind zu wenige Informationen, um Dir wirklich helfen zu können.
Ein Logauszug mit verbose=5 wäre hilfreich, damit man besser erkennen kann, was vor der Ausgabe der Meldung passiert.
GeZi3560
Oh, ich sehe gerade im Reading:
state: Another operation is in progress. Data is stored temporarily.
Mal sehen ob es sich mit der Zeit selbst behebt..
DS_Starter
Also die Logeinträge sagen aus, dass 25 Datensätze nicht in die DB wollen.
Das kann verschiedene Ursachen haben und wie betateilchen schon schrieb sieht man mit verbose 5 deutlich mehr.
Abhängig vom Cache-Stand können aber sehr viele! Logeinträge entstehen.
Ich schlage dir vor folgendes Attr zu setzen:
insertMode = 1
Und wie groß ist der Cache schon? sieht man an den entsprechenden Readings.
Es ist eher unwahrscheinlich dass eine Selbstheilung eintritt.
Wenn verbose 5 wegen zuviel Daten ungünstig erscheint, kannst du noch das Attr
commitMode = ac:on_ta:off
setzen. Allerdings werden dann die problematischen Datensätze verworfen und wir können den Grund dann wohl nicht mehr nachvollziehen.
DS_Starter
Sehe gerade es dürften mehr als 5800 Datensätze sein. Verbose 5 gibt uns dann eine ganze Menge Material!
GeZi3560
Das Problem hat sich von selbst gelöst, es war wohl wirklich so das ein anderer Prozess tätig war.
