HTTPMOD liefert "Müll" statt XML
Begonnen von Kharim, 07 Januar 2024, 13:39:56
Aurel_B
Was passiert bei "attr EPG_Suche bodyDecode utf-8" ?
Kharim
Leider keine Besserung :-(
2024.01.21 12:00:45 5: EPG_Suche: attr EPG_Suche get01URL http://192.168.100.20:8089/api/epg.html?lvl=2&search=Tagesschau
2024.01.21 12:00:45 5: EPG_Suche: UpdateHintList called
2024.01.21 12:00:45 5: EPG_Suche: UpdateHintList: setlist = interval reread:noArg stop:noArg start:noArg clearCookies:noArg upgradeAttributes:noArg storeKeyValue
2024.01.21 12:00:45 5: EPG_Suche: UpdateHintList: getlist = Genial_daneben:noArg
2024.01.21 12:00:53 5: EPG_Suche: get called with Genial_daneben
2024.01.21 12:00:53 5: EPG_Suche: get found option Genial_daneben in attribute get01Name
2024.01.21 12:00:53 4: EPG_Suche: get will now request Genial_daneben, no optional value
2024.01.21 12:00:53 5: EPG_Suche: AddToQueue adds type get01 to URL http://192.168.100.20:8089/api/epg.html?lvl=2&search=Tagesschau, no data, no headers, retry 0, initial queue len: 0
2024.01.21 12:00:53 5: EPG_Suche: HandleSendQueue called from HTTPMOD::AddToSendQueue, qlen = 1
2024.01.21 12:00:53 4: EPG_Suche: HandleSendQueue sends get01 with timeout 2 to http://192.168.100.20:8089/api/epg.html?lvl=2&search=Tagesschau, No Data, No Header
2024.01.21 12:00:53 5: EPG_Suche: ReadCallback called from __ANON__
2024.01.21 12:00:53 4: EPG_Suche: Read callback: request type was get01 retry 0,
header: HTTP/1.0 200 OK
Content-Type: text/xml; charset="utf-8"
Content-Length: 7554
Content-Encoding: deflate, body length 7552
2024.01.21 12:00:53 5: EPG_Suche: Read callback: body
�r�F���S�w���^Y␒␆�␁��:e␟m>6��T�u���␗�␈QX��␖␄�^���␙�U��b�␇�l␒ݖ9␔@�\�d�_`�zfz���s��o�␙�5ɗ�"��␗����%��b�f�?}Q␖�G�␗�g��8:b��eg�_�N�7I�^&�4f?%9��␝␝=;Mn��u��g|���&_L�x>Oز���O_��/=�s�K��w,����Ue�^\�Y������ ␒�SZ�0�OL~M�"�<�B���������♎<_��␓��ӋEV�sτ�zr��S��|�␔Ϫ��?8-�b�,��}�*�&�%<Y������␋��$ˋ<�)�H����� �[|q��␗W�]l␂�x�������ѿ�?�=��4���␅␗�E�'␋x8IJ���bf̜N�"�1������r�.␘���-.�U␒��h흯_�ey���w�OO�ou�␑�����␞␂&<
��,�i�� ␕8`��d␋�6-LK␌L␆���␃,�␕␁,␄�[␃␋<␌,�b��^%��H~+␐��`�P�a�pu��␗y��␖r]�����l���)�·�����=����7M%��␖��␖4␅��␃�h�f�(���b�$h
␞�as�0M7�a�6æ␈␂␌S����`�
␓��z�
�pUZ�̰>␃ |�ɱ�l␋␘5e����a���r�3���EDwi�Z��q)S�7r`]t�␑␑��ܳ d�z c`�^���*�A0}n␃�␞�̀�␎��aJ␒���Y␗sf(]7������,`�;0�ȓ␎��aj␒���I����␋s␎f�0␃␒f`1���␈&vc��a�J�o��H␓��a�~��ݗ�z���J#���U+h(jU*�c_��␂&�X~␓␕��a��U�␐����l␋��)`�"␁@�H/U*��^�␎0J~␓V��qw���E���.)�MX�o��ݥ␖�␗�;�I�o�J~�␂�␋��␑���;LJ~␓V�␔h^␈��\7�����&��7A��:p���ä�7a'� b�␌��#�.`R򛰓�$␒ƕ�9���o���&��7�R9���z7�䷦�IR~�v�B␂@␘��e�␟&%�I;�
����l␋�T␔0e#h�e�a␐9��␝`��&��␅,!��E���.)�M��o(�␟`r^ߔ�`�␎��ߤ�����␁�/�b�����&��M��H␄���?LJ~�v�[H��ҥ2v��ߤ��␖␒c�r��␝���7i'��h�␃`�T���$�7i'�E(�-�␂]�f�␖��i␂3�2␇\␑64��l��g�Ԁ���=,��U�AS����)P�␜␛̶�Q�����␔J␋␇`J;!�␝`�.��t9�ՅT�␒O��.)]NY�r�j␂f��k�␝&��)+]N���Thvu8)g�0)]NY�r�p����u���I�r�J�S␜���4����0)]NY�rU␅␎␄��8v��唕.����␃0��q�?LR�SV��B�<����C�dZ��J�S(�?T��]j��aRiq�*-NI4␅Q��␖86�m␁��7m'�I�e*)��K�␁F�o�N~S(`Q�%�v�]R򛶓�PJ8���Ud�;LR~�v�B�|%��)6��I�o�N~�h�␏C����␁LJ~�v�&����8v��ߴ���vބ0␎�␜�␎`R򛶓�4Z�Pвݘ�w������7��␃`���K���a
��NS�a}�t�5�␆l���5`␑'
l��&c�v���(�\�xv��(��␎&�{�]␞w�V�6�)O␐k��Y��Q�W␇�]��␃I��P␂�5bJ�C��>A���␐�qc�>�����o����B␂ZX␗?␆␐␗␎␙�}̈� yH{��L�>��4%�����䐡�ǚ␄4T�iȱ�i�␔�␆r}�␐F>q�ogq�٧�␄␝␅}u�i|�U�A_���)��4]�y�0��C��M�ST7␝QƲ�h_��)ڨ�␎Ս�A�Ѿ�v␚�k��␂�pt8��m���H�����h���ҡ␌�M�a|%Ϸ|_wv␋#q��˧U`S�7��␏��E�,l���߮g�2�5a?&␗WI␎��'�&��N�I¾��^���'␌��˻�s�c�]����␛�z1�&p␛%����w��Ҍ%�/� ��␘␜`�^]%�x��i���(�,���"␅�e��&k��B\.���?����␋x␔�;��^�␗�"Oc�␒n0�]���̼�iv�n���}<eWEq�|zr��͛c��b␓�␕W���$9Y��,�� ���#��5{ެ>�Ĝ7�P�������/5=��N%����␁����9�H�J�N%��*�+�a$B�j�N�H�RVN�W߫���s��:�&�J[8␕D���f�␞␞8�␚�SqnN8FJ␘��^�ʩ�
��ϬuĹ�[s����>�&�%�);�������2�"+␖�␓6��)�%� ��=��ww����␇]�␟�B����p[�␓�u|���� {␁�psi␌���R�o��no�t�����4=/␘\�,�]␚��g�;��Q`������␝?�y�]ݽ-�`��|B␆�␎��,��N�g.S�ѿ_^��,9z1��␛��d�.������l␂�`o������Ev̞�Å��,���_�ia␚␁4��ю~��␛f␓xCv���
ܫj`p�܈�r�jf�L:��x��U␋�$s���␟�~N���,��^o@�K/␖3��_Sc`hO�շ���͊<��I�6␇����W��␇T�����}␟��␃�U�␖�mrS|0.���␌^Ö␋û��˂�'��M�␔_UM�9X|�_�[���fj���␃ï,^������������Z*�D��AT�ho*ُT#6[+�␌�����Р�w&�*␌�␏�ql�8��2���M�6�␏K�#5��␔N�␖��ٔ�GjZ[��4�x8�t�����IӪ�␗�GjZ[��4-ZVܔ�Gj�]"|c�5�j�j��␈�E�.��k�_k�*B␋�.��1¯w�␞��s␑��␑>2���U\��[��L��g�␈��␈␟�V�c9\��S��L�N�r␑�N␑�o�pl�)��␄i␏wUu1�␓�B[␆����ΘK����1��␟g?��␟'��␂ښ��␏c���ӥZ��l��␓�T�<␕�)w�W�]�T␚%�␎��C?.� ���ޮ��␂N���z;�V�8�d��␝<�e0��n␌孬�c
f␗��6␔␜24�q���ET=fh��'␁m␘��1���#<E���̘����G@�8[b�;�L�>t�����␆��y$C�=šf!x␝�*�{ξˎ�u���r␖��jY␛���̮␋6M�sxSQ�␛�����E��[X=f�)Z��o�␗��Ւ���,WRr�u����mqk␖��Jw��U��j��␕�~�^���␓��
���$Y��¬����x��R�_$���^�mjR␛�����ے��E��f�&'�]����␂n�zVf�$;�wh��␏�r���y�����%Z#�t����O���1@%�4ܪ␌��S�{␌���j��������=�6␈?��L9b�������r5D(���~*��u5���������sD␏\{��L�␂�Ϸ␟�.ߏ�
␆O���>␈흤␙�␇,���*␚��i�W��F�␄w�␙��2�␞���?J���Ou�5��␞�[��␖������m�ݢ-5�L�~�␎��C��l�~��n␑Kͬ��M�#�n��KL�ĺ��(�␏�␔�Z��8�A�4��YR���.jdCc�Y���2�2�����^/�7�ua$Mc�l�␘i��␚�␕{�feQ���k����4O�j��:�w��Y:����␖>��$�'����:7�␇��1��D��_�_����<����L�E'V7�����s4��~�␜'Ƿ;���u�|␅�␝պnr����0␒���yBM�4w|�␜�"��HC���␝�}��*ܨ�#�␞��|xeU␘���|6�␋z␔����␚�n��l�D�l�SLX���c͝␞�r���nK��2�=��N�Nݖ�������ؖ;�␕u[␆H~�O\��P�q)�P␌W?f␒��F�P)��[����\␞��^�'<
��, �␂�A��A�␚�$[��i H�␃␈2p-a{␈���i����␞BPO␘␄␈��S�␎␈B␇�␔04␐S7��!␔␃�<b�␈�p��zF��� B· �N^�ɵ��␚��␑R����*}␖␕M�X>�␁w��!␔(�P��␌C␄!�#7␌u� R��+<����␕  ���6�I�WZ��␐K���␈�-␈ԔƷ���}Ҿ��!F�mA�(�␞�Z@��IXB�␝mV?��*"␆{�{6�=�␐7�␎r��␁��h���␆␐J��E�;*Krp�$ HZ␁B�*�␐�.�␙@�␄�,�;0�����␁�$ m␅�␘�"�Q���␃␔��␂� ��Pz|�pcP7�0␄ �S4��g�␂aVjp8
W�@�hM��␟�bf␗���Ҍ��l␏␈EkJ�]U�␜�* <�S␐��B'���T�UɥAB��␙a%�HT�-P�␏]��␐ B�␑VҌD␇8 q�␂f␇�HiFXI30�ǀ��O␎P␃�(iFXI3dZ��\␗�␌ J�␑vҌ � ␝��e3�(iF�I3�␘�␂q��Z␗�(iF�I3␒��JC|�u���␂��b�C␃!IiF�I3��>�␌�Jg3�(iF�I3��D␘��␎`␘�* =�(␈�fҩ��0��>�=␄J��v�L�␆�␐���␑Ҍ��fP�,⼞���␄��f��4�Rd␁�/�̿␙@�4#���M,�H␄��k␆␐%�H;i&$� �Қ␚␂DI3�N� �1H����QҌ��fP�s␃ȥ55␃ȺR␇␁(BY3�.��+B���␑
W�
!|�␘|�[␂m␆��a��Z␌B
��␂ ��a�␃�␋␔��(+�F��L���␓ζ�@i6�J�Q␞.��␏3������l��f␃�&␅n[s#�H�FYi6����dA;I�␙@�f��4␛ʼn␃␌�t]\3�(�FYi6�`��l$p3�fQ����l���␈��wj␈␐��(+�F���|_�|�fYW␄���؃8D�W 4�N���i␔ʭ
��|�␄�␌ *�F[��(��iS{�␐��� PҌ��f�b�R␈��m␏��f��4���0␓˺�(iF�I3(5␓i�v�6␂��f��4���R� t3�fQҌ��f4�X���␄5␄��f��4��1(r�N
␁��␙m'͠��␐�5���␐ J��vҌ&ί�.ߩ␙@�␇�␐�PR��␏��␕��
␇�␟-'��u��`␋␇��VS
BX␏�␆_��O�/7��W�␆���O��5c+"#��Sv�zR#�R���ɞb�M␐␚�3�X��XI�␓
8V�*�4�␕�{␟�t␕�l�NH�U��qLWQI�ta]7␘rT�U␜�iS)�4���␑]��5ӡ��C␞��␚��5�*�Ç�T␟�X�IĴ��I���␐�?�wb��"��������␓k�␖DlZ���␆␜D␌H��� �=<��;␆$RԬ�jA
9T␙�␒!�:␆)�␃�n>&␕u␓�ԭ␝qT�a␐QL{V�%ZAV�K␃��Vڳ�.Q �*␖Ԇ␝��g�]�����'�␙}�g�]�␌dU=����E␓J*�����X␖␙�������]F␓+���~{�ki��=h�y9�c��␙�c9�0��m\�␙����q�f�6␐xЌ(?�␌␄␎ٌ�␎�␏�␑ij���f�vD�Ȍ␁�␓A��lF�ZC���p3␐����E���t���'lqɮ�8O�i_␖@␞␄��������2␈0�̞␘:␘븅␂3�܌�␓�␎�␈b���␘:␘렋␂3����␓�␎␗ 8�j}�␔W��]�␒␂�9Z␇␖�K�6g�eG��&�y����7./�z�~(��M��␜�T␜����␙���O�(��p␋���<M��`␓x�␛�␅�ti�d�C��z_�u����mq;�'␓���E>��}�␋ӌ�J~+��␗�l�����N'ɂ-␗o�[��e�\&�$a/��WT��6␅K����w��m���Lf3��WW�␜��W�9+�6�ge6M2�mߞ␝��/&嵹�m}�c�if␘␛3�t���5␏��v�:·�␏�#␈�|8�x�|xl>l␝�␓>��a�]*�·����3␘ʇ5��֝l�|xl>l���Jfp��>�Ñ��ƾN-e]�ґ��␆�b�_␗9�=���*O��j%M��I␜�␗X�w)�Cx���? 2T�2s�ߞ�"␚J%.:2�!CU*3Wm�␐mFv5␌␟␎␙�D��jA␆Ր��T�~�(␛␐␙��,����%␙��␄���l=␖��␔/���#�*��a1K��� \�␋��␐;~_Ί2��~�Y�E␕����xq��1�~����f␁Qb�F␛��␜BBvy�{�൙ ␝����woo�%�H�fy����_␄␑�4>�7ߖ9D5U��SQ�8�M����H�ٛ�|�<-V�پq�␏␓��oOfU\␎�X����D�Cs>�8+\�載p>"�Ӌ�<��9߁:� �OX9␟�9�k��␙�|␇�|�$�K+端�␚�k�8␝�|␇�|�<�+a␑�␅x␆␋}g��$�|␇�|�T�k+端Y��A(��9�'����
Wm�␏U�5Χ݄�9ߧ�/ℤ��v���␑1��␚<+�9�a:��␜��␆T@}�9�␟���␄5NR�6�yXO�␁j�Q���␄␙��␔��E���DDg��␆գ�,��␞�$���7␔�� D�z�␘␛��Q2��jC␆�V␔��
�$C�@��r���O��dh�d�EY�jQVq��4:컙B␏g
�ƣ>�`��4␟vL�␝�␗AO␏k␜N�A.(�V�␂�%O�M␞␂躌�u␙�{E)��aU�␃��␅E�K␛:D�␏�]␒�aw␛M8�Oh(�JCQ>␎s��\␒�s�O��&���U�q �c␖(␕�␆Wc�␘ʾgP'c�H�|�3_␅~�dF#�
�'q�|��Hʯg�␇�4F�␚���PҪ��VQE# ␓��\�␁���Ua'�
TcWi��␑{,␙JZ␕vҪD␋E�D"7�9옳ݙ� �Ua'�J4␙R�|5�e<�␌%�
;iU␒����(⺌�8�u 3�1��?�Ⱝ�y'����E␚����{
␖�p�F␏��&���V����ʇ␘�␋�r�s�O�%$�Ui'�*4�
�*␁م��"Chy�NZUh�␁d�␆ɌFZ���*��U��P␛��5�ǐ��Ui'�j��h�O�X2��*��U�␏^␈�&����␌%�J;i␕�␒
BS��Ŝ␇␝s�;␓���*��UTf␈␜ӗ␝�␘>�.��V����j�␙␑�.�u␙�pL����c"��␝��66*�Uڥ�␆(�8�B��;␜v�҄� N�d�y���␑�qD�␓:���1␚�nVw>a�|�␈␂�W簺␘�Qd␄IFYĸ��!�␛$3␚�U�����\Q␕␞�!�␆�e��P(�U�i��� ��Mna␜'␙JsUv�k��N�J;␁�d(�U�i�Q}�␃d�&O�t1g␏c�vg��\���␚�iB�oؕ}y$␙JsUv�kT���fϰ�2\��␈Ǵ> �rL<�␝�␁��ҡ�Ue%�j��␑␁t��6k␟v�ф�Q��*�U{x��␇�['t����]�tVm�Ϊ=4�R&�υ��$Chy�*�U{h�␁d�;�t␗␜�����U��␖␂␎�ܙ��$CI��JZը:␜����8N2�����U����R��%CI��JZը@␐�Qhw��9␏+�lw&�IiU[I�␚�G␂�␌BW��d(i␕�g�x�'f
Q��q]�1�.��V����}�����NFw�Mb�Ԅ�^��␎�@�CJ���횮?�a������l␞�>�|���)␑�uB␝y�?z6��kw��%�3���␂�␖Ɨ����U̒4K�␟�S.�/��t������ �N��������8E�fwo3p��y��␅8�y�L�[p�Wwo�3p|v
&d�8{�����~��>����S���␏����Y�H~I�␂n��jn,[���]��5��,�b␙��d~s���p���␜^c\�u�Og������␝_␗eR9��␁Γiz␎�YZ�-g����
������ח+S���~/|M�,�4�␕�3�,-���g��<␁o�$3��18x�<a�B~�Jhlp;%|���̓I␚C�}^^��2��
-�{��o�␌�>[&��e␗c���␗�␜���am�M/B�␝�am�␁␃2D_ W-��␈W␕4UV␟����J�W␞p_���␒���w��|�v�@�G�?����i
LH␕XW�.���D�'␞p��[aȍ�␇o���FT␘�␝0��ߪ���5
��r}��␓␏�Oܭ�C��␅�������␄�␚�o����71:7�v␝��H�ަ���8:2�m�h␕�n��5hTfB␃����t��␁����^Ԛ��M��^tё␆�]�␆��^��&���P����w�#u␝�␁w�������Pa��^ݪxϖ�j�p␑u�4����␆��C�i��@G"e
�B`�H�35�F�(�5"5�OӮM0␜�йi�㉝$7�g�␏
2024.01.21 12:00:53 4: EPG_Suche: BodyDecode is decoding the response body as utf-8
2024.01.21 12:00:53 5: EPG_Suche: InitParsers: XPath-Strict parsing done.
2024.01.21 12:00:53 5: EPG_Suche: GetCookies is looking for Cookies
2024.01.21 12:00:53 5: EPG_Suche: ExtractSid called, context get, num 01
2024.01.21 12:00:53 4: EPG_Suche: checking for redirects, code=200, ignore=0
2024.01.21 12:00:53 4: EPG_Suche: no redirects to handle
2024.01.21 12:00:53 5: EPG_Suche: Read callback sets LAST_REQUEST to get01
2024.01.21 12:00:53 5: EPG_Suche: CheckAuth decided no authentication required
2024.01.21 12:00:53 5: EPG_Suche: ExtractReading for context get, num 01 - no individual parse definition
2024.01.21 12:00:53 5: EPG_Suche: UpdateReadingList created list of reading.* nums to parse during getUpdate as 01
2024.01.21 12:00:53 5: EPG_Suche: Read starts parsing response to get01 with defined readings: 01
2024.01.21 12:00:53 5: EPG_Suche: ExtractReading reading01 with XPath-Strict /epg[@Ver="1"]//programme[1]@start
2024.01.21 12:00:53 3: EPG_Suche: error in find for XPathStrictNodeset:
not well-formed (invalid token) at line 1, column 0, byte 0:
�r�F���S�w���^Y␒␆�␁��:e␟m>6��T�u���␗�␈QX��␖␄�^���␙�U��b�␇�l␒ݖ9␔@�\�d�_`�zfz���s��o�␙�5ɗ�"��␗���%��b�f�?}Q␖�G�␗�g��8:b��eg�_�N�7I�^&�4f?%9��␝␝=;Mn��u��g|���&_L�x>Oز���O_�/=�s�K��w,����Ue�^\�Y���� ␒�SZ�0�OL~M�"�<�B���������♎<_��␓��ӋEV�sτ�zr��S��|�␔Ϫ��?8-�b�,��}�*�&�%<Y������␋��$ˋ<�)�H����� �[|q��␗W�]l␂�x������ѿ�?�=�4���␅␗�E�'␋x8IJ���bf̜N�"�1������r�.␘��-.�U␒��h흯_�ey���w�OO�ou�␑��␞␂&<
␞�as�0M7�a�6æ␈␂␌S���`�
␓��z�
�pUZ�̰>␃ |�ɱ�l␋␘5e��a���r�3���EDwi�Z��q)S�7r`]t�␑␑��ܳ d�z c`�^���*�A0}n␃�␞�̀�␎��aJ␒���Y␗sf(]7������,`�;0�ȓ␎��aj␒���I����␋s␎f�0␃␒f`1�␈&vc��a�J�o��H␓��a�~��ݗ�z���J#���U+h(jU*�c_��␂&�X~␓␕��a��U�␐���l␋��)`�"␁@�H/U*��^�␎0J~␓V��qw���E���.)�MX�o��ݥ␖�␗�;�I�o�J~�␂�␋��␑���;LJ~␓V�␔h^␈��\7�����&��7A��:p���ä�7a'� b�␌��#�.`R򛰓�$␒ƕ�9���o���&��7�R9���z7�䷦�IR~�v�B␂@␘��e�␟&%�I;�
 at /usr/lib/arm-linux-gnueabihf/perl5/5.28/XML/Parser.pm line 187.
2024.01.21 12:00:53 5: EPG_Suche: ExtractReading reading01 did not match
2024.01.21 12:00:53 4: EPG_Suche: Read response to get01 didn't match any Reading
2024.01.21 12:00:53 5: EPG_Suche: HandleSendQueue called from HTTPMOD::ReadCallback, qlen = 0
2024.01.21 12:00:53 5: EPG_Suche: HandleSendQueue found no usable entry in queue
Raspberry Pi 2 + Minibian + 2x MAX Cube CUN (868/433Mhz) + Thermostate + Fensterkontakte + Taster+RGB-LED Band über pigpiod + TFA Sensoren 30.3169/3125
Raspberry Pi 2 + Minibian +Z-Wave (USB) + Bewegungsmelder + Fensterkontakt + Sirene + SMS Steuer-/Benachrichtigung (ohne Internet)
Aurel_B
Hmmm, da weiss ich auch nicht mehr weiter. Hast du mal den Autor von HTTPMOD kontaktiert?
KyleK
gibt es bei HTTPMod die Möglichkeit, das ergebnis in eine Datei schreiben zu lassen?
dann könntest du uns zumindest mal den Binär-Blob hier hochladen, und wir könnten drauf schauen.
FHEM on Futro S940
CUL868
7x MAX! Thermostat, 8x MAX! Fensterkontakte
Conbee II + deConz, TradFri Lampen, Osram Smart+ Steckdosen
Selbst wenn HTTPMOD das nicht kann, könnte man den content per curl oder wget auf Betriebssystemebene in eine Datei schreiben.
KyleK
Aber mit curl und wget hat er ja augenscheinlich keine Probleme.
Nur HTTPMod mit HTTPMod kommen "seltsame" Daten.
FHEM on Futro S940
CUL868
KyleK
@Kharim
Für mich sieht es tatsächlich so aus, als würde die HTTP-Response von HTTPMod nicht dekodiert, sondern direkt als Binary rausgereicht.
Da ich das mit dem DVBViewer nicht testen kann (es scheint die API ist nur mit der kostenpflichtigen Version verfügbar), kann ich's nicht selbst ausprobieren.
Man könnte versuchen an den relevanten Stellen zur Dekodierung im Source Code das Logging zu erweitern, um mehr Informationen zu bekommen.
FHEM on Futro S940
CUL868
