Was ist hier falsch? condition c02: Argument "" isn't numeric in numeric lt (<)
Begonnen von Invers, 01 Februar 2024, 15:27:24
Invers
Ich finde die Ursache nicht. Das Reading scheint doch zu stimmen. Warum klappt dann der Vergleich nicht.
define DI_TemperaturLog DOIF ([00:00]) \
    ({open (my $DATEI, ">>/opt/fhem/TempLogAussen.txt") or die $!;;\
      print $DATEI ReadingsVal("DI_TemperaturLog","myTime","0")." ". ReadingsVal("DI_TemperaturLog","myTemp","0")."\n";;\
      close ($DATEI);;}\
    (setreading $SELF myTemp 100)\
DOELSEIF ([TMP_Aussen:temterature] < [$SELF:myTemp])\
    ({fhem("setreading $SELF myTemp ". ReadingsVal("TMP_Aussen","temperature","0"))})\
    ({fhem("setreading $SELF myTime ". ReadingsTimestamp("TMP_Aussen","temperature","0"))})\
DOELSE
attr DI_TemperaturLog room 1_TEST
#   DEF        ([00:00])
#    ({open (my $DATEI, ">>/opt/fhem/TempLogAussen.txt") or die $!;
#      print $DATEI ReadingsVal("DI_TemperaturLog","myTime","0")." ". ReadingsVal("DI_TemperaturLog","myTemp","0")."\n";
#      close ($DATEI);}
#    (setreading $SELF myTemp 100)
#DOELSEIF ([TMP_Aussen:temterature] < [$SELF:myTemp])
#    ({fhem("setreading $SELF myTemp ". ReadingsVal("TMP_Aussen","temperature","0"))})
#    ({fhem("setreading $SELF myTime ". ReadingsTimestamp("TMP_Aussen","temperature","0"))})
#DOELSE
#   FUUID      65bba71d-f33f-8098-1b76-d668663d5090733b
#   MODEL      FHEM
#   NAME       DI_TemperaturLog
#   NOTIFYDEV  TMP_Aussen,global,DI_TemperaturLog
#   NR         606
#   NTFY_ORDER 50-DI_TemperaturLog
#   STATE      cmd_1
#   TYPE       DOIF
#   VERSION    27740 2023-07-10 09:31:11
#   eventCount 25
#   READINGS:
#     2024-02-01 15:19:49   cmd             1.2
#     2024-02-01 15:19:49   cmd_event       set_cmd_1
#     2024-02-01 15:19:49   cmd_nr          1
#     2024-02-01 15:19:49   cmd_seqnr       2
#     2024-02-01 15:19:48   e_DI_TemperaturLog_myTemp 100
#     2024-02-01 15:15:47   mode            enabled
#     2024-02-01 15:19:48   myTemp          9.3
#     2024-02-01 15:19:48   myTime          2024-02-01 15:19:22
#     2024-02-01 15:19:49   state           cmd_1
#     2024-02-01 15:15:48   timer_01_c01    02.02.2024 00:00:00
#     2024-02-01 15:19:48   warning         condition c02: Argument "" isn't numeric in numeric lt (<)
#   Regex:
#     accu:
#     bar:
#     barAvg:
#     collect:
#     cond:
#       DI_TemperaturLog:
#         0:
#         1:
#           myTemp     ^DI_TemperaturLog$:^myTemp:
#       TMP_Aussen:
#         1:
#           temterature ^TMP_Aussen$:^temterature:
#   attr:
#     cmdState:
#     wait:
#     waitdel:
#   condition:
#     0          ::DOIF_time_once($hash,0,$wday)
#     1          ::ReadingValDoIf($hash,'TMP_Aussen','temterature') < ::ReadingValDoIf($hash,'DI_TemperaturLog','myTemp')
#   days:
#   do:
#     0:
#       0          {open (my $DATEI, ">>/opt/fhem/TempLogAussen.txt") or die $!;       print $DATEI ReadingsVal("DI_TemperaturLog","myTime","0")." ". ReadingsVal("DI_TemperaturLog","myTemp","0")."\n";       close ($DATEI);}
#       1          setreading DI_TemperaturLog myTemp 100
#     1:
#       0          {fhem("setreading DI_TemperaturLog myTemp ". ReadingsVal("TMP_Aussen","temperature","0"))}
#       1          {fhem("setreading DI_TemperaturLog myTime ". ReadingsTimestamp("TMP_Aussen","temperature","0"))}
#     2:
#       0
#   helper:
#     event      myTemp: 100
#     globalinit 1
#     last_timer 1
#     sleeptimer -1
#     timerdev   DI_TemperaturLog
#     timerevent myTemp: 100
#     triggerDev DI_TemperaturLog
#     timerevents:
#       myTemp: 100
#       e_DI_TemperaturLog_myTemp: 100
#       warning: condition c02: Argument "" isn't numeric in numeric lt (<)
#       myTemp: 9.3
#       cmd_nr: 2
#       cmd_seqnr: 1
#       cmd: 2.1
#       cmd_event: DI_TemperaturLog
#       cmd_2_1
#       myTime: 2024-02-01 15:19:22
#       cmd_nr: 2
#       cmd_seqnr: 2
#       cmd: 2.2
#       cmd_2
#     timereventsState:
#       myTemp: 100
#       myTemp: 9.3
#       cmd_nr: 2
#       cmd_seqnr: 1
#       cmd: 2.1
#       cmd_2_1
#       cmd_nr: 2
#       cmd_seqnr: 2
#       cmd: 2.2
#       cmd_2
#     triggerEvents:
#       myTemp: 100
#       myTemp: 9.3
#       cmd_nr: 2
#       cmd_seqnr: 1
#       cmd: 2.1
#       cmd_2_1
#       cmd_nr: 2
#       cmd_seqnr: 2
#       cmd: 2.2
#       cmd_2
#     triggerEventsState:
#       myTemp: 100
#       myTemp: 9.3
#       cmd_nr: 2
#       cmd_seqnr: 1
#       cmd: 2.1
#       cmd_2_1
#       cmd_nr: 2
#       cmd_seqnr: 2
#       cmd: 2.2
#       cmd_2
#   internals:
#   intervalfunc:
#   localtime:
#     0          1706828400
#   readings:
#     all         TMP_Aussen:temterature DI_TemperaturLog:myTemp
#   realtime:
#     0          00:00:00
#   time:
#     0          00:00:00
#   timeCond:
#     0          0
#   timer:
#     0          0
#   timers:
#     0           0
#   trigger:
#   triggertime:
#     1706828400:
#       localtime  1706828400
#       hash:
#   uiState:
#   uiTable:
setstate DI_TemperaturLog cmd_1
setstate DI_TemperaturLog 2024-02-01 15:19:49 cmd 1.2
setstate DI_TemperaturLog 2024-02-01 15:19:49 cmd_event set_cmd_1
setstate DI_TemperaturLog 2024-02-01 15:19:49 cmd_nr 1
setstate DI_TemperaturLog 2024-02-01 15:19:49 cmd_seqnr 2
setstate DI_TemperaturLog 2024-02-01 15:19:48 e_DI_TemperaturLog_myTemp 100
setstate DI_TemperaturLog 2024-02-01 15:15:47 mode enabled
setstate DI_TemperaturLog 2024-02-01 15:19:48 myTemp 9.3
setstate DI_TemperaturLog 2024-02-01 15:19:48 myTime 2024-02-01 15:19:22
setstate DI_TemperaturLog 2024-02-01 15:19:49 state cmd_1
setstate DI_TemperaturLog 2024-02-01 15:15:48 timer_01_c01 02.02.2024 00:00:00
setstate DI_TemperaturLog 2024-02-01 15:19:48 warning condition c02: Argument "" isn't numeric in numeric lt (<)\
Damian
Du bist sicher, dass der Name richtig ist?
Invers
Mann! Jetzt, wo du es sagst, sehe ich meinen Tippfehler. Ich habe 4 Stunden nach dem Fehler gesucht und alles Geschriebene x-fach verglichen. Trotzdem nicht gesehen. Vielen Dank.
