Diagramm in TabletUI anzeigen
Begonnen von stobor, 23 Dezember 2024, 17:54:29
stobor
ich schreibe die aktuellen Temperatur-Daten in eine Log-Datei:
2024-12-23_17:38:38 HM_TH_Garten 4.8
2024-12-23_17:38:38 HM_TH_Garten TEMPERATURE: 4.8
2024-12-23_17:38:38 HM_TH_Garten measured-temp: 4.8
2024-12-23_17:38:38 HM_TH_Garten devstate: ok
2024-12-23_17:38:38 HM_TH_Garten hmstate: 4.8
2024-12-23_17:38:38 HM_TH_Garten HUMIDITY: 76
2024-12-23_17:38:38 HM_TH_Garten humidity: 76
2024-12-23_17:40:44 HM_TH_Garten 4.8
2024-12-23_17:40:44 HM_TH_Garten TEMPERATURE: 4.8
2024-12-23_17:40:44 HM_TH_Garten measured-temp: 4.8
2024-12-23_17:40:44 HM_TH_Garten devstate: ok
2024-12-23_17:40:44 HM_TH_Garten hmstate: 4.8
2024-12-23_17:40:44 HM_TH_Garten HUMIDITY: 76
2024-12-23_17:40:44 HM_TH_Garten humidity: 76
2024-12-23_17:43:40 HM_TH_Garten 4.8
2024-12-23_17:43:40 HM_TH_Garten TEMPERATURE: 4.8
2024-12-23_17:43:40 HM_TH_Garten measured-temp: 4.8
2024-12-23_17:43:40 HM_TH_Garten devstate: ok
2024-12-23_17:43:40 HM_TH_Garten hmstate: 4.8
2024-12-23_17:43:40 HM_TH_Garten HUMIDITY: 77
2024-12-23_17:43:40 HM_TH_Garten humidity: 77
2024-12-23_17:46:21 HM_TH_Garten 4.7
2024-12-23_17:46:21 HM_TH_Garten TEMPERATURE: 4.7
2024-12-23_17:46:21 HM_TH_Garten measured-temp: 4.7
2024-12-23_17:46:21 HM_TH_Garten devstate: ok
2024-12-23_17:46:21 HM_TH_Garten hmstate: 4.7
2024-12-23_17:46:21 HM_TH_Garten HUMIDITY: 77
2024-12-23_17:46:21 HM_TH_Garten humidity: 77
2024-12-23_17:48:48 HM_TH_Garten 4.7
2024-12-23_17:48:48 HM_TH_Garten TEMPERATURE: 4.7
2024-12-23_17:48:48 HM_TH_Garten measured-temp: 4.7
2024-12-23_17:48:48 HM_TH_Garten devstate: ok
2024-12-23_17:48:48 HM_TH_Garten hmstate: 4.7
2024-12-23_17:48:48 HM_TH_Garten HUMIDITY: 77
2024-12-23_17:48:48 HM_TH_Garten humidity: 77
Ein SVG innerhalb von FHEM zeigt mir auch toll die Graphen:
Leider bekomme ich das nicht im Browser meiner TabletUI Integration hin:
  <div data-type="chart"
data-logdevice='["FileLog_HM_TH_Garten",""]'
data-columnspec='["TEMPERATURE:","HUMIDITY:"]'
data-style='["ftui l2","ftui 16"]'
data-ptype='["lines","lines"]'
data-uaxis='["primary","secondary"]'
data-legend='["Temperatur","Feuchtigkeit"]'
data-yunit="°C"
data-ytext="Temperatur"
data-minvalue="auto"
data-maxvalue="auto"
data-yunit_sec="%"
data-ytext_sec="Feuchtigkeit"
data-height="250"
data-yticks="auto"
data-minvalue_sec="0"
data-maxvalue_sec="100"
data-nofulldays="true"
data-cursorgroup="1"
data-scrollgroup="1"
data-xticks="auto">
</div>
Hat hier vielleicht auch jemand einen Tipp?
Intel NUC (Ubuntu 24.04.4 LTS)  mit CUL V3.2 (FW 1.57 CUL868) für FS20 und CCU3 für HM(IP) + Arduino Mega (Firmata) - FHEM Revision: 31515 - FS20, HM(IP), MQTT, Philips HUE, ModBus
dyna
Moin stobor,
ändere folgende Zeilen
data-logdevice='["FileLog_HM_TH_Garten","FileLog_HM_TH_Garten"]'
data-columnspec='["4:TEMPERATURE","4:HUMIDITY"]'
stobor
Das habe ich probiert:
<header>Außentemperatur</header>
                        data-style='["ftui 12","ftui 16"]'
                        data-yunit="°C"
                        data-yunit_sec="%"
                        data-height="250"
                        data-yticks="auto"
                        data-xticks="auto">
                    </div>
Trotz komplettem Seite-Reload sieht das Diagramm komisch aus:
Hier die LogDatei (HM_TH_Garten-2024-12.log):
2024-12-24_10:57:20 HM_TH_Garten 2.7
2024-12-24_10:57:20 HM_TH_Garten TEMPERATURE: 2.7
2024-12-24_10:57:20 HM_TH_Garten measured-temp: 2.7
2024-12-24_10:57:20 HM_TH_Garten devstate: ok
2024-12-24_10:57:20 HM_TH_Garten hmstate: 2.7
2024-12-24_10:57:20 HM_TH_Garten HUMIDITY: 81
2024-12-24_10:57:20 HM_TH_Garten humidity: 81
2024-12-24_11:00:15 HM_TH_Garten 2.8
2024-12-24_11:00:15 HM_TH_Garten TEMPERATURE: 2.8
2024-12-24_11:00:15 HM_TH_Garten measured-temp: 2.8
2024-12-24_11:00:15 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:00:15 HM_TH_Garten humidity: 80
2024-12-24_11:00:15 HM_TH_Garten devstate: ok
2024-12-24_11:00:15 HM_TH_Garten hmstate: 2.8
2024-12-24_11:02:55 HM_TH_Garten 3.0
2024-12-24_11:02:55 HM_TH_Garten TEMPERATURE: 3.0
2024-12-24_11:02:55 HM_TH_Garten measured-temp: 3.0
2024-12-24_11:02:55 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:02:55 HM_TH_Garten humidity: 80
2024-12-24_11:02:55 HM_TH_Garten devstate: ok
2024-12-24_11:02:55 HM_TH_Garten hmstate: 3.0
2024-12-24_11:05:21 HM_TH_Garten 3.1
2024-12-24_11:05:21 HM_TH_Garten TEMPERATURE: 3.1
2024-12-24_11:05:21 HM_TH_Garten measured-temp: 3.1
2024-12-24_11:05:21 HM_TH_Garten devstate: ok
2024-12-24_11:05:21 HM_TH_Garten hmstate: 3.1
2024-12-24_11:05:21 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:05:21 HM_TH_Garten humidity: 80
2024-12-24_11:07:33 HM_TH_Garten 3.2
2024-12-24_11:07:33 HM_TH_Garten TEMPERATURE: 3.2
2024-12-24_11:07:33 HM_TH_Garten measured-temp: 3.2
2024-12-24_11:07:33 HM_TH_Garten devstate: ok
2024-12-24_11:07:33 HM_TH_Garten hmstate: 3.2
2024-12-24_11:07:33 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:07:33 HM_TH_Garten humidity: 80
2024-12-24_11:10:34 HM_TH_Garten 3.4
2024-12-24_11:10:34 HM_TH_Garten TEMPERATURE: 3.4
2024-12-24_11:10:34 HM_TH_Garten measured-temp: 3.4
2024-12-24_11:10:34 HM_TH_Garten devstate: ok
2024-12-24_11:10:34 HM_TH_Garten hmstate: 3.4
2024-12-24_11:10:34 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:10:34 HM_TH_Garten humidity: 81
2024-12-24_11:13:21 HM_TH_Garten 3.6
2024-12-24_11:13:21 HM_TH_Garten TEMPERATURE: 3.6
2024-12-24_11:13:21 HM_TH_Garten measured-temp: 3.6
2024-12-24_11:13:21 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:13:21 HM_TH_Garten humidity: 81
2024-12-24_11:13:21 HM_TH_Garten devstate: ok
2024-12-24_11:13:21 HM_TH_Garten hmstate: 3.6
2024-12-24_11:15:54 HM_TH_Garten 3.7
2024-12-24_11:15:54 HM_TH_Garten TEMPERATURE: 3.7
2024-12-24_11:15:54 HM_TH_Garten measured-temp: 3.7
2024-12-24_11:15:54 HM_TH_Garten devstate: ok
2024-12-24_11:15:54 HM_TH_Garten hmstate: 3.7
2024-12-24_11:15:54 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:15:54 HM_TH_Garten humidity: 81
2024-12-24_11:18:12 HM_TH_Garten 3.8
2024-12-24_11:18:12 HM_TH_Garten TEMPERATURE: 3.8
2024-12-24_11:18:12 HM_TH_Garten measured-temp: 3.8
2024-12-24_11:18:12 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:18:12 HM_TH_Garten humidity: 81
2024-12-24_11:18:12 HM_TH_Garten devstate: ok
2024-12-24_11:18:12 HM_TH_Garten hmstate: 3.8
2024-12-24_11:20:15 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:20:15 HM_TH_Garten humidity: 81
2024-12-24_11:20:15 HM_TH_Garten 3.9
2024-12-24_11:20:15 HM_TH_Garten TEMPERATURE: 3.9
2024-12-24_11:20:15 HM_TH_Garten measured-temp: 3.9
2024-12-24_11:20:15 HM_TH_Garten devstate: ok
2024-12-24_11:20:15 HM_TH_Garten hmstate: 3.9
2024-12-24_11:23:09 HM_TH_Garten 4.0
2024-12-24_11:23:09 HM_TH_Garten TEMPERATURE: 4.0
2024-12-24_11:23:09 HM_TH_Garten measured-temp: 4.0
2024-12-24_11:23:09 HM_TH_Garten devstate: ok
2024-12-24_11:23:09 HM_TH_Garten hmstate: 4.0
2024-12-24_11:23:09 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:23:09 HM_TH_Garten humidity: 81
2024-12-24_11:25:47 HM_TH_Garten 4.1
2024-12-24_11:25:47 HM_TH_Garten TEMPERATURE: 4.1
2024-12-24_11:25:47 HM_TH_Garten measured-temp: 4.1
2024-12-24_11:25:47 HM_TH_Garten devstate: ok
2024-12-24_11:25:47 HM_TH_Garten hmstate: 4.1
2024-12-24_11:25:47 HM_TH_Garten HUMIDITY: 81
2024-12-24_11:25:47 HM_TH_Garten humidity: 81
2024-12-24_11:28:12 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:28:12 HM_TH_Garten humidity: 80
2024-12-24_11:28:12 HM_TH_Garten 4.2
2024-12-24_11:28:12 HM_TH_Garten TEMPERATURE: 4.2
2024-12-24_11:28:12 HM_TH_Garten measured-temp: 4.2
2024-12-24_11:28:12 HM_TH_Garten devstate: ok
2024-12-24_11:28:12 HM_TH_Garten hmstate: 4.2
2024-12-24_11:30:22 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:30:22 HM_TH_Garten humidity: 80
2024-12-24_11:30:22 HM_TH_Garten 4.2
2024-12-24_11:30:22 HM_TH_Garten TEMPERATURE: 4.2
2024-12-24_11:30:22 HM_TH_Garten measured-temp: 4.2
2024-12-24_11:30:22 HM_TH_Garten devstate: ok
2024-12-24_11:30:22 HM_TH_Garten hmstate: 4.2
2024-12-24_11:33:21 HM_TH_Garten 4.3
2024-12-24_11:33:21 HM_TH_Garten TEMPERATURE: 4.3
2024-12-24_11:33:21 HM_TH_Garten measured-temp: 4.3
2024-12-24_11:33:21 HM_TH_Garten devstate: ok
2024-12-24_11:33:21 HM_TH_Garten hmstate: 4.3
2024-12-24_11:33:21 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:33:21 HM_TH_Garten humidity: 80
2024-12-24_11:36:06 HM_TH_Garten 4.4
2024-12-24_11:36:06 HM_TH_Garten TEMPERATURE: 4.4
2024-12-24_11:36:06 HM_TH_Garten measured-temp: 4.4
2024-12-24_11:36:06 HM_TH_Garten devstate: ok
2024-12-24_11:36:06 HM_TH_Garten hmstate: 4.4
2024-12-24_11:36:06 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:36:06 HM_TH_Garten humidity: 80
2024-12-24_11:38:37 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:38:37 HM_TH_Garten humidity: 80
2024-12-24_11:38:37 HM_TH_Garten 4.5
2024-12-24_11:38:37 HM_TH_Garten TEMPERATURE: 4.5
2024-12-24_11:38:37 HM_TH_Garten measured-temp: 4.5
2024-12-24_11:38:37 HM_TH_Garten devstate: ok
2024-12-24_11:38:37 HM_TH_Garten hmstate: 4.5
2024-12-24_11:40:53 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:40:53 HM_TH_Garten humidity: 80
2024-12-24_11:40:53 HM_TH_Garten 4.6
2024-12-24_11:40:53 HM_TH_Garten TEMPERATURE: 4.6
2024-12-24_11:40:53 HM_TH_Garten measured-temp: 4.6
2024-12-24_11:40:53 HM_TH_Garten devstate: ok
2024-12-24_11:40:53 HM_TH_Garten hmstate: 4.6
2024-12-24_11:42:55 HM_TH_Garten 4.7
2024-12-24_11:42:55 HM_TH_Garten TEMPERATURE: 4.7
2024-12-24_11:42:55 HM_TH_Garten measured-temp: 4.7
2024-12-24_11:42:55 HM_TH_Garten devstate: ok
2024-12-24_11:42:55 HM_TH_Garten hmstate: 4.7
2024-12-24_11:42:55 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:42:55 HM_TH_Garten humidity: 80
2024-12-24_11:45:46 HM_TH_Garten 4.8
2024-12-24_11:45:46 HM_TH_Garten TEMPERATURE: 4.8
2024-12-24_11:45:46 HM_TH_Garten measured-temp: 4.8
2024-12-24_11:45:46 HM_TH_Garten devstate: ok
2024-12-24_11:45:46 HM_TH_Garten hmstate: 4.8
2024-12-24_11:45:46 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:45:46 HM_TH_Garten humidity: 80
2024-12-24_11:48:23 HM_TH_Garten 4.9
2024-12-24_11:48:23 HM_TH_Garten TEMPERATURE: 4.9
2024-12-24_11:48:23 HM_TH_Garten measured-temp: 4.9
2024-12-24_11:48:23 HM_TH_Garten devstate: ok
2024-12-24_11:48:23 HM_TH_Garten hmstate: 4.9
2024-12-24_11:48:23 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:48:23 HM_TH_Garten humidity: 80
2024-12-24_11:50:46 HM_TH_Garten 4.9
2024-12-24_11:50:46 HM_TH_Garten TEMPERATURE: 4.9
2024-12-24_11:50:46 HM_TH_Garten measured-temp: 4.9
2024-12-24_11:50:46 HM_TH_Garten devstate: ok
2024-12-24_11:50:46 HM_TH_Garten hmstate: 4.9
2024-12-24_11:50:46 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:50:46 HM_TH_Garten humidity: 80
2024-12-24_11:52:54 HM_TH_Garten 4.9
2024-12-24_11:52:54 HM_TH_Garten TEMPERATURE: 4.9
2024-12-24_11:52:54 HM_TH_Garten measured-temp: 4.9
2024-12-24_11:52:54 HM_TH_Garten devstate: ok
2024-12-24_11:52:54 HM_TH_Garten hmstate: 4.9
2024-12-24_11:52:54 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:52:54 HM_TH_Garten humidity: 80
2024-12-24_11:55:52 HM_TH_Garten 5.0
2024-12-24_11:55:52 HM_TH_Garten TEMPERATURE: 5.0
2024-12-24_11:55:52 HM_TH_Garten measured-temp: 5.0
2024-12-24_11:55:52 HM_TH_Garten devstate: ok
2024-12-24_11:55:52 HM_TH_Garten hmstate: 5.0
2024-12-24_11:55:52 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:55:52 HM_TH_Garten humidity: 80
2024-12-24_11:58:35 HM_TH_Garten 5.0
2024-12-24_11:58:35 HM_TH_Garten TEMPERATURE: 5.0
2024-12-24_11:58:35 HM_TH_Garten measured-temp: 5.0
2024-12-24_11:58:35 HM_TH_Garten devstate: ok
2024-12-24_11:58:35 HM_TH_Garten hmstate: 5.0
2024-12-24_11:58:35 HM_TH_Garten HUMIDITY: 80
2024-12-24_11:58:35 HM_TH_Garten humidity: 80
2024-12-24_12:01:04 HM_TH_Garten 5.0
2024-12-24_12:01:04 HM_TH_Garten TEMPERATURE: 5.0
2024-12-24_12:01:04 HM_TH_Garten measured-temp: 5.0
2024-12-24_12:01:04 HM_TH_Garten devstate: ok
2024-12-24_12:01:04 HM_TH_Garten hmstate: 5.0
2024-12-24_12:01:04 HM_TH_Garten HUMIDITY: 80
2024-12-24_12:01:04 HM_TH_Garten humidity: 80
2024-12-24_12:03:18 HM_TH_Garten 5.1
2024-12-24_12:03:18 HM_TH_Garten TEMPERATURE: 5.1
2024-12-24_12:03:18 HM_TH_Garten measured-temp: 5.1
2024-12-24_12:03:18 HM_TH_Garten devstate: ok
2024-12-24_12:03:18 HM_TH_Garten hmstate: 5.1
2024-12-24_12:03:18 HM_TH_Garten HUMIDITY: 80
2024-12-24_12:03:18 HM_TH_Garten humidity: 80
2024-12-24_12:05:18 HM_TH_Garten 5.1
2024-12-24_12:05:18 HM_TH_Garten TEMPERATURE: 5.1
2024-12-24_12:05:18 HM_TH_Garten measured-temp: 5.1
2024-12-24_12:05:18 HM_TH_Garten devstate: ok
2024-12-24_12:05:18 HM_TH_Garten hmstate: 5.1
2024-12-24_12:05:18 HM_TH_Garten HUMIDITY: 80
2024-12-24_12:05:18 HM_TH_Garten humidity: 80
2024-12-24_12:08:08 HM_TH_Garten HUMIDITY: 80
2024-12-24_12:08:08 HM_TH_Garten humidity: 80
2024-12-24_12:08:08 HM_TH_Garten 5.2
2024-12-24_12:08:08 HM_TH_Garten TEMPERATURE: 5.2
2024-12-24_12:08:08 HM_TH_Garten measured-temp: 5.2
2024-12-24_12:08:08 HM_TH_Garten devstate: ok
2024-12-24_12:08:08 HM_TH_Garten hmstate: 5.2
2024-12-24_12:10:43 HM_TH_Garten 5.2
2024-12-24_12:10:43 HM_TH_Garten TEMPERATURE: 5.2
2024-12-24_12:10:43 HM_TH_Garten measured-temp: 5.2
2024-12-24_12:10:43 HM_TH_Garten devstate: ok
2024-12-24_12:10:43 HM_TH_Garten hmstate: 5.2
2024-12-24_12:10:43 HM_TH_Garten HUMIDITY: 80
2024-12-24_12:10:43 HM_TH_Garten humidity: 80
2024-12-24_12:15:10 HM_TH_Garten 5.2
2024-12-24_12:15:10 HM_TH_Garten TEMPERATURE: 5.2
2024-12-24_12:15:10 HM_TH_Garten measured-temp: 5.2
2024-12-24_12:15:10 HM_TH_Garten devstate: ok
2024-12-24_12:15:10 HM_TH_Garten hmstate: 5.2
2024-12-24_12:15:10 HM_TH_Garten HUMIDITY: 80
2024-12-24_12:15:10 HM_TH_Garten humidity: 80
Wie sollte ich vorgehen?
dyna
Moin stobor,
das habe ich noch übersehen
es muss data-style='["ftui l2","ftui l6"]' heißen. Hier sind "1" und "l" verwechselt bei Dir.
Jens
stobor
