commandref zu threeStateSensor
Begonnen von betateilchen, 30 Oktober 2013, 21:47:23
falsch:
threeStateSensor
[open|tilted|closed]]
[wet|damp|dry] #HM-SEC-WDS only
cover [open|closed] #HM-SEC-WDS only
alive yes
battery [low|ok]
contact [open|tilted|closed]
contact [wet|damp|dry] #HM-SEC-WDS only
sabotageError [on|off] #HM-SEC-SC and HM-Sec-RHS only
richtig:
threeStateSensor
cover [open|closed] #HM-SEC-WDS and HM-Sec-RHS only
alive yes
battery [low|ok]
LuckyDay
#1
gelöscht
