- some problem starting fhem fixed: the module was responsible for messages like "Use of uninitialized value $arg in string eq at /usr/local/FHEM/bin/fhem.pl line 2311."
Begonnen von System, 03 November 2013, 00:00:29
System
some problem starting fhem fixed: the module was responsible for messages like "Use of uninitialized value $arg in string eq at /usr/local/FHEM/bin/fhem.pl line 2311."View Changes
Source: - some problem starting fhem fixed: the module was responsible for messages like "Use of uninitialized value $arg in string eq at /usr/local/FHEM/bin/fhem.pl line 2311."
