plot bzw log veringern
Begonnen von jostmario, 06 November 2013, 17:10:43
jostmario
mein OWL Strommesser sendet sehr viel Daten.
kann man das irgendwie realisieren das das Log File nicht so groß wird.
evtl nur bei änderung der Ampere Loggen oder nur jede sec.
Zitat2013-11-06_13:10:04 CM160 A: 8.26 A, W: 1899.80 W, C: 57.4879 EUR/h, CO2: 1.1209 kg/h
2013-11-06_13:10:04 CM160 A: 9.45 A, W: 2173.50 W, C: 65.7701 EUR/h, CO2: 1.2824 kg/h
2013-11-06_13:10:04 CM160 A: 9.38 A, W: 2157.40 W, C: 65.2829 EUR/h, CO2: 1.2729 kg/h
2013-11-06_13:10:04 CM160 A: 9.10 A, W: 2093.00 W, C: 63.3342 EUR/h, CO2: 1.2349 kg/h
2013-11-06_13:10:04 CM160 A: 9.17 A, W: 2109.10 W, C: 63.8214 EUR/h, CO2: 1.2444 kg/h
2013-11-06_13:10:04 CM160 A: 9.52 A, W: 2189.60 W, C: 66.2573 EUR/h, CO2: 1.2919 kg/h
2013-11-06_13:10:04 CM160 A: 9.31 A, W: 2141.30 W, C: 64.7957 EUR/h, CO2: 1.2634 kg/h
2013-11-06_13:10:05 CM160 A: 9.38 A, W: 2157.40 W, C: 65.2829 EUR/h, CO2: 1.2729 kg/h
2013-11-06_13:10:05 CM160 A: 9.52 A, W: 2189.60 W, C: 66.2573 EUR/h, CO2: 1.2919 kg/h
2013-11-06_13:10:05 CM160 A: 9.45 A, W: 2173.50 W, C: 65.7701 EUR/h, CO2: 1.2824 kg/h
2013-11-06_13:10:05 CM160 A: 9.80 A, W: 2254.00 W, C: 68.2060 EUR/h, CO2: 1.3299 kg/h
2013-11-06_13:10:05 CM160 A: 12.04 A, W: 2769.20 W, C: 83.7960 EUR/h, CO2: 1.6338 kg/h
2013-11-06_13:10:05 CM160 A: 10.36 A, W: 2382.80 W, C: 72.1035 EUR/h, CO2: 1.4059 kg/h
2013-11-06_13:10:05 CM160 A: 11.27 A, W: 2592.10 W, C: 78.4369 EUR/h, CO2: 1.5293 kg/h
2013-11-06_13:10:05 CM160 A: 0.84 A, W: 193.20 W, C: 5.8462 EUR/h, CO2: 0.1140 kg/h
2013-11-06_13:10:05 CM160 A: 0.91 A, W: 209.30 W, C: 6.3334 EUR/h, CO2: 0.1235 kg/h
2013-11-06_13:10:05 CM160 A: 0.42 A, W: 96.60 W, C: 2.9231 EUR/h, CO2: 0.0570 kg/h
2013-11-06_13:10:06 CM160 A: 0.42 A, W: 96.60 W, C: 2.9231 EUR/h, CO2: 0.0570 kg/h
2013-11-06_13:10:06 CM160 A: 1.19 A, W: 273.70 W, C: 8.2822 EUR/h, CO2: 0.1615 kg/h
2013-11-06_13:10:06 CM160 A: 0.91 A, W: 209.30 W, C: 6.3334 EUR/h, CO2: 0.1235 kg/h
2013-11-06_13:10:06 CM160 A: 1.05 A, W: 241.50 W, C: 7.3078 EUR/h, CO2: 0.1425 kg/h
2013-11-06_13:10:06 CM160 A: 1.40 A, W: 322.00 W, C: 9.7437 EUR/h, CO2: 0.1900 kg/h
Gruß Josty
Raspberry Pi  ---  HM-LAN ---  8X HM_HM_CC_RT_DN --- OWL+USB Strommesser    UVR1611
Puschel74
siehe event-on-change-reading bzw. event-on-update-reading
Was die Einträge aber wohl nur auf einen pro Sekunde reduzieren würde.
