Verständnissfrage zu HM-Sec-SC und HM-CC-RT-DN
Begonnen von MartinD, 08 Dezember 2013, 12:15:51
MartinD
ich habe:
HM-CC-RT-DN -> Thermostat_Kueche -> CUL_HM_HM_CC_RT_DN_21F22A_WindowRec
HM-Sec-SC -> Fenster_Kontakt_Kueche
list CUL_HM_HM_CC_RT_DN_21F22A_WindowRec
   DEF        21F22A03
   NAME       CUL_HM_HM_CC_RT_DN_21F22A_WindowRec
   NR         118
   STATE      last:Fenster_Kontakt_Kueche :closed
   TYPE       CUL_HM
   chanNo     03
   device     Thermostat_Kueche
   peerList   Fenster_Kontakt_Kueche,
   Readings:
     2013-12-08 11:31:14   R-Fenster_Kontakt_Kueche_chn-01-shCtValLo 50
     2013-12-08 11:31:15   R-Fenster_Kontakt_Kueche_chn-01-winOpnTemp 8 C
     2013-12-08 11:31:14   R-sign          off
     2013-12-08 11:31:13   peerList        Fenster_Kontakt_Kueche,
     2013-12-08 11:47:25   trigLast        Fenster_Kontakt_Kueche :closed
     2013-12-08 11:47:25   trig_Fenster_Kontakt_Kueche closed
     2013-12-08 00:57:08   winOpnBoost     off
     2013-12-08 00:57:08   winOpnDetFall   1.4 K
     2013-12-08 00:57:08   winOpnMode      off
     2013-12-08 00:57:08   winOpnPeriod    15 min
     2013-12-08 00:57:08   winOpnTemp-int  10 C
   Helper:
     peerIDsRaw ,2229F601,00000000
     Role:
       chn        1
     Shadowreg:
   alias      Kueche_HM_CC_RT_DN_21F22A_WindowRec
   expert     1
   model      HM-CC-RT-DN
   peerIDs    00000000,2229F601,
   room       System
   stateFormat last:trigLast
list Fenster_Kontakt_Kueche
   DEF        2229F6
   EVENTS     6
   HMLAN1_MSGCNT 7
   HMLAN1_RAWMSG E2229F6,0000,02BFFEDE,FF,FFAE,71A4412229F623A755016A00
   HMLAN1_RSSI -82
   HMLAN1_TIME 2013-12-08 11:47:25
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     7
   NAME       Fenster_Kontakt_Kueche
   NR         206
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:71 - t:41 s:2229F6 d:23A755 016A00
   peerList   CUL_HM_HM_CC_RT_DN_21F22A_WindowRec,
   protLastRcv 2013-12-08 11:47:25
   protSnd    6 last_at:2013-12-08 11:47:25
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-81.71 min:-83 max:-81 lst:-82 cnt:7
   Readings:
     2013-12-08 08:32:57   Activity        alive
     2013-12-08 00:24:23   CommandAccepted yes
     2013-12-08 00:24:24   PairedTo        0x23A755
     2013-11-30 21:22:51   R-CUL_HM_HM_CC_RT_DN_21F22A_WindowRec-expectAES set_off
     2013-11-30 21:22:51   R-CUL_HM_HM_CC_RT_DN_21F22A_WindowRec-peerNeedsBurst set_on
     2013-12-08 00:24:24   R-cyclicInfoMsg off
     2013-11-30 20:51:15   R-eventDlyTime  0 s
     2013-11-30 20:51:15   R-ledOnTime     0.5 s
     2013-12-08 00:24:24   R-msgScPosA     closed
     2013-12-08 00:24:24   R-msgScPosB     open
     2013-12-08 00:24:24   R-pairCentral   0x23A755
     2013-12-08 00:24:24   R-sabotageMsg   on
     2013-12-08 00:24:24   R-transmDevTryMax 6
     2013-12-08 00:24:24   R-transmitTryMax 6
     2013-12-08 00:24:24   RegL_00:        02:01 09:00 0A:23 0B:A7 0C:55 10:01 14:06 00:00
     2013-12-08 00:24:24   RegL_01:        08:00 20:60 21:00 22:64 30:06 00:00
     2013-12-08 08:32:25   aesKeyNbr       FF
     2013-12-08 00:24:40   alive           yes
     2013-12-08 00:24:40   battery         ok
     2013-12-08 11:47:25   contact         closed (to HMLAN1)
     2013-12-08 01:32:57   peerList        CUL_HM_HM_CC_RT_DN_21F22A_WindowRec,
     2013-12-08 00:24:40   sabotageError   off
     2013-12-08 11:47:25   state           closed
   Helper:
     mId        002F
     rxType     4
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_hmlan1:
         avg        -81.7142857142857
         cnt        7
         lst        -82
         max        -81
         min        -83
   actCycle   028:00
   actStatus  alive
   alias      Küche Fenster R
   autoReadReg 4_reqStatus
   comment    Ürsprünglicher alias: Küche_Fenster_R_HM_SEC_SC_2229F6; Ursprünglicher Name: CUL_HM_HM_SEC_SC_2229F6
   devStateIcon .*open:signal_Fenster_Offen.on .*closed:signal_Fenster_Offen.off
   expert     2_full
   firmware   2.1
   fp_Grundriss_DGH 191,1117,1,Fenster ist
   icon       fts_window_1w_open
   model      HM-SEC-SC
   peerIDs    00000000,21F22A03,
   room       Küche
   serialNr   KEQ0530378
   subType    threeStateSensor
Nun die Frage:
Wird das Ventil am HM-CC-RT-DN geschlossen  sobald HM-SEC-SC den Status open hat.?
peterk_de
Also theoretisch ja - sobald du das Fenster auf machst, solltest du im Thermostaten ein kleines, stilisiertes Fenster sehen - das passiert quasi sofort. Schließen des Ventils dauert dann noch eine Weile.
Dass das bei dir nicht passiert, darauf deutet folgendes hin:
Da sollte stehen:
contact closed (to kueche.thermostat)
(so sieht es bei mir aus).
Könnte also sein, dass mit dem Peering noch etwas nicht stimmt. Ich würde dann noch einmal neu peeren (immer schön alle an ihn gesendeten Kommandos mit dem Knopf am Fensterkontakt bestätigen) und dann noch einmal den Fensterkontakt mit getconfig neu auslesen (auch wieder Knopf drücken).
FHEM auf Ubuntu-VM / 2xNUC Proxmox Cluster
UI: HomeKit, TabletUI, Grafana
IOdevs: 2xHueBridge, RaspiMatic-CCU, CUL868, 2xHarmonyHub, 6xRaspi-Roomnode mit CO2, VOC und lepresenced
Devices: 107xHomematic(IP), 96xPhilips Hue, 17xTECHEM, 12xBTLE, 8xSONOS, 2xHomeConnect, 1xShelly 3em, 1xNanoleaf ...
MartinD
