[gelöst] HM-RC-12 mit HM-LC-Bl1PBU-FM peeren; Ich blicks doch nicht?
Begonnen von habichthugo, 14 Dezember 2013, 22:08:22
habichthugo
So sieht meine fhem.cfg für die beiden Devices aus, die ich peeren möchte:
define HM_Rol_Wohnzimmer_Fenster_rechts CUL_HM 23AC37
attr HM_Rol_Wohnzimmer_Fenster_rechts .devInfo 010100
attr HM_Rol_Wohnzimmer_Fenster_rechts .stc 30
attr HM_Rol_Wohnzimmer_Fenster_rechts expert 2_full
attr HM_Rol_Wohnzimmer_Fenster_rechts firmware 2.2
attr HM_Rol_Wohnzimmer_Fenster_rechts model HM-LC-Bl1PBU-FM
attr HM_Rol_Wohnzimmer_Fenster_rechts peerIDs
attr HM_Rol_Wohnzimmer_Fenster_rechts room CUL_HM
attr HM_Rol_Wohnzimmer_Fenster_rechts serialNr KEQ0812827
attr HM_Rol_Wohnzimmer_Fenster_rechts subType blindActuator
attr HM_Rol_Wohnzimmer_Fenster_rechts webCmd toggle:on:off:up:down:stop:statusRequest
define HM_RC_12 CUL_HM 1E52B0
attr HM_RC_12 .devInfo 0C0000
attr HM_RC_12 .stc 40
attr HM_RC_12 expert 2_full
attr HM_RC_12 firmware 1.1
attr HM_RC_12 model HM-RC-12
attr HM_RC_12 peerIDs
attr HM_RC_12 room CUL_HM
attr HM_RC_12 serialNr JEQ0735285
attr HM_RC_12 subType remote
attr HM_RC_12 webCmd getConfig
define HM_RC_12_Btn_01 CUL_HM 1E52B001
attr HM_RC_12_Btn_01 model HM-RC-12
attr HM_RC_12_Btn_01 peerIDs 00000000,
attr HM_RC_12_Btn_01 room CUL_HM
define HM_RC_12_Btn_02 CUL_HM 1E52B002
attr HM_RC_12_Btn_02 model HM-RC-12
attr HM_RC_12_Btn_02 peerIDs 00000000,
attr HM_RC_12_Btn_02 room CUL_HM
define HM_RC_12_Btn_03 CUL_HM 1E52B003
attr HM_RC_12_Btn_03 model HM-RC-12
attr HM_RC_12_Btn_03 peerIDs 00000000,
attr HM_RC_12_Btn_03 room CUL_HM
define HM_RC_12_Btn_04 CUL_HM 1E52B004
attr HM_RC_12_Btn_04 model HM-RC-12
attr HM_RC_12_Btn_04 peerIDs 00000000,
attr HM_RC_12_Btn_04 room CUL_HM
define HM_RC_12_Btn_05 CUL_HM 1E52B005
attr HM_RC_12_Btn_05 model HM-RC-12
attr HM_RC_12_Btn_05 peerIDs 00000000,
attr HM_RC_12_Btn_05 room CUL_HM
define HM_RC_12_Btn_06 CUL_HM 1E52B006
attr HM_RC_12_Btn_06 model HM-RC-12
attr HM_RC_12_Btn_06 peerIDs 00000000,
attr HM_RC_12_Btn_06 room CUL_HM
define HM_RC_12_Btn_07 CUL_HM 1E52B007
attr HM_RC_12_Btn_07 model HM-RC-12
attr HM_RC_12_Btn_07 peerIDs 00000000,
attr HM_RC_12_Btn_07 room CUL_HM
define HM_RC_12_Btn_08 CUL_HM 1E52B008
attr HM_RC_12_Btn_08 model HM-RC-12
attr HM_RC_12_Btn_08 peerIDs 00000000,
attr HM_RC_12_Btn_08 room CUL_HM
define HM_RC_12_Btn_09 CUL_HM 1E52B009
attr HM_RC_12_Btn_09 model HM-RC-12
attr HM_RC_12_Btn_09 peerIDs 00000000,
attr HM_RC_12_Btn_09 room CUL_HM
define HM_RC_12_Btn_10 CUL_HM 1E52B00A
attr HM_RC_12_Btn_10 model HM-RC-12
attr HM_RC_12_Btn_10 peerIDs 00000000,
attr HM_RC_12_Btn_10 room CUL_HM
define HM_RC_12_Btn_11 CUL_HM 1E52B00B
attr HM_RC_12_Btn_11 model HM-RC-12
attr HM_RC_12_Btn_11 peerIDs 00000000,
attr HM_RC_12_Btn_11 room CUL_HM
define HM_RC_12_Btn_12 CUL_HM 1E52B00C
attr HM_RC_12_Btn_12 model HM-RC-12
attr HM_RC_12_Btn_12 peerIDs 00000000,
attr HM_RC_12_Btn_12 room CUL_HM
Was genau muss ich nun tun, um die ersten beiden Buttons meiner 'HM_RC_12' mit meinem 'HM_Rol_Wohnzimmer_Fenster_rechts' so zu peeren, dass sie als Hoch- bzw. Runter Tasten funktionieren?
Bitte, bitte: Ich brauchs offenbar für Blöde, also möglichst genau mit meinen Bezeichnern.
CUL (CC1101-USB-Lite module-V3) + 4*fht80b; SIGNALduino + x Funksteckd.; HM-LGW-O-TW-W-EU + 11*HM-LC-Bl1PBU-FM Rollladenaktor + 1*HM-LC-Sw1PBU-FM Lichtschalter + 2*HM-RC-12-W + 3* HM-CC-RT-DN Heizkörpertherm. + 2*HM-TC-IT-WM-W-EU Wandtherm.; HM-MOD-RPI-PCB Funkmodul; Pi OS Lite 64 (Bookworm); Pi 3B+
martinp876
Hallo habichthugo,
du hast sicher einmal das doc überflogen
http://forum.fhem.de/index.php?action=dlattach;topic=16563.0;attach=8796
noch einmal zum peeren
- das kommando geht immer vom Sensor/Button aus. Der steht also immer "forne", der Aktor hinten
- das Kommando schreibt in beide devices, den Sensor UND des Aktor
- die Option single|dual solltest du auf dual setzen,also 2 buttons
set HM_RC_12_Btn_01 peerChan 0 HM_Rol_Wohnzimmer_Fenster_rechts
dual, set, both sind default.
das kommando zum BL1PBU wird sofort ausgeführt, da er immer auf Empfang ist.
Das kommando zur RC12 wird erst ausgeführt, wenn du anlernen drückst.
Gruss Martin
habichthugo
Ja, aber wohl eher zu flüchtig. War jetzt zu sehr mit der (Hardware-) Umrüstung der Altbaurolläden beschäftigt. Ufff. Wollte einfach fertig werden...
Danke, für die konkrete Antwort. Das hat mir sehr geholfen!
