i2c-1 Problem (fast gelöst durch Neuinstallation) Kann auch gelöscht werden
Begonnen von stgeran, 30 Juli 2016, 18:10:59
stgeran
Ich habe folgendes im logfile
2016.07.30 17:53:07 1: define Display FRAMEBUFFER /dev/fb1: /dev/fb1 isn't readable and writable
2016.07.30 17:53:07 1: Including ./log/fhem.save
2016.07.30 17:53:07 1: configfile: 0
I2C: Error! I2C device not readable: /dev/i2c-1. Please install wiringpi or change access rights for fhem user
Luminosity: unknown IODev specified
Unknown command system("/usr/local/bin/gpio, try help.
2016.07.30 17:53:07 3: No I/O device found for Luminosity
2016.07.30 17:53:09 1: OWX: 1-Wire bus OWio: interface DS2482 / COC detected in CUL868 with response OK
V 1.61 RPIAddOn_CSM
2016.07.30 17:53:09 1: usb create starting
2016.07.30 17:53:10 1: usb create end
2016.07.30 17:53:10 2: Error messages while initializing FHEM: configfile: 0 I2C: Error! I2C device not readable: /dev/i2c-1. Please install wiringpi or change access rights for fhem user Luminosity: unknown IODev specified /dev/fb1 isn't readable and writable /dev/fb1 isn't readable and writable Unknown command system("/usr/local/bin/gpio, try help.
2016.07.30 17:53:10 0: Featurelevel: 5.7
2016.07.30 17:53:10 0: Server started with 20 defined entities (version $Id: fhem.pl 9893 2015-11-15 08:43:05Z rudolfkoenig $, os linux, user fhem, pid 646)
2016.07.30 17:53:10 1: Pressure: Can't call method "bus_read" on an undefined value
2016.07.30 17:53:10 1: Luminosity: no IODev assigned to 'Luminosity'
2016.07.30 17:53:10 1: PERL WARNING: Use of uninitialized value in multiplication (*) at ./FHEM/51_I2C_TSL2561.pm line 574.
2016.07.30 17:53:10 1: PERL WARNING: Use of uninitialized value in multiplication (*) at ./FHEM/51_I2C_TSL2561.pm line 575.
2016.07.30 17:53:23 1: OWX: No answer to CUL868 device search
2016.07.30 17:53:23 1: OWX: 1-Wire devices found on bus OWio ()
ich bin nach der Kurzanleitung für das addonboard von locutus vorgegangen.
ich habe kein /dev/fb1 nur ein /dev/fb0
wiringpi ist nach der Anleitung installiert muss ich jetzt noch per Hand die Rechte ändern?
2. Problem
sudo crontab -e
gibt folgende Meldung
no crontab for root - using an empty one
888
ich kann dann nichts eingeben und komme aus diesem Zustand nicht mehr heraus.
Nur Versorgungsspannung weg hilft da.
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
