(gelöst) Warnmeldungen beim FHEM Restart
Begonnen von P.A.Trick, 31 Januar 2015, 13:04:25
P.A.Trick
Hallo Zusammen,
ich bekomme beim Neustart noch einige Warnhinweise von fhemweb?
2015.01.31 13:01:34.692 1: Perfmon: possible freeze starting at 13:01:32, delay is 2.691
2015.01.31 13:01:34.404 3:     main::CallFn                        called by fhem.pl (608)
2015.01.31 13:01:34.403 3:     main::FBAHA_Read                    called by fhem.pl (2960)
2015.01.31 13:01:34.403 3:     main::Dispatch                      called by ./FHEM/00_FBAHA.pm (289)
2015.01.31 13:01:34.402 3:     main::DoTrigger                     called by fhem.pl (3176)
2015.01.31 13:01:34.401 3:     main::CallFn                        called by fhem.pl (2883)
2015.01.31 13:01:34.401 3:     main::LightScene_Notify             called by fhem.pl (2960)
2015.01.31 13:01:34.400 3:     main::FW_devState                   called by ./FHEM/31_LightScene.pm (276)
2015.01.31 13:01:34.399 3:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (2442)
2015.01.31 13:01:34.399 3: stacktrace:
2015.01.31 13:01:34.398 1: PERL WARNING: Use of uninitialized value $FW_CSRF in concatenation (.) or string at ./FHEM/01_FHEMWEB.pm line 2442.
2015.01.31 13:01:34.397 3:     main::CallFn                        called by fhem.pl (608)
2015.01.31 13:01:34.397 3:     main::FBAHA_Read                    called by fhem.pl (2960)
2015.01.31 13:01:34.396 3:     main::Dispatch                      called by ./FHEM/00_FBAHA.pm (289)
2015.01.31 13:01:34.396 3:     main::DoTrigger                     called by fhem.pl (3176)
2015.01.31 13:01:34.395 3:     main::CallFn                        called by fhem.pl (2883)
2015.01.31 13:01:34.395 3:     main::LightScene_Notify             called by fhem.pl (2960)
2015.01.31 13:01:34.394 3:     main::FW_devState                   called by ./FHEM/31_LightScene.pm (276)
2015.01.31 13:01:34.394 3:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (2442)
2015.01.31 13:01:34.393 3: stacktrace:
2015.01.31 13:01:34.393 1: PERL WARNING: Use of uninitialized value $FW_subdir in concatenation (.) or string at ./FHEM/01_FHEMWEB.pm line 2442.
2015.01.31 13:01:34.392 3:     main::CallFn                        called by fhem.pl (608)
2015.01.31 13:01:34.391 3:     main::FBAHA_Read                    called by fhem.pl (2960)
2015.01.31 13:01:34.391 3:     main::Dispatch                      called by ./FHEM/00_FBAHA.pm (289)
2015.01.31 13:01:34.390 3:     main::DoTrigger                     called by fhem.pl (3176)
2015.01.31 13:01:34.390 3:     main::CallFn                        called by fhem.pl (2883)
2015.01.31 13:01:34.389 3:     main::LightScene_Notify             called by fhem.pl (2960)
2015.01.31 13:01:34.389 3:     main::FW_devState                   called by ./FHEM/31_LightScene.pm (276)
2015.01.31 13:01:34.388 3:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (2442)
2015.01.31 13:01:34.387 3: stacktrace:
2015.01.31 13:01:34.387 1: PERL WARNING: Use of uninitialized value $FW_ME in concatenation (.) or string at ./FHEM/01_FHEMWEB.pm line 2442.
2015.01.31 13:01:32.016 3: CUL_HM set DG.JZ.Deckenleuchte statusRequest
Funktion ist aber gegeben!
FHEM + Homeassistant - meine HW -> https://www.trinityonline.de/hardware/
LightScene ist uebermotiviert, und versucht deviceStati an Frontends zu melden, bevor diese Frontends mit FHEM sich verbunden haben.
P.A.Trick
Ah ok, dann ist das etwas für Andre, oder?
Danke im Voraus für deine Hilfe!
Patrick
justme1968
LightScene ruft FW_devState auf um das icon für den aktuellen device state zu bekommen. ohne weiter etwas damit zu tun.
ich hab eben eine version eingecheckt die das nur noch macht wenn die LightScene auch sichtbar ist. das sollte helfen.
ob man das nicht auch in FW_devState abfangen sollte ist eine andere diskussion :)
  andre
P.A.Trick
Danke Andre, ich werde morgen berichten!
P.A.Trick
Der Patch funktioniert einwandfrei! Danke Andre und Rudolf!
