Warnungen beim Aufwecklicht
Begonnen von P.A.Trick, 03 Februar 2015, 13:49:26
P.A.Trick
Ich benutze einen Homematic Dimmaktor um ein Aufwachlicht zu realisieren.
Das Kommando welches ich benutze ich das folgende:
set OG.SZ.Deckenleuchte pct 100 2400 600
Das funktioniert auch soweit, allerdings finde ich im Logfile folgende Warnungen:
2015.02.03 13:44:56.216 1: PERL WARNING: Argument "set_100" isn't numeric in numeric eq (==) at (eval 2800) line 1.
2015.02.03 13:44:56.217 3: stacktrace:
2015.02.03 13:44:56.218 3:     main::__ANON__                      called by (eval 2800) (1)
2015.02.03 13:44:56.219 3:     (eval)                              called by fhem.pl (3550)
2015.02.03 13:44:56.220 3:     main::evalStateFormat               called by fhem.pl (3638)
2015.02.03 13:44:56.221 3:     main::readingsEndUpdate             called by fhem.pl (3801)
2015.02.03 13:44:56.221 3:     main::readingsSingleUpdate          called by ./FHEM/10_CUL_HM.pm (6948)
2015.02.03 13:44:56.222 3:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (3799)
2015.02.03 13:44:56.223 3:     main::CUL_HM_Set                    called by fhem.pl (2959)
2015.02.03 13:44:56.224 3:     main::CallFn                        called by fhem.pl (1467)
2015.02.03 13:44:56.225 3:     main::DoSet                         called by fhem.pl (1497)
2015.02.03 13:44:56.226 3:     main::CommandSet                    called by fhem.pl (989)
2015.02.03 13:44:56.227 3:     main::AnalyzeCommand                called by fhem.pl (868)
2015.02.03 13:44:56.228 3:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (1989)
2015.02.03 13:44:56.228 3:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (654)
2015.02.03 13:44:56.229 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (423)
2015.02.03 13:44:56.230 3:     main::FW_Read                       called by fhem.pl (2964)
2015.02.03 13:44:56.231 3:     main::CallFn                        called by fhem.pl (608)
2015.02.03 13:44:56.273 1: PERL WARNING: Argument "set_100" isn't numeric in numeric eq (==) at (eval 2801) line 1.
2015.02.03 13:44:56.274 3: stacktrace:
2015.02.03 13:44:56.275 3:     main::__ANON__                      called by (eval 2801) (1)
2015.02.03 13:44:56.276 3:     (eval)                              called by fhem.pl (3550)
2015.02.03 13:44:56.277 3:     main::evalStateFormat               called by fhem.pl (3638)
2015.02.03 13:44:56.278 3:     main::readingsEndUpdate             called by fhem.pl (3801)
2015.02.03 13:44:56.279 3:     main::readingsSingleUpdate          called by ./FHEM/10_CUL_HM.pm (6948)
2015.02.03 13:44:56.280 3:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (4823)
2015.02.03 13:44:56.280 3:     main::CUL_HM_Set                    called by fhem.pl (2959)
2015.02.03 13:44:56.281 3:     main::CallFn                        called by fhem.pl (1467)
2015.02.03 13:44:56.282 3:     main::DoSet                         called by fhem.pl (1497)
2015.02.03 13:44:56.283 3:     main::CommandSet                    called by fhem.pl (989)
2015.02.03 13:44:56.284 3:     main::AnalyzeCommand                called by fhem.pl (868)
2015.02.03 13:44:56.285 3:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (1989)
2015.02.03 13:44:56.285 3:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (654)
2015.02.03 13:44:56.286 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (423)
2015.02.03 13:44:56.287 3:     main::FW_Read                       called by fhem.pl (2964)
2015.02.03 13:44:56.288 3:     main::CallFn                        called by fhem.pl (608)
2015.02.03 13:44:56.329 3: CUL_HM set OG.SZ.Deckenleuchte pct 100 2400 600
2015.02.03 13:44:56.630 1: PERL WARNING: Argument "set_100" isn't numeric in numeric eq (==) at (eval 2802) line 1.
2015.02.03 13:44:56.631 3: stacktrace:
2015.02.03 13:44:56.632 3:     main::__ANON__                      called by (eval 2802) (1)
2015.02.03 13:44:56.632 3:     (eval)                              called by fhem.pl (3550)
2015.02.03 13:44:56.633 3:     main::evalStateFormat               called by fhem.pl (3638)
2015.02.03 13:44:56.633 3:     main::readingsEndUpdate             called by ./FHEM/10_CUL_HM.pm (6938)
2015.02.03 13:44:56.634 3:     main::CUL_HM_UpdtReadBulk           called by ./FHEM/10_CUL_HM.pm (2917)
2015.02.03 13:44:56.635 3:     main::CUL_HM_pushEvnts              called by ./FHEM/10_CUL_HM.pm (2351)
2015.02.03 13:44:56.635 3:     main::CUL_HM_Parse                  called by fhem.pl (3101)
2015.02.03 13:44:56.635 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (711)
2015.02.03 13:44:56.636 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (523)
2015.02.03 13:44:56.636 3:     main::HMLAN_Read                    called by fhem.pl (2964)
2015.02.03 13:44:56.636 3:     main::CallFn                        called by fhem.pl (608)
Mache ich etwas falsch oder sind die Warnungen ein Bug?
Vielen lieben Dank im Voraus!
Patrick
vbs
Interessanterweise habe ich seit gestern auch Probleme in der Art. Dachte eigentlich, dass es an mir liegt, aber vlt. doch eher generell:
2015.02.03 18:09:33 3: CUL_HM set fl_lightChain statusRequest
2015.02.03 18:09:34 3: CUL_HM set wz_lightCrystal statusRequest
2015.02.03 18:09:36 3: CUL_HM set wz_lightDesk statusRequest
2015.02.03 18:09:37 3: CUL_HM set wz_lightRed statusRequest
2015.02.03 18:09:41 3: CUL_HM set fl_lightChrist statusRequest
2015.02.03 18:10:36 1: PERL WARNING: Argument "set_100" isn't numeric in numeric lt (<) at (eval 9607) line 1.
2015.02.03 18:10:36 3: CUL_HM set wz_lightDesk pct 100
2015.02.03 18:10:37 1: PERL WARNING: Argument "set_100" isn't numeric in numeric lt (<) at (eval 9612) line 1.
2015.02.03 18:10:37 3: CUL_HM set wz_lightCrystal pct 100
2015.02.03 18:10:38 1: PERL WARNING: Argument "set_100" isn't numeric in numeric lt (<) at (eval 9617) line 1.
2015.02.03 18:10:38 3: CUL_HM set wz_lightRed pct 100
2015.02.03 18:10:39 3: CUL_HM set fl_lightChain pct 100
2015.02.03 18:10:41 3: CUL_HM set fl_lightChrist pct 100
martinp876
schwer zu sagen - da der Filename und die Line nummer nicht korrekt sind.
Problem ist klar: jemand will einen numerischen Wert vergleichen (100) - aber der Wert ist in CUL_HM nicht bestätigt (set_100).
Ein Vergleich (leider weiss ich nicht, wer wo was vergleicht) würde nicht korrekt sein, da der Wert unklar ist.
Es scheint ein "eval" zu sein. Daher kann man das File nicht sehen.
Irgend eine Auswertung scheint es zu sein.
P.A.Trick
Soll ich das mal mit verbose 5 mitlaufen lassen?
martinp876
P.A.Trick
Zitat von: martinp876 am 07 Februar 2015, 15:33:52
ist ein Versuch.
Here we are (ist leider umgegehrt chronologisch)
2015.02.07 16:04:17.662 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem?XHR=1&inform=type=status;filter=;since=1423321455;fmt=JSON&timestamp=1423321457158
2015.02.07 16:04:17.469 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/images/default/fhemicon_dark.png
2015.02.07 16:04:17.436 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/images/default/icoEverything.png
2015.02.07 16:04:17.314 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/codemirror/codemirror.js
2015.02.07 16:04:17.306 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.292 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:17.274 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte.Switch state: CMDs_done -> state: CMDs_done
2015.02.07 16:04:17.273 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte.Switch CMDs_done -> CMDs_done
2015.02.07 16:04:17.272 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:17.270 5: HM_Components: not on any display, ignoring notify
2015.02.07 16:04:17.268 5: statistics Statistik: Notify.260 Notification of 'OG.SZ.Deckenleuchte.Switch' received. Device not monitored.
2015.02.07 16:04:17.267 5: Notify loop for OG.SZ.Deckenleuchte.Switch CMDs_done
2015.02.07 16:04:17.265 5: Triggering OG.SZ.Deckenleuchte.Switch (1 changes)
2015.02.07 16:04:17.258 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.252 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.246 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.239 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.233 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.226 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.208 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:17.189 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:17.188 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:17.181 5: rh: not on any display, don't trigger
2015.02.07 16:04:17.167 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:17.154 4: eventTypes: LightScene ls_AlleLichter nomatch -> nomatch
2015.02.07 16:04:17.153 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:17.149 5: statistics Statistik: Notify.260 Notification of 'ls_AlleLichter' received. Device not monitored.
2015.02.07 16:04:17.148 5: Notify loop for ls_AlleLichter nomatch
2015.02.07 16:04:17.147 5: Triggering ls_AlleLichter (1 changes)
2015.02.07 16:04:17.144 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:17.143 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:17.142 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:17.140 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte state: chn:0.5 phys:0 -> state: chn:.* phys:.*
2015.02.07 16:04:17.140 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte dim: up:0.5 -> dim: up:.*
2015.02.07 16:04:17.139 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte timedOn: running -> timedOn: running
2015.02.07 16:04:17.138 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte chn:0.5 phys:0 -> chn:.* phys:.*
2015.02.07 16:04:17.137 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte deviceMsg: 0.5 (to vccu) -> deviceMsg: .* (to vccu)
2015.02.07 16:04:17.137 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte pct: 0.5 -> pct: .*
2015.02.07 16:04:17.136 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte level: 0.5 -> level: .*
2015.02.07 16:04:17.135 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:17.132 5: HM_Components: not on any display, ignoring notify
2015.02.07 16:04:17.129 5: statistics Statistik: Notify.260 Notification of 'OG.SZ.Deckenleuchte' received. Device not monitored.
2015.02.07 16:04:17.128 5: Notify loop for OG.SZ.Deckenleuchte level: 0.5
2015.02.07 16:04:17.127 5: Triggering OG.SZ.Deckenleuchte (6 changes)
2015.02.07 16:04:17.123 3:     main::CallFn                        called by fhem.pl (608)
2015.02.07 16:04:17.122 3:     main::HMLAN_Read                    called by fhem.pl (2966)
2015.02.07 16:04:17.121 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (523)
2015.02.07 16:04:17.121 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (711)
2015.02.07 16:04:17.120 3:     main::CUL_HM_Parse                  called by fhem.pl (3103)
2015.02.07 16:04:17.119 3:     main::CUL_HM_pushEvnts              called by ./FHEM/10_CUL_HM.pm (2351)
2015.02.07 16:04:17.119 3:     main::CUL_HM_UpdtReadBulk           called by ./FHEM/10_CUL_HM.pm (2917)
2015.02.07 16:04:17.118 3:     main::readingsEndUpdate             called by ./FHEM/10_CUL_HM.pm (6938)
2015.02.07 16:04:17.117 3:     main::evalStateFormat               called by fhem.pl (3640)
2015.02.07 16:04:17.117 3:     (eval)                              called by fhem.pl (3552)
2015.02.07 16:04:17.116 3:     main::__ANON__                      called by (eval 63839) (1)
2015.02.07 16:04:17.115 3: stacktrace:
2015.02.07 16:04:17.114 1: PERL WARNING: Argument "set_100" isn't numeric in numeric eq (==) at (eval 63839) line 1.
2015.02.07 16:04:17.110 5: CUL_HM OG.SZ.Deckenleuchte.Switch protEvent:CMDs_done
2015.02.07 16:04:17.093 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/dashboard_darkstyle.css
2015.02.07 16:04:17.076 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/icons/favicon
2015.02.07 16:04:17.060 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/darkCommon.css
2015.02.07 16:04:17.007 4: HTTP FHEMWEB:192.168.1.33:52942 GET /fhem/pgm2/dashboard.js
2015.02.07 16:04:17.002 4: HTTP FHEMWEB:192.168.1.33:52940 GET /fhem/js/webviewcontrol.js
2015.02.07 16:04:17.000 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/cordova-2.3.0.js
2015.02.07 16:04:16.996 4: HTTP FHEMWEB:192.168.1.33:52959 GET /fhem/codemirror/fhem_codemirror.js
2015.02.07 16:04:16.993 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/codemirror/search.js
2015.02.07 16:04:16.989 4: HTTP FHEMWEB:192.168.1.33:52942 GET /fhem/codemirror/codemirror.js
2015.02.07 16:04:16.985 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/fhemweb_readingsHistory.js
2015.02.07 16:04:16.982 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/fhemweb_readingsGroup.js
2015.02.07 16:04:16.978 4: HTTP FHEMWEB:192.168.1.33:52940 GET /fhem/pgm2/fhemweb_knob.js
2015.02.07 16:04:16.974 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/fhemweb_colorpicker.js
2015.02.07 16:04:16.971 4: HTTP FHEMWEB:192.168.1.33:52959 GET /fhem/pgm2/jquery-ui.min.js
2015.02.07 16:04:16.969 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/fhemweb.js
2015.02.07 16:04:16.962 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/jquery.min.js
2015.02.07 16:04:16.956 4: HTTP FHEMWEB:192.168.1.33:52942 GET /fhem/pgm2/jquery-ui.min.css
2015.02.07 16:04:16.949 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem/pgm2/style.css
2015.02.07 16:04:16.862 4: 4356:FHEMWEB:192.168.1.33:52943: /fhem / RL:1781 / text/html; charset=UTF-8 / Content-Encoding: gzip
2015.02.07 16:04:16.843 4: HTTP FHEMWEB:192.168.1.33:52943 GET /fhem
2015.02.07 16:04:16.834 5: CUL_HM OG.SZ.Deckenleuchte.Switch protEvent:CMDs_processing... pending:0
2015.02.07 16:04:16.830 3: CUL_HM set OG.SZ.Deckenleuchte pct 100 2400 600
2015.02.07 16:04:16.823 5: rh: not on any display, don't trigger
2015.02.07 16:04:16.809 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:16.791 5: rh: not on any display, don't trigger
2015.02.07 16:04:16.777 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:16.764 4: eventTypes: LightScene ls_AlleLichter nomatch -> nomatch
2015.02.07 16:04:16.763 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:16.760 5: statistics Statistik: Notify.260 Notification of 'ls_AlleLichter' received. Device not monitored.
2015.02.07 16:04:16.760 5: Notify loop for ls_AlleLichter nomatch
2015.02.07 16:04:16.759 5: Triggering ls_AlleLichter (1 changes)
2015.02.07 16:04:16.755 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:16.754 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte state: set_100 -> state: set_.*
2015.02.07 16:04:16.754 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte set_100 -> set_.*
2015.02.07 16:04:16.753 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:16.751 5: HM_Components: not on any display, ignoring notify
2015.02.07 16:04:16.749 5: statistics Statistik: Notify.260 Notification of 'OG.SZ.Deckenleuchte' received. Device not monitored.
2015.02.07 16:04:16.748 5: Notify loop for OG.SZ.Deckenleuchte set_100
2015.02.07 16:04:16.747 5: Triggering OG.SZ.Deckenleuchte (1 changes)
2015.02.07 16:04:16.747 3:     main::CallFn                        called by fhem.pl (608)
2015.02.07 16:04:16.746 3:     main::FW_Read                       called by fhem.pl (2966)
2015.02.07 16:04:16.746 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (423)
2015.02.07 16:04:16.746 3:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (654)
2015.02.07 16:04:16.745 3:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (1989)
2015.02.07 16:04:16.744 3:     main::AnalyzeCommand                called by fhem.pl (868)
2015.02.07 16:04:16.744 3:     main::CommandSet                    called by fhem.pl (989)
2015.02.07 16:04:16.744 3:     main::DoSet                         called by fhem.pl (1497)
2015.02.07 16:04:16.743 3:     main::CallFn                        called by fhem.pl (1467)
2015.02.07 16:04:16.743 3:     main::CUL_HM_Set                    called by fhem.pl (2961)
2015.02.07 16:04:16.742 3:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (4823)
2015.02.07 16:04:16.742 3:     main::readingsSingleUpdate          called by ./FHEM/10_CUL_HM.pm (6948)
2015.02.07 16:04:16.741 3:     main::readingsEndUpdate             called by fhem.pl (3803)
2015.02.07 16:04:16.741 3:     main::evalStateFormat               called by fhem.pl (3640)
2015.02.07 16:04:16.741 3:     (eval)                              called by fhem.pl (3552)
2015.02.07 16:04:16.740 3:     main::__ANON__                      called by (eval 63838) (1)
2015.02.07 16:04:16.740 3: stacktrace:
2015.02.07 16:04:16.739 1: PERL WARNING: Argument "set_100" isn't numeric in numeric eq (==) at (eval 63838) line 1.
2015.02.07 16:04:16.731 5: rh: not on any display, don't trigger
2015.02.07 16:04:16.717 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:16.704 5: ls_AlleLichter: not on any display, ignoring notify
2015.02.07 16:04:16.703 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte level: set_100 -> level: set_.*
2015.02.07 16:04:16.702 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:16.701 5: HM_Components: not on any display, ignoring notify
2015.02.07 16:04:16.699 5: statistics Statistik: Notify.260 Notification of 'OG.SZ.Deckenleuchte' received. Device not monitored.
2015.02.07 16:04:16.698 5: Notify loop for OG.SZ.Deckenleuchte level: set_100
2015.02.07 16:04:16.698 5: Triggering OG.SZ.Deckenleuchte (1 changes)
2015.02.07 16:04:16.697 3:     main::CallFn                        called by fhem.pl (608)
2015.02.07 16:04:16.697 3:     main::FW_Read                       called by fhem.pl (2966)
2015.02.07 16:04:16.696 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (423)
2015.02.07 16:04:16.696 3:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (654)
2015.02.07 16:04:16.696 3:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (1989)
2015.02.07 16:04:16.696 3:     main::AnalyzeCommand                called by fhem.pl (868)
2015.02.07 16:04:16.695 3:     main::CommandSet                    called by fhem.pl (989)
2015.02.07 16:04:16.695 3:     main::DoSet                         called by fhem.pl (1497)
2015.02.07 16:04:16.694 3:     main::CallFn                        called by fhem.pl (1467)
2015.02.07 16:04:16.694 3:     main::CUL_HM_Set                    called by fhem.pl (2961)
2015.02.07 16:04:16.694 3:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (3799)
2015.02.07 16:04:16.693 3:     main::readingsSingleUpdate          called by ./FHEM/10_CUL_HM.pm (6948)
2015.02.07 16:04:16.693 3:     main::readingsEndUpdate             called by fhem.pl (3803)
2015.02.07 16:04:16.692 3:     main::evalStateFormat               called by fhem.pl (3640)
2015.02.07 16:04:16.692 3:     (eval)                              called by fhem.pl (3552)
2015.02.07 16:04:16.691 3:     main::__ANON__                      called by (eval 63837) (1)
2015.02.07 16:04:16.691 3: stacktrace:
2015.02.07 16:04:16.691 1: PERL WARNING: Argument "set_100" isn't numeric in numeric eq (==) at (eval 63837) line 1.
2015.02.07 16:04:16.689 5: CUL_HM OG.SZ.Deckenleuchte.Switch protEvent:CMDs_pending pending:1
2015.02.07 16:04:16.682 5: rh: not on any display, don't trigger
2015.02.07 16:04:16.668 5: rg_HM_RSSI: not on any display, ignoring notify
2015.02.07 16:04:16.654 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte.Switch state: CMDs_pending -> state: CMDs_pending
2015.02.07 16:04:16.654 4: eventTypes: CUL_HM OG.SZ.Deckenleuchte.Switch CMDs_pending -> CMDs_pending
2015.02.07 16:04:16.653 5: battStatus: not on any display, ignoring notify
2015.02.07 16:04:16.651 5: HM_Components: not on any display, ignoring notify
2015.02.07 16:04:16.649 5: statistics Statistik: Notify.260 Notification of 'OG.SZ.Deckenleuchte.Switch' received. Device not monitored.
2015.02.07 16:04:16.648 5: Notify loop for OG.SZ.Deckenleuchte.Switch CMDs_pending
2015.02.07 16:04:16.647 5: Triggering OG.SZ.Deckenleuchte.Switch (1 changes)
2015.02.07 16:04:16.644 5: Cmd: >set OG.SZ.Deckenleuchte pct 100 2400 600<
2015.02.07 16:04:16.640 4: HTTP FHEMWEB:192.168.1.33:52940 GET /fhem&cmd=set+OG.SZ.Deckenleuchte+pct+100+2400+600
