Fehlermeldungen
Begonnen von punker, 03 August 2014, 10:05:29
punker
habe ab und zu diese Fehlermeldungen im Log.
Wieso? 2014.08.03 09:16:24 1: HMLAN_Parse: hmusb new condition ok
2014.08.03 09:16:23 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:23 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:23 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:22 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
2014.08.03 09:16:21 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:21 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:21 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:21 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
2014.08.03 09:16:16 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:16 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:16 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:16 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
2014.08.03 09:16:14 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:14 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:14 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:14 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
2014.08.03 09:16:12 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:12 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:12 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:12 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
2014.08.03 09:16:11 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:11 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:11 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:11 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
2014.08.03 09:16:10 1: HMLAN_Parse: hmusb new condition init
2014.08.03 09:16:10 1: 127.0.0.1:1000 reappeared (hmusb)
2014.08.03 09:16:10 1: HMLAN_Parse: hmusb new condition disconnected
2014.08.03 09:16:10 1: 127.0.0.1:1000 disconnected, waiting to reappear (hmusb)
Dieter
The truth is out there!
Tion
Wenn es alle 24 Stunden vorkommt, vermute ich mal, das es der normale Reboot vom Stick ist.
    -r n            reboot HM-CFG-USB after n seconds (0: no reboot, default: 86400)
http://forum.fhem.de/index.php/topic,13071.msg79872.html#msg79872
Gruß Volker
FHEM@CT||RFXTRX,CUL868@MAX,HM-Usb,JeeLink
Jee:TX29DTH-IT||Max:Thermostat,ShutterContact,
HM:SEC-MDIR,LC-SW1-PL2,LC-Dim1TPBU-FM,PB-2-WM55
RFX:FA20RF/2, HE501EU,ITL-230,OWL Intuition-lc,YCT-100,div Brennstuhl,IT 1500
FS20:IRU,KSE||FbDect 200,EG-PM2-LAN
punker
Hab keinen Reboot definiert!
Die Meldungen kommen auch nicht jeden Tag!
Dieter
Tion
Musst du auch nicht definieren.
ZitatDa der HM-CFG-USB gelegentlich das Senden einstellt, wird er in der Standardkonfiguration 24 Stunden nach Verbindungsaubau neugestartet. Dieses Verhalten kann mit dem Parameter -r beeinflusst werden.
Schalte doch mal den Reboot aus und schau was passiert.
Gruß Volker
punker
So, habs jetzt mal mit -r 0 ausgeschalten.
Mal schaun obs hilft!
Dieter
Das ist alles auch ein bisschen abhängig von der Firmwareversion Deines USB-Sticks.
Bei Firmwareversionen älter als 0.967 ist der Reboot im hmland standardmäßig aktiviert - alle 86400 Sekunden (24 Stunden)
Bei Firmwareversionen ab 0.967 ist der Reboot im hmland standardmäßig abgeschaltet.
punker
Habe noch die 0.967 - muss ich mal updaten!
Wenn der Reboot standardmäßig aktiviert ist, lässt der sich dann wenigstens mit -r 0 abschalten?
Vielen Dank
Dieter
ja, steht doch alles im Hilfetext, wenn Du den hmland mal mit -h aufrufst
./hmland -h
Syntax: ./hmland options
Possible options:
-D debug mode
-d daemon mode
-h this help
-i interactive mode (connect HM-CFG-USB to terminal)
-l ip listen on given IP address only (for example 127.0.0.1)
-L logfile log network-communication to logfile
-P create PID file /var/run/hmland.pid in daemon mode
-p n listen on port n (default: 1000)
-r n reboot HM-CFG-USB after n seconds (0: no reboot, default: 86400 if FW < 0.967, 0 otherwise)
   hh:mm reboot HM-CFG-USB daily at hh:mm
-v verbose mode
-V show version (0.097-git)
punker
#8
Hab ich natürlich gelesen, wollte nur noch ne Bestätigung, damit du etwas zu tun hast!  ;D
Äh ist die 0.967 eigentlich die aktuellste FW?
Bin grad dabei die 30 Thread-Seiten durchzulesen!
Dieter
punker
Dieter
