57_Calendar.pm zickt rum
Begonnen von Eisingstone, 08 Oktober 2014, 11:50:48
Eisingstone
habe heute mal das Global LogFile der aktuellen Woche gecheckt und festgestellt das diese jetzt nach 2 Tagen schon ~ 130 MB groß ist.
Folgender Teil kommt dauernd vor und müllt das Log voll.
2014.10.08 11:45:36 1: PERL WARNING: Use of uninitialized value $key in hash element at ./FHEM/57_Calendar.pm line 89.
2014.10.08 11:45:36 3: stacktrace:
2014.10.08 11:45:36 3:     main::__ANON__                      called by ./FHEM/57_Calendar.pm (89)
2014.10.08 11:45:36 3:     ICal::Entry::addproperty            called by ./FHEM/57_Calendar.pm (137)
2014.10.08 11:45:36 3:     ICal::Entry::parseSub               called by ./FHEM/57_Calendar.pm (135)
2014.10.08 11:45:36 3:     ICal::Entry::parseSub               called by ./FHEM/57_Calendar.pm (109)
2014.10.08 11:45:36 3:     ICal::Entry::parse                  called by ./FHEM/57_Calendar.pm (923)
2014.10.08 11:45:36 3:     main::Calendar_GetUpdate            called by ./FHEM/57_Calendar.pm (798)
2014.10.08 11:45:36 3:     main::Calendar_Wakeup               called by ./FHEM/57_Calendar.pm (1086)
2014.10.08 11:45:36 3:     main::Calendar_Define               called by fhem.pl (2902)
2014.10.08 11:45:36 3:     main::CallFn                        called by fhem.pl (1570)
2014.10.08 11:45:36 3:     main::CommandDefine                 called by fhem.pl (966)
2014.10.08 11:45:36 3:     main::AnalyzeCommand                called by fhem.pl (847)
2014.10.08 11:45:36 3:     main::AnalyzeCommandChain           called by fhem.pl (1101)
2014.10.08 11:45:36 3:     main::CommandInclude                called by fhem.pl (1201)
2014.10.08 11:45:36 3:     main::CommandRereadCfg              called by fhem.pl (966)
2014.10.08 11:45:36 3:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (1918)
2014.10.08 11:45:36 3:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1716)
2014.10.08 11:45:36 3:     main::FW_style                      called by ./FHEM/01_FHEMWEB.pm (736)
2014.10.08 11:45:36 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (393)
2014.10.08 11:45:36 3:     main::FW_Read                       called by fhem.pl (2902)
2014.10.08 11:45:36 3:     main::CallFn                        called by fhem.pl (594)
Hat jemand eine Ahnung woran das liegen kann und evtl. eine Lösung dafür?
Update wird regelmäßig gemacht.
Danke und besten Gruß
Stefan
Post unter http://forum.fhem.de/index.php/topic,26034.0.html eingefügt.
FHEM 5.7 (Dev.), Debian Jessie Server
HM-LAN, HM-CFG-USB-2, RFXTRX433-USB, BT, HUE sowie diverse Homematic Sensoren und Aktoren
