FileLog nach Update kaputt
Begonnen von Herr 3x, 15 Oktober 2014, 18:30:32
Herr 3x
aktuell läuft bei mir:
# $Id: fhem.pl 6425 2014-08-19 20:55:00Z rudolfkoenig $
# $Id: 10_CUL_HM.pm 6747 2014-10-12 05:36:33Z martinp876 $
# $Id: 72_FB_CALLMONITOR.pm 6554 2014-09-15 10:12:17Z markusbloch $
# $Id: 01_FHEMWEB.pm 6611 2014-09-24 07:48:32Z rudolfkoenig $
# $Id: 95_FLOORPLAN.pm 6174 2014-06-29 05:51:28Z ulimaass $
# $Id: 92_FileLog.pm 6571 2014-09-19 16:05:56Z rudolfkoenig $
# $Id: 00_HMLAN.pm 6471 2014-08-27 12:32:38Z martinp876 $
# $Id: 98_HMinfo.pm 6575 2014-09-19 18:33:13Z martinp876 $
# $Id: 98_PID.pm 3988 2013-11-01 09:20:26Z john $
# $Id: 99_SUNRISE_EL.pm 5851 2014-05-13 19:39:03Z rudolfkoenig $
# $Id: 98_SVG.pm 6587 2014-09-21 12:11:10Z rudolfkoenig $
# $Id: 99_Utils.pm 6574 2014-09-19 17:32:48Z rudolfkoenig $
# $Id: 59_Weather.pm 6432 2014-08-20 15:46:12Z borisneubert $
# $Id: 90_at.pm 5319 2014-03-25 10:11:47Z rudolfkoenig $
# $Id: 98_autocreate.pm 6505 2014-09-06 12:24:48Z rudolfkoenig $
# $Id: 98_dewpoint.pm 5099 2014-03-02 16:29:34Z betateilchen $
# $Id: 98_dummy.pm 4934 2014-02-15 08:23:12Z rudolfkoenig $
# $Id: 91_notify.pm 6371 2014-08-07 05:33:37Z rudolfkoenig $
# $Id: 33_readingsGroup.pm 6262 2014-07-16 07:46:03Z justme1968 $
# $Id: 98_restore.pm 6451 2014-08-24 11:46:10Z rudolfkoenig $
# $Id: 98_telnet.pm 6611 2014-09-24 07:48:32Z rudolfkoenig $
# $Id:
# $Id: 98_weblink.pm 5608 2014-04-23 10:57:16Z rudolfkoenig $
Beim gestrigen Update waren alle Filelogs weg:
2014.10.14 21:20:35.337 1: reload: Error:Modul 92_FileLog deactivated:
Global symbol "$cmdFromAnalyze" requires explicit package name at /usr/local/share/fhem/FHEM/92_FileLog.pm line 700, <$fh> line 55.
Global symbol "$cmdFromAnalyze" requires explicit package name at /usr/local/share/fhem/FHEM/92_FileLog.pm line 701, <$fh> line 55.
Global symbol "$cmdFromAnalyze" requires explicit package name at /usr/local/share/fhem/FHEM/92_FileLog.pm line 702, <$fh> line 55.
Ich habe dann erst mal einen restore gemacht.
Was ist denn da kaputt? Vor allem scheint das kein übliches Problem zu sein, sonst hätte ich das sicher schon gefunden in der Suche.
Herr 3x
#1
Ich denke, in Zeile 700 müsste es korrekterweise heißen:
Das "my" fehlt aktuell.
Edit: na dann ist ja alles geklärt :)
fhem.pl ist nicht aktuell, benoetigt wird eine Version >= 6707, geaendert vor ca eine Woche.
Herr 3x
Vielen Dank, an dem veralteten fhem.pl lag es.
Jetzt muss ich nur noch herausfinden, warum fhem.pl nicht im Update mitgekommen ist.
webbi
nur als info:
ich hatte das gleiche Problem, auch eine alte fhem.pl
nach einem "update fhem.pl" und "shutdown restart" gehts dann.
