Replacement switch part number for Homatic HMIP-ROLL & BSL HM_LC_Sw1PBU_FM
Begonnen von Mario, 09 Januar 2020, 13:56:58
Mario
Dears,
I got failed internal switches with HmIP-BROLL & HmIP-BSL, does anybody know replacement producer / part number ?
Internally there are two black switches, round with diameter about 6 mm, height 5.5 mm, with lead wires, button travel length about 1.5-2 mm.
On mouser & digikey I only found poor match with Panasonic EVQ-PVF05K (with travel length 1.3 mm)
I see the same switches are probably within Homematic counter part like HM_LC_Sw1PBU_FM
Does anybody know replacement producer / part number ?
FHEM since 2013, mixed FS20, HmIP, HM,
own modules for heater, garden & wheater station,
sun intensity, rain ratio & soil humidity sensors for inteligent watering.
Pfriemler
just looked around, with no success. I did read about those switches for replacemant, but where?
Cleaning is not helpful?
Mario
Thank you, it could be SKPLAFD010..
BTW: cleaning would be not enough - switch is wholesale and is missing whole moving cap :-)
You can get genuine replacement (fast) here: https://mouser.com/ProductDetail/ALPS/SKPLAFD010?qs=4nKZKRgDHlkh65Qi5hphgA%3D%3D
