Update nicht möglich, IO::Socket::INET: connect: timeout ???
Begonnen von lukasbastelpeter, 30 März 2015, 18:38:38
lukasbastelpeter
wenn ich auf meinem BananaPi...
# $Id: fhem.pl 6913 2014-11-08 10:32:44Z rudolfkoenig $
# $Id: 00_CUL.pm 8176 2015-03-08 18:37:04Z martinp876 $
# $Id: 10_CUL_HM.pm 8258 2015-03-21 19:02:33Z martinp876 $
# $Id: 57_Calendar.pm 6742 2014-10-11 17:39:02Z borisneubert $
# $Id: 95_Dashboard.pm 5921 2014-05-21 18:47:19Z svenson08 $
# $Id: 01_FHEMWEB.pm 8288 2015-03-26 13:53:13Z rudolfkoenig $
# $Id: 95_FLOORPLAN.pm 6174 2014-06-29 05:51:28Z ulimaass $
# $Id: 10_FS20.pm 7070 2014-11-27 12:45:34Z rudolfkoenig $
# $Id: 92_FileLog.pm 6769 2014-10-15 17:03:30Z rudolfkoenig $
# $Id: 00_HMLAN.pm 7822 2015-02-01 16:28:10Z martinp876 $
# $Id: 98_HTTPMOD.pm 6463 2014-08-26 16:14:30Z ststrobel $
# $Id: 98_IF.pm 6855 2014-11-01 19:12:51Z damian-s $
# $Id: 10_IT.pm 8311 2015-03-28 15:40:22Z dancer0705 $
# $Id: 31_LightScene.pm 6704 2014-10-07 17:03:35Z justme1968 $
# $Id: 73_PRESENCE.pm 6706 2014-10-07 21:24:25Z markusbloch $
# $Id: 99_SUNRISE_EL.pm 5851 2014-05-13 19:39:03Z rudolfkoenig $
# $Id: 98_SVG.pm 6756 2014-10-12 13:13:26Z rudolfkoenig $
# $Id: 10_UNIRoll.pm 6514 2014-09-07 11:10:40Z c-herrmann $
# $Id: 99_Utils.pm 5488 2014-04-08 11:32:17Z rudolfkoenig $
# $Id: 59_Weather.pm 6705 2014-10-07 17:41:42Z borisneubert $
# $Id: 98_XmlList.pm 2895 2013-03-11 19:48:01Z rudolfkoenig $
# $Id: 90_at.pm 6797 2014-10-21 12:32:19Z rudolfkoenig $
# $Id: 98_autocreate.pm 6505 2014-09-06 12:24:48Z rudolfkoenig $
# $Id: 98_backup.pm 5893 2014-05-19 09:45:08Z rudolfkoenig $
# $Id: 98_dummy.pm 4934 2014-02-15 08:23:12Z rudolfkoenig $
# $Id: 91_eventTypes.pm 6792 2014-10-19 16:03:13Z rudolfkoenig $
# $Id: 91_notify.pm 6371 2014-08-07 05:33:37Z rudolfkoenig $
# $Id: 33_readingsGroup.pm 6262 2014-07-16 07:46:03Z justme1968 $
# $Id: 32_speedtest.pm 6631 2014-09-29 12:52:53Z justme1968 $
# $Id: 98_structure.pm 6664 2014-10-03 10:53:48Z rudolfkoenig $
# $Id: 98_telnet.pm 6611 2014-09-24 07:48:32Z rudolfkoenig $
# $Id: 98_update.pm 6784 2014-10-18 09:12:57Z rudolfkoenig $
# $Id: 91_watchdog.pm 5622 2014-04-24 08:04:29Z rudolfkoenig $
./FHEM/95_webViewControl.pm: No such file or directory
# $Id: 98_weblink.pm 5608 2014-04-23 10:57:16Z rudolfkoenig $
"update" ausführe bekomme ich:
Events (global only):
2015-03-30 18:33:37 Global global UPD ./CHANGED
2015-03-30 18:33:38 Global global UPD ./configDB.pm
2015-03-30 18:33:38 Global global UPD ./fhem.cfg.demo
2015-03-30 18:33:38 Global global UPD ./fhem.pl
2015-03-30 18:33:38 Global global UPD FHEM/00_CUL.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_FBAHA.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_HMLAN.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_HXB.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_KM271.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_MAXLAN.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_MQTT.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_RPII2C.pm
2015-03-30 18:33:39 Global global UPD FHEM/00_SONOS.pm
2015-03-30 18:33:40 Global global UPD FHEM/00_TCM.pm
2015-03-30 18:33:40 Global global UPD FHEM/00_THZ.pm
2015-03-30 18:33:41 Global global UPD FHEM/00_ZWDongle.pm
2015-03-30 18:33:41 Global global UPD FHEM/01_FHEMWEB.pm
2015-03-30 18:33:41 Global global UPD FHEM/02_FRAMEBUFFER.pm
2015-03-30 18:33:41 Global global UPD FHEM/02_HTTPSRV.pm
2015-03-30 18:33:41 Global global UPD FHEM/02_RSS.pm
2015-03-30 18:33:41 Global global UPD FHEM/09_CUL_FHTTK.pm
2015-03-30 18:33:42 Global global UPD FHEM/10_CUL_HM.pm
2015-03-30 18:33:43 Global global UPD FHEM/10_EnOcean.pm
2015-03-30 18:33:44 Global global UPD FHEM/10_FRM.pm
2015-03-30 18:33:45 Global global UPD FHEM/10_FS20.pm
2015-03-30 18:33:45 Global global UPD FHEM/10_HXBDevice.pm
2015-03-30 18:33:45 Global global UPD FHEM/10_IT.pm
2015-03-30 18:33:45 Global global UPD FHEM/10_KOPP_FC.pm
2015-03-30 18:33:46 Global global UPD FHEM/10_MAX.pm
2015-03-30 18:33:46 Global global UPD FHEM/10_MQTT_BRIDGE.pm
2015-03-30 18:33:46 Global global UPD FHEM/10_MQTT_DEVICE.pm
2015-03-30 18:33:46 Global global UPD FHEM/10_MYSENSORS_DEVICE.pm
2015-03-30 18:33:46 Global global UPD FHEM/10_OWServer.pm
2015-03-30 18:33:46 Global global UPD FHEM/10_RESIDENTS.pm
2015-03-30 18:33:50 Global global http://fhem.de/fhemupdate/FHEM/10_RESIDENTS.pm: Can't connect(1) to http://fhem.de:80: IO::Socket::INET: connect: timeout
Jemand Ideen?
# Raspberry Pi
# Homematic, Z-Wave
# HUE, Tradfri
# Harmony
# ESP8266  Basteleien per MQTT
Benni
Hallo lukasbastelpeter,
kommt manchmal vor, wenn die Internetverbindung hakelt.
Hatte ich auch schon: Einfach ein paar mal versuchen, irgendwann klappt's dann schon.
Und für den Fall der Fälle hast du zuvor natürlich sowieso ein Backup gemacht?  ;)
Gruß Benni.
lukasbastelpeter
#2
Backup habe ich gemacht, hatte das schon mal auf meiner alten Himbeere, da war danach ganz gerne mal alles platt bei solchen Meldungen.
Ich habe Unitymedia... mit FritzBox habe hier irgendwo gelesen, dass es nicht so die beste Ausgangslage ist. Stimmt das?
(http://forum.fhem.de/index.php/topic,11503.msg257840.html#msg257840)
Wenn ja/nein, was kann ich sonst noch machen außer fleißig weiter probieren?
# Raspberry Pi
# Homematic, Z-Wave
# HUE, Tradfri
# Harmony
