tempList erneuern, weiss nimmer wie
Begonnen von satprofi, 21 November 2014, 12:59:00
satprofi
Hallo.
Wollte heute meine tempList aus der 99_myUtils.pm in den HM--CC-RT-DN einspielen, aber irgendwie klappt das nicht. Habs schon einmal gemacht, allerdings schon länger her.
wenn ich jetzt set HZ_Wohnzimmer_Clima tempList 99_myUtils.pm  eingebe bekomme ich folgendes retour
Unknown argument tempList, choose one of burstXmit clear:readings,register,rssi,msgEvents controlManu:on,off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0 controlMode:auto,manu,boost,day,night controlParty desired-temp:on,off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0 getConfig getRegRaw inhibit:on,off peerBulk regBulk regSet sign:on,off sysTime tempListFri tempListMon tempListSat tempListSun tempListThu tempListTmpl tempListTue tempListWed
was passt da nicht?
99_myUtils.pm
sub
SetTempList_Wohnzimmer()
   { fhem ("set HZ_Wohnzimmer_Clima tempListMon prep 05:30 18.0 05:50 20.0 16:00 20.5 21:30 20.0 24:00 18.0")};
   { fhem ("set HZ_Wohnzimmer_Clima tempListTue prep 05:30 18.0 05:50 20.0 16:00 20.5 21:30 20.0 24:00 18.0")};
   { fhem ("set HZ_Wohnzimmer_Clima tempListWed prep 05:30 18.0 05:50 20.5 16:00 20.5 21:30 20.0 24:00 18.0")};
   { fhem ("set HZ_Wohnzimmer_Clima tempListThu prep 05:30 18.0 05:50 20.0 16:00 20.5 21:30 20.0 24:00 18.0")};
   { fhem ("set HZ_Wohnzimmer_Clima tempListFri prep 05:30 18.0 15:00 20.5 20:30 20.0 24:00 18.0")};
   { fhem ("set HZ_Wohnzimmer_Clima tempListSat prep 07:00 18.0 21:00 21.0 24:00 18.0")};
   { fhem ("set HZ_Wohnzimmer_Clima tempListSun exec 07:00 18.0 21:00 21.0 24:00 18.0")};
# End SetTempList_Wohnzimmer
oder ist der Befehl falsch?
Tasmota,LD382A,Telegram
herrmie
gib oben in der cmd box einfach mal {SetTempList_Wohnzimmer()} ein.
Grüße,
herrmie
satprofi
