Keymatic Settings über Fhem verändern
Begonnen von Rampler, 18 Dezember 2014, 20:31:42
Rampler
kann ich überhaupt die Keymatic spezifischen Settings über Fhem ändern ?
Der List WF.keymatic ergibt:
   DEF        261118
   HMLAN1_MSGCNT 164
   HMLAN1_RAWMSG E261118,0000,0568B837,FF,FFC0,71A01026111829A0830287FF8B880000
   HMLAN1_RSSI -64
   HMLAN1_TIME 2014-12-18 20:16:47
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     164
   NAME       WF.keymatic
   NR         30
   STATE      unlocked
   TYPE       CUL_HM
   lastMsg    No:71 - t:10 s:261118 d:29A083 0287FF8B880000
   peerList   WF.fb_unlock,WF.fb_lock,WF.fb_open,WF.codeschloss1,
   protCmdDel 0
   protEvt_AESok 6 last_at:2014-12-18 20:09:01
   protLastRcv 2014-12-18 20:16:47
   protNack   1 last_at:2014-12-18 19:50:43
   protSnd    136 last_at:2014-12-18 20:16:47
   protState  CMDs_done
   rssi_HMLAN1 avg:-64.31 min:-69 max:-60 lst:-65 cnt:19
   rssi_WF.codeschloss avg:-44.15 min:-54 max:-29 lst:-30 cnt:13
   rssi_at_HMLAN1 avg:-63.4 min:-73 max:-56 lst:-64 cnt:164
   Readings:
     2014-12-18 20:16:43   PairedTo        0x29A083
     2014-12-18 20:16:47   R-WF.codeschloss1-lgCtOff geLo
     2014-12-18 20:16:47   R-WF.codeschloss1-lgCtOn geLo
     2014-12-18 20:16:47   R-WF.codeschloss1-lgCtValHi 100
     2014-12-18 20:16:47   R-WF.codeschloss1-lgCtValLo 50
     2014-12-18 20:16:47   R-WF.codeschloss1-lgKeyJtOff open
     2014-12-18 20:16:47   R-WF.codeschloss1-lgKeyJtOn open
     2014-12-18 20:16:47   R-WF.codeschloss1-lgOnTime unused
     2014-12-18 20:16:47   R-WF.codeschloss1-shCtOff geLo
     2014-12-18 20:16:47   R-WF.codeschloss1-shCtOn geLo
     2014-12-18 20:16:47   R-WF.codeschloss1-shCtValHi 100
     2014-12-18 20:16:47   R-WF.codeschloss1-shCtValLo 50
     2014-12-18 20:16:47   R-WF.codeschloss1-shKeyJtOff open
     2014-12-18 20:16:47   R-WF.codeschloss1-shKeyJtOn open
     2014-12-18 20:16:47   R-WF.codeschloss1-shOnTime unused
     2014-12-18 20:16:45   R-WF.fb_lock-lgCtOff geLo
     2014-12-18 20:16:45   R-WF.fb_lock-lgCtOn geLo
     2014-12-18 20:16:45   R-WF.fb_lock-lgCtValHi 100
     2014-12-18 20:16:45   R-WF.fb_lock-lgCtValLo 50
     2014-12-18 20:16:45   R-WF.fb_lock-lgKeyJtOff lock
     2014-12-18 20:16:45   R-WF.fb_lock-lgKeyJtOn lock
     2014-12-18 20:16:45   R-WF.fb_lock-lgOnTime unused
     2014-12-18 20:16:45   R-WF.fb_lock-shCtOff geLo
     2014-12-18 20:16:45   R-WF.fb_lock-shCtOn geLo
     2014-12-18 20:16:45   R-WF.fb_lock-shCtValHi 100
     2014-12-18 20:16:45   R-WF.fb_lock-shCtValLo 50
     2014-12-18 20:16:45   R-WF.fb_lock-shKeyJtOff lock
     2014-12-18 20:16:45   R-WF.fb_lock-shKeyJtOn lock
     2014-12-18 20:16:45   R-WF.fb_lock-shOnTime unused
     2014-12-18 20:16:46   R-WF.fb_open-lgCtOff geLo
     2014-12-18 20:16:46   R-WF.fb_open-lgCtOn geLo
     2014-12-18 20:16:46   R-WF.fb_open-lgCtValHi 100
     2014-12-18 20:16:46   R-WF.fb_open-lgCtValLo 50
     2014-12-18 20:16:46   R-WF.fb_open-lgKeyJtOff open
     2014-12-18 20:16:46   R-WF.fb_open-lgKeyJtOn open
     2014-12-18 20:16:46   R-WF.fb_open-lgOnTime unused
     2014-12-18 20:16:46   R-WF.fb_open-shCtOff geLo
     2014-12-18 20:16:46   R-WF.fb_open-shCtOn geLo
     2014-12-18 20:16:46   R-WF.fb_open-shCtValHi 100
     2014-12-18 20:16:46   R-WF.fb_open-shCtValLo 50
     2014-12-18 20:16:46   R-WF.fb_open-shKeyJtOff open
     2014-12-18 20:16:46   R-WF.fb_open-shKeyJtOn open
     2014-12-18 20:16:46   R-WF.fb_open-shOnTime unused
     2014-12-18 20:16:44   R-WF.fb_unlock-lgCtOff geLo
     2014-12-18 20:16:44   R-WF.fb_unlock-lgCtOn geLo
     2014-12-18 20:16:44   R-WF.fb_unlock-lgCtValHi 100
     2014-12-18 20:16:44   R-WF.fb_unlock-lgCtValLo 50
     2014-12-18 20:16:44   R-WF.fb_unlock-lgKeyJtOff open
     2014-12-18 20:16:44   R-WF.fb_unlock-lgKeyJtOn open
     2014-12-18 20:16:44   R-WF.fb_unlock-lgOnTime unused
     2014-12-18 20:16:44   R-WF.fb_unlock-shCtOff geLo
     2014-12-18 20:16:44   R-WF.fb_unlock-shCtOn geLo
     2014-12-18 20:16:44   R-WF.fb_unlock-shCtValHi 100
     2014-12-18 20:16:44   R-WF.fb_unlock-shCtValLo 50
     2014-12-18 20:16:44   R-WF.fb_unlock-shKeyJtOff unLock
     2014-12-18 20:16:44   R-WF.fb_unlock-shKeyJtOn unLock
     2014-12-18 20:16:44   R-WF.fb_unlock-shOnTime unused
     2014-12-18 20:16:43   R-keypressSignal on
     2014-12-18 20:16:43   R-pairCentral   0x29A083
     2014-12-18 20:16:43   R-signal        on
     2014-12-18 20:16:43   R-signalTone    low
     2014-12-18 20:16:43   RegL_00:          02:01 03:19 0A:29 0B:A0 0C:83 00:00
     2014-12-18 20:16:47   RegL_03:WF.codeschloss1   03:00 04:32 05:64 07:FF 0B:88 83:00 84:32 85:64  87:FF 8B:88 00:00
     2014-12-18 20:16:45   RegL_03:WF.fb_lock   03:00 04:32 05:64 07:FF 0B:66 83:00 84:32 85:64  87:FF 8B:66 00:00
     2014-12-18 20:16:46   RegL_03:WF.fb_open   03:00 04:32 05:64 07:FF 0B:88 83:00 84:32 85:64  87:FF 8B:88 00:00
     2014-12-18 20:16:44   RegL_03:WF.fb_unlock   03:00 04:32 05:64 07:FF 0B:33 83:00 84:32 85:64  87:FF 8B:88 00:00
     2014-12-18 20:15:47   battery         ok
     2014-12-18 20:15:47   direction       none
     2014-12-18 20:15:47   error           none
     2014-12-18 20:15:47   lock            unlocked
     2014-12-18 20:16:44   peerList        WF.fb_unlock,WF.fb_lock,WF.fb_open,WF.codeschloss1,
     2014-12-18 20:15:47   recentStateType info
     2014-12-18 20:15:47   state           unlocked
     2014-12-18 20:15:47   uncertain       no
   Helper:
     cSnd       0129A083261118010429B6650103
     mId        0026
     peerIDsRaw ,26848A01,26848A02,26848A04,29B66501,00000000
     rxType     2
     Io:
       newChn     +261118,00,01,00
       nextSend   1418930207.17623
       prefIO
       rxt        0
       vccu
       p:
         261118
         00
         01
         00
     Mrssi:
       mNo        71
       Io:
         HMLAN1     -62
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMLAN1
       flg        A
       ts         1418930207.11366
       ack:
         HASH(0x21326d0)
         71800229A08326111800
     Rssi:
       Hmlan1:
         avg        -64.3157894736842
         cnt        19
         lst        -65
         max        -60
         min        -69
       Wf.codeschloss:
         avg        -44.1538461538462
         cnt        13
         lst        -30
         max        -29
         min        -54
       At_hmlan1:
         avg        -63.4024390243903
         cnt        164
         lst        -64
         max        -56
         min        -73
     Shadowreg:
       RegL_01:    14:1F
   IODev      HMLAN1
   actCycle   024:00
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_full
   firmware   2.5
   model      HM-SEC-KEY-S
   msgRepeat  1
   peerIDs    00000000,26848A01,26848A02,26848A04,29B66501,
   room       Windfang
   serialNr   KEQ1063797
   subType    keyMatic
   webCmd     lock:unlock:open
Was mir abgeht ist z.B:
   1: angelLocked      |   0 to 3000deg     |          | Angle Locked position
   1: angelMax         |   0 to 3000deg     |          | Angle maximum
   1: angelOpen        |   0 to 3000deg     |          | Door opening angle
   1: holdPWM          |   0 to 255         |          | Holdtime pulse wide modulation
   1: holdTime         |   0 to 8.16s       |          | Holdtime for door opening
Beim Versuch die holdTime auf 1 zu setzen ergibt :
R-holdTime set_0.992 s
protState CMDs_done
Also das set_ verschwindet nicht, nach clear reading - getconfig ist das reading wieder weg
Sieht so aus als werden zum einen nicht alle Readings gelesen, und folglich auch keine geschrieben..
expert steht auf 2_full
intKeyVisib gibt es nicht
Der Türöffner ist aber einwandfrei über Fhem zu steuern...
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Bullseye), ZWAVE, HM-Classic, und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
Rampler
Ich will mal anders Fragen:
Hat jemand die Settings (Drehwinkel, Haltezeit etc.) der Keymatic HM-SEC-KEY-S erfolgreich mit FHEM verändert ??
Nicht das ich hier suche und es liegt dann doch an FHEM ..
frank
alles was dir "abgeht" sind register aus register-liste1. wenn du diese mit get reglist angezeigt bekommst, sollte fhem damit arbeiten können. in deinen readings erscheint aber keine liste1. nur liste0 und listen3. was sagt denn zb hminfo configcheck?
ZitatAlso das set_ verschwindet nicht, nach clear reading - getconfig ist das reading wieder weg
diesem getconfig folgte auch ein cmds_done?
ZitatSieht so aus als werden zum einen nicht alle Readings gelesen,
weil liste 1 fehlt.
Zitatund folglich auch keine geschrieben..
könnte trotzdem gesetzt werden. nur nicht zu verifizieren. sind änderungen am verhalten der keymatic nicht feststellbar?
ansonsten raw-messages sniffen. fhem ist aktuell?
gruss frank
FHEM: 6.0(SVN) => Pi3(buster)
Rampler
Erst mal danke für die Infos   :)
Zitatwas sagt denn zb hminfo configcheck?
configCheck done:
missing register list
    WF.fb_light:   RegL_01:
    WF.fb_lock:   RegL_01:,RegL_04:WF.keymatic_chn:01
    WF.fb_open:   RegL_01:,RegL_04:WF.keymatic_chn:01
    WF.fb_unlock:   RegL_01:,RegL_04:WF.keymatic_chn:01
peer not verified. Check that peer is set on both sides
    WF.licht p:WF.fb_light
trigger sent to undefined device
    triggerUndefined: WF.fb_light:29A083
    triggerUndefined: WF.tuerkontakt:29A083
Kannte den configcheck bisher nocht nicht coole Sache ..
Zitatdiesem getconfig folgte auch ein cmds_done?
Korrekt ohne Fehlermeldung..(kein pending..)
ZitatSind änderungen am verhalten der keymatic nicht feststellbar?
Ich habe mal erfolgreich mit den Quttingston gespielt.
get regList sieht gut aus, also angelLocked,angelOpen stehen drinn
ansonsten raw-messages sniffen.  ==> bin schon am lesen ...
fhem ist aktuell?  ==> Gestern erst ein update gemacht..
gruss Klaus
Rampler
Hallo Frank,
ich hoffe das erschlägt Dich nicht ..
Also nach clear readings:
2014.12.19 15:26:47.567 0: HMLAN_Parse: HMLAN1 R:E24A2F6   stat:0000 t:006193BF d:FF r:FFC5     m:A8 845E 24A2F6 000000 800576000000000008DAFD
2014.12.19 15:26:50.657 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:26:50.662 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00619FE1 IDcnt:000C
2014.12.19 15:27:15.662 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:27:15.668 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00620193 IDcnt:000C
2014.12.19 15:27:22.738 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:00621D28 d:FF r:FFBD     m:09 A610 2EEC7C 29A083 06011600
2014.12.19 15:27:22.828 0: HMLAN_Send:  HMLAN1 S:S62F22146 stat:  00 t:00000000 d:01 r:62F22146 m:09 8002 29A083 2EEC7C 01011600
2014.12.19 15:27:23.126 0: HMLAN_Parse: HMLAN1 R:R62F22146 stat:0002 t:00000000 d:FF r:7FFF     m:09 8002 29A083 2EEC7C 01011600
2014.12.19 15:27:40.670 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:27:40.676 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00626347 IDcnt:000C
2014.12.19 15:27:42.731 0: HMLAN_Send:  HMLAN1 S:S62F26F54 stat:  00 t:00000000 d:01 r:62F26F54 m:13 B001 29A083 261118 010E
2014.12.19 15:27:43.251 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:00626D4B d:FF r:FFB6     m:13 A010 261118 29A083 060101004A
2014.12.19 15:27:43.368 0: HMLAN_Parse: HMLAN1 R:R62F26F54 stat:0001 t:00626D50 d:FF r:FFB6     m:13 A010 261118 29A083 060101004A
2014.12.19 15:28:05.687 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:28:05.693 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0062C503 IDcnt:000C
Nach getconfig:
2014.12.19 15:28:30.704 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:28:30.709 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:006326C0 IDcnt:000C
2014.12.19 15:28:55.710 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:28:55.716 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00638873 IDcnt:000C
2014.12.19 15:29:18.067 0: HMLAN_Parse: HMLAN1 R:E24A2F6   stat:0000 t:0063DFBC d:FF r:FFC4     m:A9 845E 24A2F6 000000 800576000000000008DAFF
2014.12.19 15:29:20.717 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:29:20.722 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0063EA26 IDcnt:000C
2014.12.19 15:29:45.735 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:29:45.740 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00644BE3 IDcnt:000C
2014.12.19 15:30:10.761 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:30:10.766 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0064ADAA IDcnt:000C
2014.12.19 15:30:29.080 0: HMLAN_Send:  HMLAN1 S:+261118,00,01,00
2014.12.19 15:30:29.082 0: HMLAN_Send:  HMLAN1 S:S62F4F921 stat:  00 t:00000000 d:01 r:62F4F921 m:14 B001 29A083 261118 00040000000000
2014.12.19 15:30:29.609 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0064F73C d:FF r:FFB7     m:14 A010 261118 29A083 02020103190A290BA00C830000
2014.12.19 15:30:29.720 0: HMLAN_Parse: HMLAN1 R:R62F4F921 stat:0001 t:0064F741 d:FF r:FFB7     m:14 A010 261118 29A083 02020103190A290BA00C830000
2014.12.19 15:30:29.729 0: HMLAN_Send:  HMLAN1 S:+261118,00,01,00
2014.12.19 15:30:29.730 0: HMLAN_Send:  HMLAN1 S:S62F4FBAA stat:  00 t:00000000 d:01 r:62F4FBAA m:15 A001 29A083 261118 0103
2014.12.19 15:30:30.136 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0064F94B d:FF r:FFB7     m:15 A010 261118 29A083 0126848A0126848A0226848A0429B66501
2014.12.19 15:30:30.244 0: HMLAN_Parse: HMLAN1 R:R62F4FBAA stat:0001 t:0064F950 d:FF r:FFB7     m:15 A010 261118 29A083 0126848A0126848A0226848A0429B66501
2014.12.19 15:30:30.379 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0064FA40 d:FF r:FFB8     m:16 A010 261118 29A083 0100000000
2014.12.19 15:30:30.470 0: HMLAN_Send:  HMLAN1 S:S62F4FE47 stat:  00 t:00000000 d:01 r:62F4FE47 m:16 A001 29A083 261118 010426848A0103
2014.12.19 15:30:30.909 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0064FC50 d:FF r:FFB7     m:16 A010 261118 29A083 0203000432056407FF0B33830084328564
2014.12.19 15:30:31.017 0: HMLAN_Parse: HMLAN1 R:R62F4FE47 stat:0001 t:0064FC55 d:FF r:FFB7     m:16 A010 261118 29A083 0203000432056407FF0B33830084328564
2014.12.19 15:30:31.153 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0064FD46 d:FF r:FFB7     m:17 A010 261118 29A083 0287FF8B880000
2014.12.19 15:30:31.244 0: HMLAN_Send:  HMLAN1 S:S62F5015A stat:  00 t:00000000 d:01 r:62F5015A m:17 A001 29A083 261118 010426848A0203
2014.12.19 15:30:31.682 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0064FF55 d:FF r:FFB7     m:17 A010 261118 29A083 0203000432056407FF0B66830084328564
2014.12.19 15:30:31.790 0: HMLAN_Parse: HMLAN1 R:R62F5015A stat:0001 t:0064FF5A d:FF r:FFB7     m:17 A010 261118 29A083 0203000432056407FF0B66830084328564
2014.12.19 15:30:31.927 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0065004B d:FF r:FFB7     m:18 A010 261118 29A083 0287FF8B660000
2014.12.19 15:30:32.017 0: HMLAN_Send:  HMLAN1 S:S62F50460 stat:  00 t:00000000 d:01 r:62F50460 m:18 A001 29A083 261118 010426848A0403
2014.12.19 15:30:32.455 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0065025A d:FF r:FFB7     m:18 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:30:32.562 0: HMLAN_Parse: HMLAN1 R:R62F50460 stat:0001 t:0065025F d:FF r:FFB7     m:18 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:30:32.699 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:00650350 d:FF r:FFB7     m:19 A010 261118 29A083 0287FF8B880000
2014.12.19 15:30:32.790 0: HMLAN_Send:  HMLAN1 S:S62F50764 stat:  00 t:00000000 d:01 r:62F50764 m:19 A001 29A083 261118 010429B6650103
2014.12.19 15:30:33.228 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:0065055F d:FF r:FFB7     m:19 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:30:33.335 0: HMLAN_Parse: HMLAN1 R:R62F50764 stat:0001 t:00650564 d:FF r:FFB7     m:19 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:30:33.472 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:00650655 d:FF r:FFB8     m:1A A010 261118 29A083 0287FF8B880000
2014.12.19 15:30:35.765 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:30:35.771 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00650F5A IDcnt:000C
2014.12.19 15:31:00.773 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:31:00.779 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0065710F IDcnt:000C
2014.12.19 15:31:25.801 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:31:25.807 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0065D2D6 IDcnt:000C
2014.12.19 15:31:34.068 0: HMLAN_Parse: HMLAN1 R:E24A2F6   stat:0000 t:0065F313 d:FF r:FFC7     m:AA 845E 24A2F6 000000 800576000000000008D9FE
2014.12.19 15:31:50.804 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:31:50.821 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00663486 IDcnt:000C
2014.12.19 15:31:54.924 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:0066448F d:FF r:FFBE     m:0A A441 2EEC7C 2F046F 01E50840
2014.12.19 15:31:55.050 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:0066450D d:FF r:FFB7     m:0A 8002 2F046F 2EEC7C 0101C84037
2014.12.19 15:31:57.247 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00664DA2 d:FF r:FFB8     m:0B A410 2F046F 29A083 0601C840
2014.12.19 15:32:09.328 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:00667CD5 d:FF r:FFB2     m:0B A441 2EEC7C 2F046F 01E68240
2014.12.19 15:32:09.454 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00667D53 d:FF r:FFB5     m:0B 8002 2F046F 2EEC7C 0101C84032
2014.12.19 15:32:12.027 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00668760 d:FF r:FFB7     m:0C A410 2F046F 29A083 0601C840
2014.12.19 15:32:13.021 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:00668B43 d:FF r:FFB8     m:0C A610 2EEC7C 29A083 06018100
2014.12.19 15:32:13.124 0: HMLAN_Send:  HMLAN1 S:S62F68F31 stat:  00 t:00000000 d:01 r:62F68F31 m:0C 8002 29A083 2EEC7C 01018100
2014.12.19 15:32:13.409 0: HMLAN_Parse: HMLAN1 R:R62F68F31 stat:0002 t:00000000 d:FF r:7FFF     m:0C 8002 29A083 2EEC7C 01018100
2014.12.19 15:32:15.811 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:32:15.816 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:00669638 IDcnt:000C
2014.12.19 15:32:27.981 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:0066C5B5 d:FF r:FFB7     m:0D A441 2EEC7C 2F046F 01E78240
2014.12.19 15:32:28.107 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:0066C633 d:FF r:FFB7     m:0D 8002 2F046F 2EEC7C 0101C84031
2014.12.19 15:32:30.003 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:0066CD9B d:FF r:FFB8     m:0E A410 2F046F 29A083 0601C840
2014.12.19 15:32:40.816 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:32:40.822 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0066F7EA IDcnt:000C
2014.12.19 15:32:43.688 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:00670313 d:FF r:FFBA     m:0E A441 2EEC7C 2F046F 01E87C40
2014.12.19 15:32:43.814 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00670391 d:FF r:FFB3     m:0E 8002 2F046F 2EEC7C 0101C8402F
2014.12.19 15:32:45.681 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00670ADC d:FF r:FFB4     m:0F A410 2F046F 29A083 0601C840
2014.12.19 15:32:58.615 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:00673D64 d:FF r:FFB9     m:0F A441 2EEC7C 2F046F 01E97F40
2014.12.19 15:32:58.741 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00673DE2 d:FF r:FFB6     m:0F 8002 2F046F 2EEC7C 0101C8402E
2014.12.19 15:33:01.460 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00674881 d:FF r:FFAE     m:10 A410 2F046F 29A083 0601C840
2014.12.19 15:33:05.824 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:33:05.829 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0067599D IDcnt:000C
2014.12.19 15:33:14.532 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:00677B95 d:FF r:FFBA     m:10 A441 2EEC7C 2F046F 01EA7F40
2014.12.19 15:33:14.657 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00677C12 d:FF r:FFB3     m:10 8002 2F046F 2EEC7C 0101C8402F
2014.12.19 15:33:16.739 0: HMLAN_Parse: HMLAN1 R:E2F046F   stat:0000 t:00678434 d:FF r:FFB5     m:11 A410 2F046F 29A083 0601C840
2014.12.19 15:33:30.841 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:33:30.846 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:0067BB5C IDcnt:000C
2014.12.19 15:33:35.818 0: HMLAN_Parse: HMLAN1 R:E24A2F6   stat:0000 t:0067CEBE d:FF r:FFC4     m:AB 845E 24A2F6 000000 800576000000000008D4FE
Und nach set WF.keymatic regSet holdTime 1
2014.12.19 15:36:50.958 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:36:50.964 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:006AC932 IDcnt:000C
2014.12.19 15:37:12.861 0: HMLAN_Send:  HMLAN1 S:S62FB2266 stat:  00 t:00000000 d:01 r:62FB2266 m:1A B001 29A083 261118 01050000000001
2014.12.19 15:37:13.397 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0100 t:006B20BE d:FF r:FFB8     m:1A A002 261118 29A083 04A71F6B8C742E02
2014.12.19 15:37:13.632 0: HMLAN_Parse: HMLAN1 R:R62FB2266 stat:0021 t:006B20C3 d:01 r:FFB8     m:1A 8002 261118 29A083 0057E2E2A5
2014.12.19 15:37:13.645 0: HMLAN_Send:  HMLAN1 S:S62FB2576 stat:  00 t:00000000 d:01 r:62FB2576 m:1B A001 29A083 261118 0108141F
2014.12.19 15:37:14.055 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0100 t:006B2350 d:FF r:FFB7     m:1B A002 261118 29A083 0418AD906DBCAE02
2014.12.19 15:37:14.290 0: HMLAN_Parse: HMLAN1 R:R62FB2576 stat:0021 t:006B2355 d:01 r:FFB7     m:1B 8002 261118 29A083 009F1FF944
2014.12.19 15:37:14.303 0: HMLAN_Send:  HMLAN1 S:S62FB2808 stat:  00 t:00000000 d:01 r:62FB2808 m:1C A001 29A083 261118 0106
2014.12.19 15:37:14.713 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0100 t:006B25E2 d:FF r:FFB7     m:1C A002 261118 29A083 0421A483D7FCBF02
2014.12.19 15:37:14.948 0: HMLAN_Parse: HMLAN1 R:R62FB2808 stat:0021 t:006B25E7 d:01 r:FFB7     m:1C 8002 261118 29A083 009B7A193B
2014.12.19 15:37:15.963 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:37:15.969 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:006B2AE3 IDcnt:000C
2014.12.19 15:37:16.870 0: HMLAN_Send:  HMLAN1 S:+261118,00,01,00
2014.12.19 15:37:16.871 0: HMLAN_Send:  HMLAN1 S:S62FB320E stat:  00 t:00000000 d:01 r:62FB320E m:1D B001 29A083 261118 00040000000000
2014.12.19 15:37:17.399 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B306D d:FF r:FFB7     m:1D A010 261118 29A083 02020103190A290BA00C830000
2014.12.19 15:37:17.509 0: HMLAN_Parse: HMLAN1 R:R62FB320E stat:0001 t:006B3072 d:FF r:FFB7     m:1D A010 261118 29A083 02020103190A290BA00C830000
2014.12.19 15:37:17.518 0: HMLAN_Send:  HMLAN1 S:+261118,00,01,00
2014.12.19 15:37:17.519 0: HMLAN_Send:  HMLAN1 S:S62FB3497 stat:  00 t:00000000 d:01 r:62FB3497 m:1E A001 29A083 261118 0103
2014.12.19 15:37:17.926 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B327C d:FF r:FFB7     m:1E A010 261118 29A083 0126848A0126848A0226848A0429B66501
2014.12.19 15:37:18.033 0: HMLAN_Parse: HMLAN1 R:R62FB3497 stat:0001 t:006B3281 d:FF r:FFB7     m:1E A010 261118 29A083 0126848A0126848A0226848A0429B66501
2014.12.19 15:37:18.169 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3371 d:FF r:FFB8     m:1F A010 261118 29A083 0100000000
2014.12.19 15:37:18.260 0: HMLAN_Send:  HMLAN1 S:S62FB373A stat:  00 t:00000000 d:01 r:62FB373A m:1F A001 29A083 261118 010426848A0103
2014.12.19 15:37:18.699 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3581 d:FF r:FFB8     m:1F A010 261118 29A083 0203000432056407FF0B33830084328564
2014.12.19 15:37:18.806 0: HMLAN_Parse: HMLAN1 R:R62FB373A stat:0001 t:006B3586 d:FF r:FFB8     m:1F A010 261118 29A083 0203000432056407FF0B33830084328564
2014.12.19 15:37:18.943 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3677 d:FF r:FFB8     m:20 A010 261118 29A083 0287FF8B880000
2014.12.19 15:37:19.035 0: HMLAN_Send:  HMLAN1 S:S62FB3A47 stat:  00 t:00000000 d:01 r:62FB3A47 m:20 A001 29A083 261118 010426848A0203
2014.12.19 15:37:19.472 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3886 d:FF r:FFB7     m:20 A010 261118 29A083 0203000432056407FF0B66830084328564
2014.12.19 15:37:19.579 0: HMLAN_Parse: HMLAN1 R:R62FB3A47 stat:0001 t:006B388B d:FF r:FFB7     m:20 A010 261118 29A083 0203000432056407FF0B66830084328564
2014.12.19 15:37:19.715 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B397C d:FF r:FFB7     m:21 A010 261118 29A083 0287FF8B660000
2014.12.19 15:37:19.807 0: HMLAN_Send:  HMLAN1 S:S62FB3D4C stat:  00 t:00000000 d:01 r:62FB3D4C m:21 A001 29A083 261118 010426848A0403
2014.12.19 15:37:20.244 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3B8B d:FF r:FFB7     m:21 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:37:20.352 0: HMLAN_Parse: HMLAN1 R:R62FB3D4C stat:0001 t:006B3B90 d:FF r:FFB7     m:21 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:37:20.488 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3C81 d:FF r:FFB9     m:22 A010 261118 29A083 0287FF8B880000
2014.12.19 15:37:20.580 0: HMLAN_Send:  HMLAN1 S:S62FB4051 stat:  00 t:00000000 d:01 r:62FB4051 m:22 A001 29A083 261118 010429B6650103
2014.12.19 15:37:21.017 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3E90 d:FF r:FFB8     m:22 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:37:21.126 0: HMLAN_Parse: HMLAN1 R:R62FB4051 stat:0001 t:006B3E95 d:FF r:FFB8     m:22 A010 261118 29A083 0203000432056407FF0B88830084328564
2014.12.19 15:37:21.261 0: HMLAN_Parse: HMLAN1 R:E261118   stat:0000 t:006B3F86 d:FF r:FFB8     m:23 A010 261118 29A083 0287FF8B880000
2014.12.19 15:37:40.977 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:37:40.983 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:006B8C9D IDcnt:000C
2014.12.19 15:37:43.888 0: HMLAN_Parse: HMLAN1 R:E2EEC7C   stat:0000 t:006B97ED d:FF r:FFBE     m:14 A610 2EEC7C 29A083 06011800
2014.12.19 15:37:43.979 0: HMLAN_Send:  HMLAN1 S:S62FB9BA4 stat:  00 t:00000000 d:01 r:62FB9BA4 m:14 8002 29A083 2EEC7C 01011800
2014.12.19 15:37:44.275 0: HMLAN_Parse: HMLAN1 R:R62FB9BA4 stat:0002 t:00000000 d:FF r:7FFF     m:14 8002 29A083 2EEC7C 01011800
2014.12.19 15:38:05.983 0: HMLAN_Send:  HMLAN1 I:K
2014.12.19 15:38:05.988 0: HMLAN_Parse: HMLAN1 V:03C4 sNo:LEQ0384784 d:29A083 O:29A083 t:006BEE4E IDcnt:000C
Rampler
So jetzt liefert der get hm configCheck keine Fehler mehr:
configCheck done  :D
Allerdings liefert der getconfig trotzdem noch keine Werte aus der Liste 1
Gruß Klaus
frank
fhem scheint das setzen von holdTime korrekt durchzuführen. die mkeymatic antwortet auch brav. aber die antworten der keymatic überfordern mich und vielleicht fhem.  ;)
das muss sich martin mal genauer anschauen.
du nutzt die keymatic ja ohne aes, wie es aussieht. vielleicht ist das der grund?
ZitatIch habe mal erfolgreich mit den Quttingston gespielt.
ich dachte eigentlich an die fehlenden register.
ZitatSo jetzt liefert der get hm configCheck keine Fehler mehr:
configCheck done  :D
schon mal ein anfang.  8)
gruss frank
Rampler
Zitatdu nutzt die keymatic ja ohne aes, wie es aussieht. vielleicht ist das der grund?
Ich hoffe doch nicht, meiner Einschätzung nach würde die Keymatic ohne AES nichts tun. Habe jedenfalls in der Homematic Konfigurationssoftware ein gesichert stehen, und in der Fhem.cfg steht auch
attr HMLAN1 hmKey 01:749Dxxxxxxxxxxxxxxxxxx73DAB6A40
Ich habe testweise mal ohne hmkey probiert, dann geht gar nix, kein open, Close etc.
Im Wiki steht auch, das die Keymatic zwingend AES brauch, sonst verweigert sie den Dienst, übrigens auch diese Fensteröffner..
Zitatich dachte eigentlich an die fehlenden register.
Und ich dachte dass der Signalton in der List1 steht, sorry mein Fehler.
Habe gerade man die Holdtime auf 5 Sekunden gesetzt, und ja die keymatic hält jetzt den verschluss 5 Sekunden
Zitatfhem scheint das setzen von holdTime korrekt durchzuführen. die mkeymatic antwortet auch brav. aber die antworten der keymatic überfordern mich und vielleicht fhem.  ;)
Also wie oben geschrieben wird's ausgeführt..
Ich kenne jetzt den Martin nicht wirklich, also wie kann man ihn darum bitten ?
Oder hast du einen Draht zu ihm ?
gruß Klaus
frank
ZitatIch hoffe doch nicht, meiner Einschätzung nach würde die Keymatic ohne AES nichts tun.
ok. ich hätte nur gedacht, dass die kommunikation dann anders verläuft. ich nutze aes höchstens mal versehentlich. das wiki sagt auch:
ZitatIn einigen Geräte wie z.B. KeyMatic kann die AES-Signierung nicht abgeschaltet werden. Diese Geräte kommunizieren immer AES-Signiert.
dann sind die antworten der keymatic sicherlich die aes-authentifizierungs-anfragen, die aber unbeantwortet bleiben. bist du sicher, dass du die aes implementierung in fhem richtig durchgeführt hast? kannst du über fhem auf-/zuschliessen?
ZitatIch kenne jetzt den Martin nicht wirklich, also wie kann man ihn darum bitten ?
unser moderator wird das sicherlich lesen, wenn er zeit findet.
Rampler
#9
Zitatdann sind die antworten der keymatic sicherlich die aes-authentifizierungs-anfragen, die aber unbeantwortet bleiben. bist du sicher, dass du die aes implementierung in fhem richtig durchgeführt hast? kannst du über fhem auf-/zuschliessen?
Ja funzt einwandfrei, ich kann die keymatic  über Fhem steuern, also lock unlock und open !
Wie gesagt, deaktiviere ich AES geht nichts mehr..
bin mal gespannt ...
Gruß Klaus
PS:
Ich sollte evtl noch erwähnen, das ich den AES key geändert habe (über HM Software), da ja alle HM Installationen sonst den gleichen Default key hätten.
Ist hier ganz gut beschrieben :
http://www.meintechblog.de/2013/12/hmlan-adapter-system-sicherheitsschluessel-aendern/
Rampler
@Martin
Hattest du schon mal ein Blick drüber werfen können, ich will hier aber keinen hetzen.. 8)
Also immer schön entspannt ..
Gruß Klaus
martinp876
probiere es einmal mit Version 7274 (HMConfig)
dann sollte auch regList 1 gelesen werden.
Bitte einmal das getConfig mitloggen, ob es klappt.
Rampler
Zitatprobiere es einmal mit Version 7274 (HMConfig)
Erstmal Danke für die Antwort, aber bin gerade mit HMconfig überfodert, was soll ich damit machen ?
frank
entweder jetzt hier http://sourceforge.net/p/fhem/code/HEAD/tree/trunk/fhem/FHEM/ die neue version runterladen und in den ordner fhem/FHEM kopieren, oder morgen update machen.
Rampler
Habe jetzt die HMConfig kopiert und alles ist gut !!!!
Der Support hier ist der Hammer !!!
8) DANKE 8)
Gruß Klaus
