[Gelöst] HM-SCI-3-FM fehlende Log Einträge
Begonnen von Rampler, 03 Januar 2015, 15:11:26
Rampler
versuche gerade einen HM-SCI-3-FM  in Betrieb zu nehmen. Leider wird keine sinnvolle Info ins LOG geschrieben.
Auszug aus dem Event Monitor: (was gut aussieht)
2015-01-03 15:07:32 CUL_HM GA.codeschloss battery: ok
2015-01-03 15:07:32 CUL_HM GA.codeschloss CMDs_done
2015-01-03 15:07:32 CUL_HM GA.codeschloss1 trigger_cnt: 26
2015-01-03 15:07:32 CUL_HM GA.codeschloss1 closed
2015-01-03 15:07:32 CUL_HM GA.codeschloss1 contact: closed (to vccu)
2015-01-03 15:07:33 CUL_HM GA.codeschloss battery: ok
2015-01-03 15:07:33 CUL_HM GA.codeschloss1 trigger_cnt: 26
Auszug aus dem LOG: (hier fehlt der Status)
2015-01-03_15:03:48 GA.codeschloss CMDs_done
2015-01-03_15:07:32 GA.codeschloss battery: ok
2015-01-03_15:07:32 GA.codeschloss CMDs_done
2015-01-03_15:07:33 GA.codeschloss battery: ok
2015-01-03_15:07:33 GA.codeschloss CMDs_done
2015-01-03_15:07:34 GA.codeschloss battery: ok
2015-01-03_15:07:34 GA.codeschloss CMDs_done
Ein List device:
   DEF        35C94C01
   NAME       GA.codeschloss1
   NR         145
   STATE      open
   TYPE       CUL_HM
   chanNo     01
   device     GA.codeschloss
   peerList   GA.keymatic,
   Readings:
     2015-01-03 14:49:39   R-GA.keymatic_chn-01-expectAES on
     2015-01-03 14:49:39   R-GA.keymatic_chn-01-peerNeedsBurst on
     2015-01-03 12:46:48   R-eventDlyTime  0 s
     2015-01-03 12:46:48   R-msgScPosA     closed
     2015-01-03 12:46:48   R-msgScPosB     open
     2015-01-03 12:46:48   R-sign          on
     2015-01-03 12:46:48   R-transmitTryMax 6
     2015-01-03 14:49:36   RegL_01:          08:01 20:60 21:00 22:00 30:06 00:00
     2015-01-03 14:49:39   RegL_04:GA.keymatic_chn:01   01:81 00:00
     2015-01-03 15:03:34   contact         open (to GA.keymatic)
     2015-01-03 14:49:36   peerList        GA.keymatic,
     2015-01-03 15:03:34   state           open
     2015-01-03 15:03:34   trigger_cnt     25
   Helper:
     peerIDsRaw ,26110D01,00000000
     Role:
       chn        1
     Shadowreg:
   model      HM-SCI-3-FM
   peerIDs    00000000,26110D01,
   room       Garage
Meine Definitionen:
define GA.codeschloss CUL_HM 35C94C
attr GA.codeschloss IODev HMLAN1
attr GA.codeschloss IOgrp vccu:HMLAN1
attr GA.codeschloss actCycle 028:00
attr GA.codeschloss actStatus alive
attr GA.codeschloss autoReadReg 4_reqStatus
attr GA.codeschloss expert 2_full
attr GA.codeschloss firmware 1.2
attr GA.codeschloss model HM-SCI-3-FM
attr GA.codeschloss room Garage
attr GA.codeschloss serialNr LEQ1455471
attr GA.codeschloss subType threeStateSensor
attr GA.codeschloss webCmd getConfig:clear msgEvents
define FileLog_GA.codeschloss FileLog ./log/GA.codeschloss-%Y.log GA.codeschloss
attr FileLog_GA.codeschloss logtype text
attr FileLog_GA.codeschloss room Garage
define GA.codeschloss1 CUL_HM 35C94C01
attr GA.codeschloss1 model HM-SCI-3-FM
attr GA.codeschloss1 peerIDs 00000000,26110D01,
attr GA.codeschloss1 room Garage
define GA.codeschloss2 CUL_HM 35C94C02
attr GA.codeschloss2 model HM-SCI-3-FM
attr GA.codeschloss2 peerIDs 00000000,
attr GA.codeschloss2 room Garage
define GA.codeschloss3 CUL_HM 35C94C03
attr GA.codeschloss3 model HM-SCI-3-FM
attr GA.codeschloss3 peerIDs 00000000,
attr GA.codeschloss3 room Garage
gruß
Klaus
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Bullseye), ZWAVE, HM-Classic, und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
LuckyDay
lg halt Logs für deine 3 Kanale an :)
im Device steht normalerweise nicht mehr drin
Rampler
Verstehe ich nicht ganz ..   :-[
Alle drei Kanäle loggen in ein File ...
oder meinst du ..
List von Kanal 1:
   DEF        35C94C01
   NR         145
   STATE      open
   TYPE       CUL_HM
   chanNo     01
   Readings:
     2015-01-03 15:17:37   contact         open (to GA.keymatic)
     2015-01-03 15:15:43   peerList        GA.keymatic,
     2015-01-03 15:17:37   state           open
     2015-01-03 15:17:37   trigger_cnt     37
   Helper:
     Role:
       chn        1
   model      HM-SCI-3-FM
   room       Garage
gruß
Klaus
franky08
Hallo, wenn du uns jetzt noch verrätst, wie du das Log definiert hast, dann könnte man vielleicht sehen woran es liegt  ;)
P.S. Bitte in Code Tags posten
VG
Frank
mit FHEM aktuell
LuckyDay
Du hast 4 define
und nur 1 Filelog auf das Device
deinen Kanäle musst du je ein einzelnes Filelog gönnen, Autocreate legt hier halt nicht für jeden Kanal ein Filelog seperat an.
LuckyDay
@franky08
hat er doch gemacht
Rampler
Habe gerade mal ein zusätzliches Log für Codeschloss1 gemacht, da steht dann alles drinn. 8)
Danke für den Hinweis....
Mich wundert es nur, da beim HM-PBI-4-FM auch nur ein LOG definiert ist, und da stehen alle drei Kanäle drin.
Kann ich beim HM-SCI-3-FM  alle drei Kanäle in ein LOG schreiben lassen ?
gruß
Klaus
franky08
Zitat von: fhem-hm-knecht am 03 Januar 2015, 15:33:24
@franky08
hat er doch gemacht
Hab ich glatt übersehen -schäm und weg  :-X
VG
Frank
mit FHEM aktuell
LuckyDay
Wenn du deine Bezeichnungen so lässt
Zitatdefine FileLog_GA.codeschloss FileLog ./log/GA.codeschloss-%Y.log GA.codeschloss.*
wir der .* ausreichen, ansonsten entsprechend ändern
Rampler
Da bleibt mir nur, mich zu bedanken !!
Klaus
8) :) ;)
