Heating_control & a boost override
Begonnen von homer, 18 Februar 2015, 19:45:50
homer
Hello all,
I currently use heating_control to control the temperatures in my rooms. It works well, with an example:
define HeatStudy Heating_Control StudyWallTemp 12345|15:30|19 12345|22:30|12 25|09:00|18 67|09:00|19 67|11:00|16 67|15:00|19 67|22:00|12
what I would like to do is add a boost that would override the daily program and boost the temperatures for a short period (1 hour) with a higher temp. Can anyone advise on how I should do this? I tried the following but realised that it would only check the function of boost at midnight:
define HeatStudy Heating_Control StudyWallTemp 12345|15:30|19 12345|22:30|12 25|09:00|18 67|09:00|19 67|11:00|16 67|15:00|19 67|22:00|12 (Value("1.Boost") eq "no") 1234567|00:00|21 (Value("1.Boost") eq "yes")
Alternatively I could do this:
set StudyWallTemp desiredTemperature 21
but how would I determine the temperature to put the Study back to once the boost period had expired?
Thanks for your help.
Homer
Mitch
Are you using HM?
I would do the following:
1. define a dummy
2. define a DOIF which act on the dummy an set boost on and disable HC for the boost time
3. change the register for boost time from 5 min to the time you need
kein fhem mehr
homer
Hi Mitch,
Thanks for your support. I'm using MAX valves and thermostats.
How do I disable the heating_control?
Thanks
Homer
Mitch
set <device> disable
in your case: set HeatStudy disable
kein fhem mehr
