Probleme mit PMSw1 und SW2 (RESPONSE TIMEOUT:RegisterRead)
Begonnen von new_rasp, 07 März 2015, 14:23:12
new_rasp
hab mir den USB-Stick und
CUL_HM_HM_RC_8_31F21D
CUL_HM_HM_ES_PMSw1_Pl_2DA617
CUL_HM_HM_Sen_MDIR_O_2_27DD2E
CUL_HM_HM_LC_SW2_FM_2A112A
geholt.
Jetzt komm ich aber nicht weiter. Die beiden Switches lassen sich beide nicht richtig pairen. Bekomme dann folgende Logs (Auszug):
2015-03-07_13:40:05 CUL_HM_HM_LC_SW2_FM_2A112A D-firmware: 1.12
2015-03-07_13:40:05 CUL_HM_HM_LC_SW2_FM_2A112A D-serialNr: LEQ0236228
2015-03-07_13:40:19 CUL_HM_HM_LC_SW2_FM_2A112A D-firmware: 1.12
2015-03-07_13:40:19 CUL_HM_HM_LC_SW2_FM_2A112A D-serialNr: LEQ0236228
2015-03-07_13:40:41 CUL_HM_HM_LC_SW2_FM_2A112A D-firmware: 1.12
2015-03-07_13:40:41 CUL_HM_HM_LC_SW2_FM_2A112A D-serialNr: LEQ0236228
2015-03-07_13:40:45 CUL_HM_HM_LC_SW2_FM_2A112A ResndFail
2015-03-07_13:40:45 CUL_HM_HM_LC_SW2_FM_2A112A CMDs_done_Errors:1
2015-03-07_13:40:45 CUL_HM_HM_LC_SW2_FM_2A112A RESPONSE TIMEOUT:RegisterRead
2015-03-07_13:55:09 CUL_HM_HM_LC_SW2_FM_2A112A CMDs_pending
2015-03-07_13:55:28 CUL_HM_HM_LC_SW2_FM_2A112A ResndFail
2015-03-07_13:55:28 CUL_HM_HM_LC_SW2_FM_2A112A CMDs_done_Errors:1
2015-03-07_13:55:28 CUL_HM_HM_LC_SW2_FM_2A112A RESPONSE TIMEOUT:RegisterRead
und:
2015-03-07_13:59:50 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_13:59:50 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_13:59:50 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:00:12 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_14:00:12 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_14:00:12 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:00:12 CUL_HM_HM_ES_PMSw1_Pl_2DA617 ResndFail
2015-03-07_14:00:12 CUL_HM_HM_ES_PMSw1_Pl_2DA617 CMDs_done_Errors:1
2015-03-07_14:00:12 CUL_HM_HM_ES_PMSw1_Pl_2DA617 RESPONSE TIMEOUT:PeerList
2015-03-07_14:00:17 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_14:00:17 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_14:00:17 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:00:22 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_14:00:22 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_14:00:22 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:00:26 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_14:00:26 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_14:00:26 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:00:28 CUL_HM_HM_ES_PMSw1_Pl_2DA617 CMDs_pending
2015-03-07_14:00:51 CUL_HM_HM_ES_PMSw1_Pl_2DA617 ResndFail
2015-03-07_14:00:51 CUL_HM_HM_ES_PMSw1_Pl_2DA617 CMDs_done_Errors:1
2015-03-07_14:00:51 CUL_HM_HM_ES_PMSw1_Pl_2DA617 RESPONSE TIMEOUT:PeerList
2015-03-07_14:01:13 CUL_HM_HM_ES_PMSw1_Pl_2DA617 powerOn: 2015-03-07 14:01:13
2015-03-07_14:01:15 CUL_HM_HM_ES_PMSw1_Pl_2DA617 CMDs_pending
2015-03-07_14:01:23 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_14:01:23 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_14:01:23 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:01:36 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-firmware: 1.6
2015-03-07_14:01:36 CUL_HM_HM_ES_PMSw1_Pl_2DA617 D-serialNr: LEQ0529121
2015-03-07_14:01:36 CUL_HM_HM_ES_PMSw1_Pl_2DA617 Activity: alive
2015-03-07_14:01:57 CUL_HM_HM_ES_PMSw1_Pl_2DA617 ResndFail
2015-03-07_14:01:57 CUL_HM_HM_ES_PMSw1_Pl_2DA617 CMDs_done_Errors:1
2015-03-07_14:01:57 CUL_HM_HM_ES_PMSw1_Pl_2DA617 RESPONSE TIMEOUT:RegisterRead
2015-03-07_14:03:57 CUL_HM_HM_ES_PMSw1_Pl_2DA617 powerOn: 2015-03-07 14:03:57
2015-03-07_14:06:29 CUL_HM_HM_ES_PMSw1_Pl_2DA617 powerOn: 2015-03-07 14:06:29
Der Status in der Übersicht (CUL HM) wechselt immer zwischen RESPONSE TIMEOUT:RegisterRead bzw. nach einer gewissen Zeit missing ACK.
Hab mehrmals nen Hardware-Reset versucht mit neu anmelden. Bleibt immer wieder da hängen. Pairen hab ich auch mehrmals hintereinander versucht. Der PMSw1 blinkt hier auch kurz schnell orange aber das Problem besteht dann weiterhin.
Verstehe nicht was ich falsch mache. getConfig hat bei der Fernbedienung auch sofort funktioniert... Beim Bewegungsmelder muss das gleich beim pairen funktioniert haben weil hier hab ich nichts manuell durchgeführt.
Ich hoffe das ich nicht irgendwas übersehen bzw. überlesen habe.
martinp876
new_rasp
Anscheinend noch nicht richtig bzw. nicht vollständig weil die Settings nicht gelesen werden können (RESPONSE TIMEOUT:RegisterRead).
Hier noch ein list von den Geräten:
   DEF        2DA617
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     31
   NAME       CUL_HM_HM_ES_PMSw1_Pl_2DA617
   NR         24
   STATE      MISSING ACK
   TYPE       CUL_HM
   channel_01 CUL_HM_HM_ES_PMSw1_Pl_2DA617_Sw
   channel_02 CUL_HM_HM_ES_PMSw1_Pl_2DA617_Pwr
   channel_03 CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenPwr
   channel_04 CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenI
   channel_05 CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenU
   channel_06 CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenF
   hmusb_MSGCNT 31
   hmusb_RAWMSG E2DA617,0000,002D4EF2,FF,FFDD,02845E2DA61700000080000000000000000928FC
   hmusb_RSSI -35
   hmusb_TIME 2015-03-07 14:06:29
   lastMsg    No:37 - t:5E s:2DA617 d:000000 80000000000000000901FD
   protCmdDel 93
   protLastRcv 2015-03-07 16:20:11
   protResnd  43 last_at:2015-03-07 16:20:14
   protResndFail 11 last_at:2015-03-07 16:20:18
   protSnd    21 last_at:2015-03-07 16:19:59
   protState  CMDs_done_Errors:1
   rssi_at_hmusb avg:-42.09 min:-61 max:-34 lst:-37 cnt:106
   Readings:
     2015-03-07 14:01:36   Activity        alive
     2015-03-07 14:01:36   D-firmware      1.6
     2015-03-07 14:01:36   D-serialNr      LEQ0529121
     2015-03-07 14:01:25   PairedTo        0x0
     2015-03-07 13:36:31   R-intKeyVisib   invisib
     2015-03-07 13:36:31   R-localResDis   off
     2015-03-07 13:36:31   R-pairCentral   0x0
     2015-03-07 14:01:25   RegL_00:          02:00 0A:00 0B:00 0C:00 18:00 00:00
     2015-03-07 14:06:29   powerOn         2015-03-07 14:06:29
     2015-03-07 16:20:18   state           MISSING ACK
   Helper:
     cSnd       11354D4E2DA6170201C80000BB81
     mId        00AC
     rxType     1
     Io:
       newChn     +2DA617,00,01,00
       nextSend   1425741611.35954
       prefIO
       rxt        0
       vccu
       p:
         2DA617
         00
         01
         00
     Mrssi:
       mNo        37
       Io:
         hmusb      -35
     Prt:
       bErr       0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmusb:
         avg        -42.0943396226415
         cnt        106
         lst        -37
         max        -34
         min        -61
     Shadowreg:
   IODev      hmusb
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_full
   firmware   1.6
   model      HM-ES-PMSw1-Pl
   room       CUL_HM
   serialNr   LEQ0529121
   subType    powerMeter
   webCmd     getConfig:clear msgEvents
SW2:
   CFGFN
   DEF        2A112A
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     34
   NAME       CUL_HM_HM_LC_SW2_FM_2A112A
   NR         52
   STATE      RESPONSE TIMEOUT:RegisterRead
   TYPE       CUL_HM
   channel_01 CUL_HM_HM_LC_SW2_FM_2A112A_Sw_01
   channel_02 CUL_HM_HM_LC_SW2_FM_2A112A_Sw_02
   hmusb_MSGCNT 34
   hmusb_RAWMSG E2A112A,0000,0015AE56,FF,FFD1,4D84002A112A0000001C00094C45513032333632323810020200
   hmusb_RSSI -47
   hmusb_TIME 2015-03-07 13:40:41
   lastMsg    No:51 - t:10 s:2A112A d:000000 06020000
   protCmdDel 34
   protLastRcv 2015-03-07 16:20:02
   protResnd  36 last_at:2015-03-07 13:55:23
   protResndFail 8 last_at:2015-03-07 13:55:28
   protSnd    31 last_at:2015-03-07 13:55:09
   rssi_at_hmusb avg:-37.09 min:-55 max:-22 lst:-36 cnt:41
   rssi_hmusb avg:-29 min:-29 max:-29 lst:-29 cnt:1
   Readings:
     2015-03-07 13:40:41   D-firmware      1.12
     2015-03-07 13:40:41   D-serialNr      LEQ0236228
     2015-03-07 13:39:57   PairedTo        0x0
     2015-03-07 13:29:02   R-intKeyVisib   invisib
     2015-03-07 13:29:02   R-pairCentral   0x0
     2015-03-07 13:55:28   state           RESPONSE TIMEOUT:RegisterRead
     Regl_00::
       VAL
   Helper:
     cSnd       01354D4E2A112A00040000000000
     mId        0009
     rxType     1
     Io:
       newChn     +2A112A,00,01,00
       nextSend   1425741602.1822
       prefIO
       rxt        0
       vccu
       p:
         2A112A
         00
         01
         00
     Mrssi:
       mNo        51
       Io:
         hmusb      -34
     Prt:
       bErr       0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmusb:
         avg        -37.0975609756098
         cnt        41
         lst        -36
         max        -22
         min        -55
       Hmusb:
         avg        -29
         cnt        1
         lst        -29
         max        -29
         min        -29
     Shadowreg:
   IODev      hmusb
   expert     2_full
   firmware   1.12
   model      HM-LC-SW2-FM
   room       CUL_HM
   serialNr   LEQ0236228
   subType    switch
new_rasp
Über die Seriennummer hab ich es noch nicht probiert. Nur über die Anlernfunktion vom Gerät.
martinp876
das list bringt nichts - ggf sind die logs interessant. Probiere es erst noch einmal, dann die Logs.
new_rasp
Okay! Hab versucht beim PMSw1 getConfig zwei mal und danach den SW2 "neu" angelernt ab 17:05. Hab das andere auch gepostet. Evtl hilfts ja was. :)
Hier die Logs:
2015.03.07 17:02:19 3: Device CUL_HM_HM_ES_PMSw1_Pl_2DA617 added to ActionDetector with 000:10 time
2015.03.07 17:03:46 1: Including fhem.cfg
2015.03.07 17:03:46 3: telnetPort: port 7072 opened
2015.03.07 17:03:46 3: WEB: port 8083 opened
2015.03.07 17:03:46 3: WEBphone: port 8084 opened
2015.03.07 17:03:46 3: WEBtablet: port 8085 opened
2015.03.07 17:03:46 2: eventTypes: loaded 215 events from ./log/eventTypes.txt
2015.03.07 17:03:46 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.07 17:03:46 3: Opening hmusb device 127.0.0.1:1234
2015.03.07 17:03:46 3: hmusb device opened
2015.03.07 17:03:46 1: HMLAN_Parse: hmusb new condition init
2015.03.07 17:03:46 1: Including ./log/fhem.save
2015.03.07 17:03:48 1: HMLAN_Parse: hmusb new condition ok
2015.03.07 17:03:51 3: Device CUL_HM_HM_ES_PMSw1_Pl_2DA617 added to ActionDetector with 000:10 time
2015.03.07 17:03:51 3: Device CUL_HM_HM_Sen_MDIR_O_2_27DD2E added to ActionDetector with 000:10 time
2015.03.07 17:03:52 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_Sw statusRequest
2015.03.07 17:03:53 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_Pwr statusRequest
2015.03.07 17:03:54 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenPwr statusRequest
2015.03.07 17:03:55 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenI statusRequest
2015.03.07 17:03:56 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenU statusRequest
2015.03.07 17:03:57 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenF statusRequest
2015.03.07 17:04:09 1: Including fhem.cfg
2015.03.07 17:04:09 3: telnetPort: port 7072 opened
2015.03.07 17:04:09 3: WEB: port 8083 opened
2015.03.07 17:04:09 3: WEBphone: port 8084 opened
2015.03.07 17:04:09 3: WEBtablet: port 8085 opened
2015.03.07 17:04:09 2: eventTypes: loaded 215 events from ./log/eventTypes.txt
2015.03.07 17:04:09 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.07 17:04:09 3: Opening hmusb device 127.0.0.1:1234
2015.03.07 17:04:09 3: hmusb device opened
2015.03.07 17:04:09 1: HMLAN_Parse: hmusb new condition init
2015.03.07 17:04:09 1: Including ./log/fhem.save
2015.03.07 17:04:09 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617 getConfig
2015.03.07 17:04:11 1: HMLAN_Parse: hmusb new condition ok
2015.03.07 17:04:14 3: Device CUL_HM_HM_ES_PMSw1_Pl_2DA617 added to ActionDetector with 000:10 time
2015.03.07 17:04:14 3: Device CUL_HM_HM_Sen_MDIR_O_2_27DD2E added to ActionDetector with 000:10 time
2015.03.07 17:04:15 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_Sw statusRequest
2015.03.07 17:04:16 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_Pwr statusRequest
2015.03.07 17:04:17 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenPwr statusRequest
2015.03.07 17:04:18 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenI statusRequest
2015.03.07 17:04:19 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenU statusRequest
2015.03.07 17:04:20 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenF statusRequest
2015.03.07 17:04:30 1: 127.0.0.1:1234 disconnected, waiting to reappear (hmusb)
2015.03.07 17:04:30 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.07 17:04:30 0: Server shutdown
2015.03.07 17:04:39 1: Including fhem.cfg
2015.03.07 17:04:39 3: telnetPort: port 7072 opened
2015.03.07 17:04:39 3: WEB: port 8083 opened
2015.03.07 17:04:39 3: WEBphone: port 8084 opened
2015.03.07 17:04:39 3: WEBtablet: port 8085 opened
2015.03.07 17:04:39 2: eventTypes: loaded 263 events from ./log/eventTypes.txt
2015.03.07 17:04:39 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.07 17:04:39 3: Opening hmusb device 127.0.0.1:1234
2015.03.07 17:04:39 3: hmusb device opened
2015.03.07 17:04:39 1: HMLAN_Parse: hmusb new condition init
2015.03.07 17:04:40 1: Including ./log/fhem.save
2015.03.07 17:04:40 1: usb create starting
2015.03.07 17:04:41 3: Probing CUL device /dev/ttyAMA0
2015.03.07 17:04:41 3: Probing TCM_ESP3 device /dev/ttyAMA0
2015.03.07 17:04:41 3: Probing FRM device /dev/ttyAMA0
2015.03.07 17:04:46 1: usb create end
2015.03.07 17:04:46 2: SecurityCheck:  WEB,WEBphone,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2015.03.07 17:04:46 0: Server started with 33 defined entities (version $Id: fhem.pl 6913 2014-11-08 10:32:44Z rudolfkoenig $, os linux, user fhem, pid 2059)
2015.03.07 17:04:46 3: Device CUL_HM_HM_ES_PMSw1_Pl_2DA617 added to ActionDetector with 000:10 time
2015.03.07 17:04:47 3: Device CUL_HM_HM_Sen_MDIR_O_2_27DD2E added to ActionDetector with 000:10 time
2015.03.07 17:04:47 1: HMLAN_Parse: hmusb new condition ok
2015.03.07 17:04:48 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_Sw statusRequest
2015.03.07 17:05:13 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_Pwr statusRequest
2015.03.07 17:05:14 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenPwr statusRequest
2015.03.07 17:05:15 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenI statusRequest
2015.03.07 17:05:16 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenU statusRequest
2015.03.07 17:05:17 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617_SenF statusRequest
2015.03.07 17:05:30 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617 getConfig
2015.03.07 17:05:40 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617 getConfig
2015.03.07 17:05:59 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617 getConfig
2015.03.07 17:06:06 3: Device CUL_HM_HM_ES_PMSw1_Pl_2DA617 added to ActionDetector with 000:10 time
2015.03.07 17:06:30 3: Device CUL_HM_HM_ES_PMSw1_Pl_2DA617 added to ActionDetector with 000:10 time
2015.03.07 17:06:34 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_2DA617 getConfig
2015.03.07 17:07:24 3: CUL_HM set CUL_HM_HM_LC_SW2_FM_2A112A_Sw_01 statusRequest
2015.03.07 17:07:25 3: CUL_HM set CUL_HM_HM_LC_SW2_FM_2A112A_Sw_01 getConfig
2015.03.07 17:07:45 3: CUL_HM set CUL_HM_HM_LC_SW2_FM_2A112A_Sw_02 getConfig
new_rasp
So jetzt geht´s auch bei mir. Bin nochmal zurück auf Anfang (Backup) und hab es nochmals Schritt für Schritt durchgeführt. Jetzt funktioniert das pairen! Hatte da schon paar Sachen konfiguriert und evtl hab ich da was verstellt!
Thema kann also zu.
Aber Dankeschön fürs helfen!
