Fehlermeldung bezüglich 57_CALVIEW.pm seit Update
Begonnen von FHEm2005, 20 August 2015, 09:15:23
FHEm2005
Seit dem heutigen Update (08:50) bekomme ich im Log folgende Warnings:
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at ./FHEM/57_CALVIEW.pm line 111.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/57_CALVIEW.pm line 167.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/57_CALVIEW.pm line 165.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 161.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 159.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 158.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value $tempvar[2] in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 158.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/57_CALVIEW.pm line 157.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 94.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value $Y in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 94.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value $D in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 94.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value $M in concatenation (.) or string at ./FHEM/57_CALVIEW.pm line 94.
2015.08.20 09:04:06 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/57_CALVIEW.pm line 93.
Kann das aus den Neuerungen des Kalenders herrühren?
Gruß Eberhard
Raspi3: FHEM,nanoCUL433 (V 1.67 nanoCUL433), Busware-CUL868 (V1.66 CUL868); HUE-Bridge (2015); 3xRaspi4 (Node-red, MQTT, FHEM)1x RasPi3(LMS) Gaszähler auslesen mit ESP32-CAM, Heizungsbedienung (Brötje) mit BSB-LAN
FHEm2005
Ich habe nicht aufgepasst und 57_CALVIEW mit 57_Calendar durcheinander geworfen. Kein Wunder, dass darauf niemand geantwortet hat.
Zusätzlich sind die Fehlermeldungen auf einmal nicht mehr da. Hat der Server wohl einen scdhlechten Tag gehabt.
Ich schlage vor diesen Thread zu löschen oder als schlechtes Beispiel zu belassen.....
Gruß Eberhard
