Warning-HighLoad immer wieder bei FHEM neustart
Begonnen von HoTi, 09 September 2015, 14:07:58
HoTi
kann mir vielelicht jemand sagen was ich falsch mache? Eigendlich habe ich an dem Homematic Geräte heute gar nicht gearbeitet?!
Hier mal der restart start Log:
Smartmatch is experimental at ./FHEM/99_MyUtils.pm line 165.
Smartmatch is experimental at ./FHEM/99_MyUtils.pm line 168.
2015.09.09 14:04:42 1: Including fhem.cfg
2015.09.09 14:04:42 3: telnetPort: port 7072 opened
2015.09.09 14:04:42 3: tPortLocal: port 7073 opened
2015.09.09 14:04:43 3: WEB: port 8083 opened
2015.09.09 14:04:43 3: WEB_SET: port 8085 opened
2015.09.09 14:04:43 2: eventTypes: loaded 5093 events from /opt/fhem/log/eventTypes.txt
Useless use of \E at ./FHEM/74_AMAD.pm line 326, <$fh> line 70.
2015.09.09 14:04:43 3: AMAD (Display_Flur) - defined with host 192.168.178.42 on port 192.168.178.42 and interval 180 (sec)
2015.09.09 14:04:44 1: HMLAN_Parse: hmusb new condition disconnected
2015.09.09 14:04:44 3: Opening hmusb device 127.0.0.1:1234
2015.09.09 14:04:44 3: hmusb device opened
2015.09.09 14:04:44 1: HMLAN_Parse: hmusb new condition init
2015.09.09 14:04:54 3: OWTHERM: Device 05_Aquarium_T1 defined.
2015.09.09 14:04:54 3: Opening FHEMduino device /dev/fhemduino
2015.09.09 14:04:54 3: Setting FHEMduino serial parameters to 9600,8,N,1
2015.09.09 14:04:54 3: FHEMduino device opened
2015.09.09 14:04:57 3: FHEMduino: Possible commands: VifdhtRq
2015.09.09 14:04:57 3: Define: EG_wz_LI_Vitrine FHEMduino_PT2262 FF0F00FFFF 324 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F00FFFF}{EG_wz_LI_Vitrine}
2015.09.09 14:04:57 3: Define: EG_wz_LI_Frau FHEMduino_PT2262 FF0F0F0FFF 324 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F0F0FFF}{EG_wz_LI_Frau}
2015.09.09 14:04:57 3: Define: Display_FLUR_power FHEMduino_PT2262 FF0F0FFF0F 324 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F0FFF0F}{Display_FLUR_power}
2015.09.09 14:04:57 3: Define: EG_ez_LI_Sideboard FHEMduino_PT2262 FF0F0FF0FF 323 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F0FF0FF}{EG_ez_LI_Sideboard}
2015.09.09 14:04:57 3: wetter_aschau: Defined with URL http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=IBAYERNA15 and interval 600
given is experimental at ./FHEM/59_PROPLANTA.pm line 515, <$fh> line 768.
when is experimental at ./FHEM/59_PROPLANTA.pm line 517, <$fh> line 768.
when is experimental at ./FHEM/59_PROPLANTA.pm line 521, <$fh> line 768.
2015.09.09 14:05:01 3: Opening my_callmonitor device 192.168.178.1:1012
2015.09.09 14:05:01 3: my_callmonitor device opened
2015.09.09 14:05:01 3: FB_CALLMONITOR (my_callmonitor) - loading cache file /opt/fhem/callmoncache.txt
2015.09.09 14:05:01 2: FB_CALLMONITOR (my_callmonitor) - read 56 contacts from Cache
Subroutine hex2bin redefined at ./FHEM/14_FHEMduino_FA20RF.pm line 321, <$fh> line 1585.
2015.09.09 14:05:02 3: FHEM2FHEM opening FHEM_Keller at 192.168.178.45:7072
2015.09.09 14:05:02 3: FHEM2FHEM device opened (FHEM_Keller)
2015.09.09 14:05:02 1: Including /opt/fhem/log/fhem.save
2015.09.09 14:05:04 1: statefile: Undefined value 13264
2015.09.09 14:05:04 3: Device EG_TH added to ActionDetector with 012:00 time
2015.09.09 14:05:04 3: Device EG_ez_TK_mi added to ActionDetector with 028:00 time
2015.09.09 14:05:04 3: Device EG_fl_RT_tuer added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device EG_wc_FK_mi added to ActionDetector with 028:00 time
2015.09.09 14:05:04 3: Device EG_wz_RT_links added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device EG_wz_RT_rechts added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device EG_wz_TC added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device GT_ga_BM_gartenlicht added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device OC3 added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device OG_TH added to ActionDetector with 012:00 time
2015.09.09 14:05:04 3: Device OG_az_FK_dach added to ActionDetector with 028:00 time
2015.09.09 14:05:05 3: Device OG_bz_FK_dach added to ActionDetector with 028:00 time
2015.09.09 14:05:05 3: Device OG_bz_RT_links added to ActionDetector with 000:10 time
2015.09.09 14:05:05 3: Device OG_bz_RT_rechts added to ActionDetector with 000:10 time
2015.09.09 14:05:05 3: Device Waesche added to ActionDetector with 000:10 time
2015.09.09 14:05:05 3: Opening FIRMATA device /dev/firmata
2015.09.09 14:05:05 3: Setting FIRMATA serial parameters to 57600,8,N,1
2015.09.09 14:05:05 3: FIRMATA device opened
2015.09.09 14:05:07 3: querying Firmata Firmware Version
2015.09.09 14:05:08 3: querying Firmata Firmware Version
2015.09.09 14:05:08 3: Firmata Firmware Version: ConfigurableFirmata.ino V_2_06
2015.09.09 14:05:09 1: OWX: 1-Wire bus Temperatur: interface Firmata detected in FIRMATA
2015.09.09 14:05:09 1: usb create starting
2015.09.09 14:05:10 1: usb create end
2015.09.09 14:05:11 3: mailcheck: connected to w009a9dc.kasserver.com
2015.09.09 14:05:11 3: mailcheck: logged in to system@horenkamp.net
2015.09.09 14:05:13 2: Error messages while initializing FHEM: statefile: Undefined value 13264
2015.09.09 14:05:13 0: Featurelevel: 5.6
2015.09.09 14:05:13 0: Server started with 277 defined entities (version $Id: fhem.pl 9195 2015-09-03 07:23:40Z rudolfkoenig $, os linux, user fhem, pid 26564)
2015.09.09 14:05:13 3: CUL_HM set EG_ez_RO_mi_SW_01 statusRequest
2015.09.09 14:05:13 1: HMLAN_Parse: hmusb new condition Warning-HighLoad
2015.09.09 14:05:14 3: CUL_HM set EG_ez_RO_mi_SW_02 statusRequest
2015.09.09 14:05:15 1: HMLAN_Parse: hmusb new condition ok
2015.09.09 14:05:15 3: CUL_HM set EG_ez_RO_mi_HOCH statusRequest
2015.09.09 14:05:16 3: CUL_HM set EG_ez_RO_mi_RUNTER statusRequest
2015.09.09 14:05:17 3: CUL_HM set EG_ku_RO_mi_SW_01 statusRequest
2015.09.09 14:05:18 3: CUL_HM set EG_ku_RO_mi_SW_02 statusRequest
2015.09.09 14:05:19 1: OWX: 1-Wire devices found on bus Temperatur (05_Aquarium_T1)
2015.09.09 14:05:19 3: CUL_HM set EG_ku_RO_mi_RUNTER statusRequest
2015.09.09 14:05:20 3: CUL_HM set EG_ku_RO_mi_HOCH statusRequest
2015.09.09 14:05:21 3: CUL_HM set EG_wc_RO_mi_SW_01 statusRequest
2015.09.09 14:05:22 3: CUL_HM set EG_wc_RO_mi_SW_02 statusRequest
2015.09.09 14:05:23 3: CUL_HM set EG_wc_RO_mi_HOCH statusRequest
2015.09.09 14:05:24 3: CUL_HM set EG_wc_RO_mi_RUNTER statusRequest
2015.09.09 14:05:25 3: CUL_HM set EG_wz_RO_li_SW_01 statusRequest
2015.09.09 14:05:26 3: CUL_HM set EG_wz_RO_li_SW_02 statusRequest
2015.09.09 14:05:27 3: CUL_HM set EG_wz_RO_li_HOCH statusRequest
2015.09.09 14:05:28 3: CUL_HM set EG_wz_RO_li_RUNTER statusRequest
2015.09.09 14:05:29 3: CUL_HM set EG_wz_RO_re_SW_01 statusRequest
2015.09.09 14:05:30 3: CUL_HM set EG_wz_RO_re_SW_02 statusRequest
2015.09.09 14:05:31 3: CUL_HM set EG_wz_RO_re_HOCH statusRequest
2015.09.09 14:05:33 3: CUL_HM set EG_wz_RO_re_RUNTER statusRequest
2015.09.09 14:05:34 3: CUL_HM set OG_kz_RO_mi_SW_01 statusRequest
2015.09.09 14:05:35 3: CUL_HM set OG_kz_RO_mi_SW_02 statusRequest
2015.09.09 14:05:35 1: HMLAN_Parse: hmusb new condition Warning-HighLoad
2015.09.09 14:05:36 3: CUL_HM set OG_kz_RO_mi_RUNTER statusRequest
2015.09.09 14:05:37 3: CUL_HM set OG_kz_RO_mi_HOCH statusRequest
2015.09.09 14:05:38 3: CUL_HM set OG_sz_RO_mi_SW_01 statusRequest
2015.09.09 14:05:39 3: CUL_HM set OG_sz_RO_mi_SW_02 statusRequest
2015.09.09 14:05:40 3: CUL_HM set OG_sz_RO_mi_HOCH statusRequest
2015.09.09 14:05:41 3: CUL_HM set OG_sz_RO_mi_RUNTER statusRequest
2015.09.09 14:05:42 3: CUL_HM set Waesche_Sw statusRequest
2015.09.09 14:05:43 3: CUL_HM set Waesche_Pwr statusRequest
Viele Grüße aus  Oberbayern
Tim (RettungsTim)
frank
Zitatkann mir vielelicht jemand sagen was ich falsch mache?
was genau meinst du?
ZitatEigendlich habe ich an dem Homematic Geräte heute gar nicht gearbeitet?!
was meinst du wohl. was hier passiert?
schau dir die load in hmlan internals an. oder hminfo msgstat oder protoevents.
FHEM: 6.0(SVN) => Pi3(buster)
mgernoth
frank hat eigentlich schon alles gesagt.
Aber die automatischen Statusrequests sollten nicht hierzu fuehren:
Fhem sollte bei batchLevel aufhoeren, neue Nachrichten zu senden.
Ich vermute eine alte Firmware auf dem HM-CFG-USB (< 0.967) und/oder einen alten hmland (<0.100). Am besten beides auf die aktuellen Versionen (0.967/0.101) aktualisieren.
Viele Gruesse
  Michael
frank
#3
stimmt, die aktuelle load ist dann immer 0%.  ;)
da müsste martin eigentlich eine warnmeldung einbauen. wenn condition highload oder overload und die aktuelle load=0% => "warning: io load error".
HoTi
HM-CFG-USB = 0.967
hmland = 101
Also daran sollte es nicht liegen. Ich werde es mal weiter beobachten.  Bis jetzt kein HighLoad mehr. Trotzdem verstehe ich das nicht. Ich habe das immer wieder mal...
Tim (RettungsTim)
frank
Zitatschau dir die load in hmlan internals an. oder hminfo msgstat oder protoevents.
wo sind die infos?
HoTi
Hallo Frank,
sorry irgendwie unter gegangen:
msg statistics
  receive hour  :| 00| 01| 02| 03| 04| 05| 06| 07| 08| 09| 10| 11| 12| 13| 14| 15| 16| 17| 18| 19| 20| 21| 22| 23
      hmusb     :|263|258|258|255|260|258|259|450|329|348|  0|  0|  0|  0|299|255|288|272|267|265|256|254|259|260
  send    hour  :| 00| 01| 02| 03| 04| 05| 06| 07| 08| 09| 10| 11| 12| 13| 14| 15| 16| 17| 18| 19| 20| 21| 22| 23
      hmusb     :| 10| 10|  8|  8| 18|  6|  7|217| 85|184|  0|  0|  0|  0| 80| 14| 57| 22| 24| 23| 12|  6| 10|  8
  receive day   :| Mon| Tue| Wed| Thu| Fri| Sat| Sun|# tdy
      hmusb     :|   0|   0|   0|2675|   0|   0|   0|#5613
  send    day   :| Mon| Tue| Wed| Thu| Fri| Sat| Sun|# tdy
      hmusb     :|   0|   0|   0| 256|   0|   0|   0|# 809
protoEvents done:
    name                 :State           |CmdPend   |Snd       |Resnd     #CmdDel    |ResndFail |Nack      |IOerr
    EG_TH                :  -             | -        | -        | -        # -        | -        | -        | -
    EG_ez_RO_mi          : done           | -        |12:       |1:        #12        | -        | -        |4:
    EG_ez_TK_mi          :  -             | -        | -        | -        # -        | -        | -        | -
    EG_fl_BM_display     : done           | -        |22:       | -        # -        | -        | -        | -
    EG_fl_RT_tuer        :  -             | -        | -        | -        # -        | -        | -        | -
    EG_ku_RO_mi          : done           | -        |11:       | -        #9         | -        | -        |3:
    EG_wc_FK_mi          :  -             | -        | -        | -        # -        | -        | -        | -
    EG_wc_RO_mi          : done           | -        |10:       |1:        #6         | -        | -        |2:
    EG_wz_RO_li          : done           | -        |9:        |1:        #3         | -        | -        |1:
    EG_wz_RO_re          : done           | -        |8:        | -        # -        | -        | -        | -
    EG_wz_RT_links       :  -             | -        | -        | -        # -        | -        | -        | -
    EG_wz_RT_rechts      :  -             | -        | -        | -        # -        | -        | -        | -
    EG_wz_TC             :  -             | -        | -        | -        # -        | -        | -        | -
    GT_ga_BM_gartenlicht : done           | -        |8:        | -        # -        | -        | -        | -
    GT_ga_RS_modul       :  -             | -        | -        | -        # -        | -        | -        | -
    OC3                  :  -             | -        | -        | -        # -        | -        | -        | -
    OG_TH                :  -             | -        | -        | -        # -        | -        | -        | -
    OG_az_FK_dach        :  -             | -        | -        | -        # -        | -        | -        | -
    OG_bz_FK_dach        :  -             | -        | -        | -        # -        | -        | -        | -
    OG_bz_RT_links       :  -             | -        | -        | -        # -        | -        | -        | -
    OG_bz_RT_rechts      :  -             | -        | -        | -        # -        | -        | -        | -
    OG_kz_RO_mi          : done           | -        |8:        | -        # -        | -        | -        | -
    OG_sz_RO_mi          : done           | -        |8:        | -        # -        | -        | -        | -
    Waesche              : done           | -        |183:      | -        # -        | -        | -        | -
    vccu                 :  -             | -        | -        | -        # -        | -        | -        | -
    sum                  0                |0         |279       |3         #30        |0         |0         |10
    CUL_HM queue length:0
    requests pending
    autoReadReg          :
        recent           : none
    status request       :
    autoReadReg wakeup   : EG_ez_TK_mi EG_wc_FK_mi
    status request wakeup:
    autoReadTest         :
    IODevs:hmusb:opened pending=0 condition:ok
Tim (RettungsTim)
frank
da siehst du doch sehr schön, dass an dein device "waesche" 183 msgs gesendet wurden (protoevents). die tabelle wird, glaube ich nach reset gelöscht. unter msgstat ist dieser wert quasi 1:1 (184) in der aktuellen stunde (09) bei hmusb send zu finden. zwischen 7 und 8 uhr sind auch verhältnismässig viele msgs in einer stunde gesendet worden (217).
ich vermute, du hast eine energiemesssteckdose, um das ende des waschens zu erkennen. heute bereits 2x gewaschen? du musst die steckdose anders einstellen, sodass weniger messwerte gesendet werden. fhem muss alle msgs beantworten.
ausserdem wartet fhem auf deine fensterkontakte (?).
die melden sich aber wahrscheinlich nicht von selbst. hminfo configcheck wird dir sagen was da los ist. wahrscheinlich mal getconfig machen und anschliessend sichern.
was ist mit der aktuellen load vom hmusb? poste ein list.
HoTi
Ja auf den Fesnterkontakt wird gewartet. Den muss ich noch betätigen.
2x Gewaschen, das kann hinkommen meine Frau ist heute zuhause  ;D
Wie muss ich den anderes einstellen?!
Hier der List vom hmusb, ich denke den willst du haben?!
   DEF        127.0.0.1:1234
   DeviceName 127.0.0.1:1234
   FD         14
   IFmodel    USB
   NAME       hmusb
   NR         77
   NTFY_ORDER 50-hmusb
   PARTIAL
   RAWMSG     E3BB343,0000,316293E0,FF,FFC9,80A45F3BB3432516B781DBDA0001B3003A092701
   RSSI       -55
   STATE      opened
   TYPE       HMLAN
   XmitOpen   1
   assignedIDsCnt 24
   hmusb_MSGCNT 1072
   hmusb_TIME 2015-09-10 10:09:59
   msgKeepAlive dlyMax:37.144 bufferMin:-32
   msgLoadCurrent 17
   msgLoadHistory 5min steps: 2/1/1/-1/-1/0/-1/-1/-17/1/0/0
   owner      2516B7
   owner_CCU  vccu
   uptime     009 230:09:03.968
   Readings:
     2015-09-10 07:35:28   D-HMIdAssigned  2516B7
     2015-09-10 07:35:28   D-HMIdOriginal  1EBE46
     2015-09-10 07:35:28   D-firmware      0.967
     2015-09-10 07:35:28   D-serialNr      JEQ0701139
     2015-09-10 08:25:14   Xmit-Events     ok:1 init:1 ERROR-Overload:10 Warning-HighLoad:10 disconnected:1
     2015-09-10 08:25:14   cond            ok
     2015-08-30 12:12:11   hmTrfHour       %
     2015-09-10 10:09:50   loadLvl         low
     2015-09-10 08:20:16   prot_ERROR-Overload last
     2015-09-10 08:20:13   prot_Warning-HighLoad last
     2015-09-10 07:35:12   prot_disconnected last
     2015-09-10 07:35:12   prot_init       last
     2015-07-26 22:05:28   prot_keepAlive  last
     2015-09-10 08:25:14   prot_ok         last
     2015-07-29 12:57:51   prot_timeout    last
     2015-09-10 08:25:14   state           opened
   Helper:
     assIdCnt   24
     assIdRep   24
     info       03C7,JEQ0701139,1EBE46,2516B7
     setTime    44002
     Cnd:
       0          1
       2          10
       253        1
       255        1
       4          10
     Ids:
       23fc63:
         name       GT_ga_RS_modul
       268f15:
         name       EG_wc_FK_mi
       276a71:
         name       OG_bz_FK_dach
       276e61:
         name       OG_az_FK_dach
       278cfc:
         chn        01
         flg        0
         msg
         name       EG_fl_BM_display
         to         1441869543.36961
       28a1de:
         chn        04
         flg        0
         msg
         name       OG_sz_RO_mi
         to         1441866336.37863
       28a1ea:
         chn        04
         flg        0
         msg
         name       EG_wz_RO_re
         to         1441866327.84011
       28a275:
         chn        04
         flg        0
         msg
         name       OG_kz_RO_mi
         to         1441866331.95403
       28a281:
         chn        02
         flg        0
         msg
         name       EG_wz_RO_li
         to         1441866923.03467
       28a47c:
         chn        04
         flg        0
         msg
         name       EG_ez_RO_mi
         to         1441867524.27525
       28a511:
         chn        02
         flg        0
         msg
         name       EG_ku_RO_mi
         to         1441867823.37978
       28a51a:
         chn        04
         flg        0
         msg
         name       EG_wc_RO_mi
         to         1441866622.91884
       2d1ec4:
         name       EG_ez_TK_mi
       34283e:
         chn        01
         flg        0
         msg
         name       GT_ga_BM_gartenlicht
         to         1441869052.8708
       3541bf:
         name       EG_fl_RT_tuer
       354a30:
         name       EG_wz_RT_rechts
       354a31:
         name       OG_bz_RT_links
       354a33:
         name       OG_bz_RT_rechts
       354a37:
         name       EG_wz_RT_links
       3745fe:
         name       OG_TH
       374600:
         name       EG_TH
       3746f1:
         name       OC3
       388b09:
         name       EG_wz_TC
       3bb343:
         chn        01
         flg        0
         msg
         name       Waesche
         to         1441866337.40793
     K:
       BufMin     -32
       DlyMax     37.144
       Next       1441872615.17166
       Start      1441872590.17166
     Loadlvl:
       bl         40
       a:
         99
         90
         40
         0
       H:
         0          low
         40         batchLevel
         90         high
         99         suspended
     Log:
       all        0
       sys        0
       ids:
         ARRAY(0x2d1e498)
     Q:
       HMcndN     0
       answerPend 0
       hmLanQlen  1
       keepAliveRec 1
       keepAliveRpt 0
       loadLast   16
       loadNo     1
       scnt       5
       apIDs:
     Ref:
       hmtL       828534827
       kTs        0
   hmId       2516B7
   hmLanQlen  1_min
   loadLevel  0:low,40:batchLevel,90:high,99:suspended
   wdTimer    25
Tim (RettungsTim)
frank
oh ha... , seit dem letzten restart bereits 10x overload. der letzte 08:20. da war die wäsche wohl fertig.
du hast wohl ein at für die msgloadest definiert. das solltest du mal auf die aktuellen verhältnisse (msgLoadCurrent) anpassen.  ;)
   msgLoadCurrent 17
ZitatWie muss ich den anderes einstellen?!
poste alle lists der steckdose und sage was deine kriterien zur erkennung sind.
HoTi
#10
Die Hutschinenmessung habe ich noch nicht lange. Ich habe auf die schnelle für meine Frau den Codeschnipsel genommen.
http://forum.fhem.de/index.php/topic,39498.0.html
Funktioniert auch gut.
*edit*
ich habe mich an dem Plot versucht:
http://www.fhemwiki.de/wiki/HM-CFG-LAN:_%C3%9Cberwachung_der_1%25-Regel
Aber auch mit der Änderung msgLoadCurrent funktiniert es irgendwie nicht...
   DEF        3BB343
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     5
   NAME       Waesche
   NR         617
   NTFY_ORDER 50-Waesche
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 Waesche_Sw
   channel_02 Waesche_Pwr
   channel_03 Waesche_SenPwr
   channel_04 Waesche_SenI
   channel_05 Waesche_SenU
   channel_06 Waesche_SenF
   hmusb_MSGCNT 5
   hmusb_RAWMSG E3BB343,0000,317A78E3,FF,FFC7,5C845E3BB34300000081DD9E0000A400350905FE
   hmusb_RSSI -57
   hmusb_TIME 2015-09-10 10:36:05
   lastMsg    No:5C - t:5E s:3BB343 d:000000 81DD9E0000A400350905FE
   protLastRcv 2015-09-10 10:36:05
   protSnd    4 last_at:2015-09-10 10:35:02
   protState  CMDs_done
   rssi_at_hmusb min:-57 max:-56 avg:-56.6 lst:-57 cnt:5
   rssi_hmusb avg:-59 max:-59 min:-59 cnt:1 lst:-59
   Readings:
     2015-09-10 10:34:24   Activity        alive
     2015-08-29 19:47:10   CommandAccepted yes
     2015-08-28 10:25:20   D-firmware      2.5
     2015-08-28 10:25:20   D-serialNr      MEQ0421050
     2015-08-29 09:06:34   PairedTo        0x2516B7
     2015-08-28 13:35:41   R-intKeyVisib   visib
     2015-08-28 10:25:25   R-localResDis   off
     2015-08-28 10:25:25   R-pairCentral   0x2516B7
     2015-08-29 09:06:34   RegL_00:        02:81 0A:25 0B:16 0C:B7 15:FF 18:00 00:00
     2015-09-10 10:35:02   state           CMDs_done
   Helper:
     HM_CMDNR   92
     cSnd       012516B73BB343010E,012516B73BB343020E
     mId        00EA
     rxType     1
     Io:
       newChn     +3BB343,00,00,00
       nextSend   1441874165.42588
       rxt        0
       vccu       vccu
       p:
         3BB343
         00
         00
         00
       prefIO:
         hmusb
     Mrssi:
       mNo        5C
       Io:
         hmusb      -55
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmusb:
         avg        -56.6
         cnt        5
         lst        -57
         max        -56
         min        -57
       Hmusb:
         avg        -59
         cnt        1
         lst        -59
         max        -59
         min        -59
   IODev      hmusb
   IOgrp      vccu:hmusb
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_full
   firmware   2.5
   model      HM-ES-PMSw1-DR
   room       CUL_HM
   serialNr   MEQ0421050
   subType    powerMeter
   webCmd     getConfig:clear msgEvents
   DEF        3BB34301
   NAME       Waesche_Sw
   NR         619
   NTFY_ORDER 50-Waesche_Sw
   STATE      on
   TYPE       CUL_HM
   chanNo     01
   device     Waesche
   peerList   self01,self05,
   Readings:
     2015-08-29 19:41:43   R-powerUpAction off
     2015-08-28 13:35:50   R-self01-lgActionType jmpToTarget
     2015-08-28 13:35:50   R-self01-lgCtDlyOff geLo
     2015-08-28 13:35:50   R-self01-lgCtDlyOn geLo
     2015-08-28 13:35:50   R-self01-lgCtOff geLo
     2015-08-28 13:35:50   R-self01-lgCtOn geLo
     2015-08-28 13:35:50   R-self01-lgCtValHi 100
     2015-08-28 13:35:50   R-self01-lgCtValLo 50
     2015-08-28 13:35:50   R-self01-lgMultiExec on
     2015-08-28 13:35:50   R-self01-lgOffDly 0 s
     2015-08-28 13:35:50   R-self01-lgOffTime unused
     2015-08-28 13:35:50   R-self01-lgOffTimeMode absolut
     2015-08-28 13:35:50   R-self01-lgOnDly 0 s
     2015-08-28 13:35:50   R-self01-lgOnTime unused
     2015-08-28 13:35:50   R-self01-lgOnTimeMode absolut
     2015-08-29 19:41:45   R-self01-lgSwJtDlyOff on
     2015-08-29 19:41:45   R-self01-lgSwJtDlyOn on
     2015-08-29 19:43:29   R-self01-lgSwJtOff dlyOn
     2015-08-29 19:43:29   R-self01-lgSwJtOn on
     2015-08-28 13:35:50   R-self01-shActionType jmpToTarget
     2015-08-28 13:35:50   R-self01-shCtDlyOff geLo
     2015-08-28 13:35:50   R-self01-shCtDlyOn geLo
     2015-08-28 13:35:50   R-self01-shCtOff geLo
     2015-08-28 13:35:50   R-self01-shCtOn geLo
     2015-08-28 13:35:50   R-self01-shCtValHi 100
     2015-08-28 13:35:50   R-self01-shCtValLo 50
     2015-08-28 13:35:50   R-self01-shOffDly 0 s
     2015-08-28 13:35:50   R-self01-shOffTime unused
     2015-08-28 13:35:50   R-self01-shOffTimeMode absolut
     2015-08-28 13:35:50   R-self01-shOnDly 0 s
     2015-08-28 13:35:50   R-self01-shOnTime unused
     2015-08-28 13:35:50   R-self01-shOnTimeMode absolut
     2015-08-29 19:43:46   R-self01-shSwJtDlyOff on
     2015-08-29 19:43:46   R-self01-shSwJtDlyOn on
     2015-08-29 19:44:00   R-self01-shSwJtOff dlyOn
     2015-08-29 19:44:00   R-self01-shSwJtOn on
     2015-08-29 19:41:46   R-self05-lgActionType jmpToTarget
     2015-08-29 19:41:46   R-self05-lgCtDlyOff geLo
     2015-08-29 19:41:46   R-self05-lgCtDlyOn geLo
     2015-08-29 19:41:46   R-self05-lgCtOff geLo
     2015-08-29 19:41:46   R-self05-lgCtOn geLo
     2015-08-29 19:41:46   R-self05-lgCtValHi 100
     2015-08-29 19:41:46   R-self05-lgCtValLo 50
     2015-08-29 19:41:46   R-self05-lgMultiExec on
     2015-08-29 19:41:46   R-self05-lgOffDly 0 s
     2015-08-29 19:41:46   R-self05-lgOffTime unused
     2015-08-29 19:41:46   R-self05-lgOffTimeMode absolut
     2015-08-29 19:41:46   R-self05-lgOnDly 0 s
     2015-08-29 19:41:46   R-self05-lgOnTime unused
     2015-08-29 19:41:46   R-self05-lgOnTimeMode absolut
     2015-08-29 19:44:17   R-self05-lgSwJtDlyOff on
     2015-08-29 19:44:17   R-self05-lgSwJtDlyOn on
     2015-08-29 19:44:33   R-self05-lgSwJtOff dlyOn
     2015-08-29 19:44:33   R-self05-lgSwJtOn on
     2015-08-29 19:41:46   R-self05-shActionType jmpToTarget
     2015-08-29 19:41:46   R-self05-shCtDlyOff geLo
     2015-08-29 19:41:46   R-self05-shCtDlyOn geLo
     2015-08-29 19:41:46   R-self05-shCtOff geLo
     2015-08-29 19:41:46   R-self05-shCtOn geLo
     2015-08-29 19:41:46   R-self05-shCtValHi 100
     2015-08-29 19:41:46   R-self05-shCtValLo 50
     2015-08-29 19:41:46   R-self05-shOffDly 0 s
     2015-08-29 19:41:46   R-self05-shOffTime unused
     2015-08-29 19:41:46   R-self05-shOffTimeMode absolut
     2015-08-29 19:41:46   R-self05-shOnDly 0 s
     2015-08-29 19:41:46   R-self05-shOnTime unused
     2015-08-29 19:41:46   R-self05-shOnTimeMode absolut
     2015-08-29 19:44:47   R-self05-shSwJtDlyOff on
     2015-08-29 19:44:47   R-self05-shSwJtDlyOn on
     2015-08-29 19:45:12   R-self05-shSwJtOff dlyOn
     2015-08-29 19:45:12   R-self05-shSwJtOn on
     2015-08-29 08:36:37   R-sign          off
     2015-08-29 08:36:37   R-statusInfoMinDly 2 s
     2015-08-29 08:36:37   R-statusInfoRandom 1 s
     2015-08-29 08:36:37   R-transmitTryMax 6
     2015-08-29 19:45:10   RegL_01:        08:00 30:06 56:00 57:24 93:20 94:45 00:00
     2015-08-29 19:45:11   RegL_03:self01  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:13 0C:33 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:13 8C:33  00:00
     2015-08-29 19:45:12   RegL_03:self05  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:13 0C:33 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:13 8C:33  00:00
     2015-09-10 10:35:01   deviceMsg       on (to vccu)
     2015-09-10 10:35:01   level           100
     2015-09-10 10:35:01   pct             100
     2015-09-10 10:34:24   peerList        self01,self05,
     2015-09-10 10:35:01   recentStateType info
     2015-09-10 10:35:01   state           on
     2015-09-10 10:35:01   timedOn         off
   Helper:
     Role:
       chn        1
       prs        1
   peerIDs    00000000,3BB34301,3BB34305,
   DEF        3BB34302
   NAME       Waesche_Pwr
   NR         620
   NTFY_ORDER 50-Waesche_Pwr
   STATE      12227
   TYPE       CUL_HM
   chanNo     02
   device     Waesche
   Readings:
     2015-08-28 10:25:26   R-averaging     1 s
     2015-08-28 10:25:26   R-sign          off
     2015-08-28 10:25:26   R-txMinDly      8 s
     2015-08-28 10:25:26   R-txThrCur      100 mA
     2015-08-28 10:25:26   R-txThrFrq      1 Hz
     2015-08-28 10:25:26   R-txThrPwr      100 W
     2015-08-28 10:25:26   R-txThrVlt      10 V
     2015-08-29 09:06:36   RegL_01:        08:00 7A:01 7B:08 7C:00 7D:27 7E:10  7F:00 80:64 81:00 82:64 83:64 00:00
     2015-09-10 10:36:05   boot            off
     2015-09-10 10:36:05   current         53
     2015-09-10 10:36:05   eState          E: 12227 P: 1.64 I: 53 U: 230.9 f: 49.98
     2015-09-10 10:36:05   energy          12227
     2015-09-10 10:36:05   energyCalc      13688
     2015-08-31 20:05:46   energyOffset    1461
     2015-09-10 10:36:05   frequency       49.98
     2015-09-10 10:36:05   power           1.64
     2015-09-10 10:36:05   state           12227
     2015-09-10 10:36:05   voltage         230.9
   Helper:
     Role:
       chn        1
   DEF        3BB34303
   NAME       Waesche_SenPwr
   NR         621
   NTFY_ORDER 50-Waesche_SenPwr
   STATE      1.64
   TYPE       CUL_HM
   chanNo     03
   device     Waesche
   Readings:
     2015-08-28 10:25:27   R-cndTxCycAbove off
     2015-08-28 10:25:27   R-cndTxCycBelow off
     2015-08-28 10:25:27   R-cndTxDecAbove 200
     2015-08-28 10:25:27   R-cndTxDecBelow 0
     2015-08-28 10:25:27   R-cndTxFalling  off
     2015-08-28 10:25:27   R-cndTxRising   off
     2015-08-28 10:25:27   R-ledOnTime     0.5 s
     2015-08-28 10:25:27   R-sign          off
     2015-08-28 10:25:27   R-transmitTryMax 6
     2015-08-28 10:25:27   R-txThrHiPwr    200 W
     2015-08-28 10:25:27   R-txThrLoPwr    100 W
     2015-08-29 09:06:37   RegL_01:        08:00 22:64 30:06 84:00 85:C8 86:00 87:00 88:00 89:4E 8A:20 8B:00 8C:00 8D:27 8E:10  00:00
     2015-09-10 10:38:05   state           1.64
   Helper:
     Role:
       chn        1
   peerIDs    00000000,
   DEF        3BB34304
   NAME       Waesche_SenI
   NR         622
   NTFY_ORDER 50-Waesche_SenI
   STATE      53
   TYPE       CUL_HM
   chanNo     04
   device     Waesche
   Readings:
     2015-08-28 10:25:29   R-cndTxCycAbove off
     2015-08-28 10:25:29   R-cndTxCycBelow off
     2015-08-28 10:25:29   R-cndTxDecAbove 200
     2015-08-28 10:25:29   R-cndTxDecBelow 0
     2015-08-28 10:25:29   R-cndTxFalling  off
     2015-08-28 10:25:29   R-cndTxRising   off
     2015-08-28 10:25:29   R-ledOnTime     0.5 s
     2015-08-28 10:25:29   R-sign          off
     2015-08-28 10:25:29   R-transmitTryMax 6
     2015-08-28 10:25:29   R-txThrHiCur    2000 mA
     2015-08-28 10:25:29   R-txThrLoCur    1000 mA
     2015-08-29 09:06:38   RegL_01:        08:00 22:64 30:06 84:00 85:C8 86:00 87:00 88:00 89:07 8A:D0 8B:00 8C:00 8D:03 8E:E8  00:00
     2015-09-10 10:38:05   state           53
   Helper:
     Role:
       chn        1
   peerIDs    00000000,
   DEF        3BB34305
   NAME       Waesche_SenU
   NR         623
   NTFY_ORDER 50-Waesche_SenU
   STATE      231.4
   TYPE       CUL_HM
   chanNo     05
   device     Waesche
   Readings:
     2015-08-29 19:45:49   R-cndTxCycAbove off
     2015-08-29 19:45:49   R-cndTxCycBelow off
     2015-08-28 10:25:30   R-cndTxDecAbove 200
     2015-08-28 10:25:30   R-cndTxDecBelow 0
     2015-08-29 19:45:49   R-cndTxFalling  off
     2015-08-29 19:45:49   R-cndTxRising   on
     2015-08-28 10:25:30   R-ledOnTime     0.5 s
     2015-08-28 10:25:30   R-sign          off
     2015-08-28 10:25:30   R-transmitTryMax 6
     2015-08-29 19:46:24   R-txThrHiVlt    200 V
     2015-08-29 19:47:14   R-txThrLoVlt    180 V
     2015-08-29 19:47:14   RegL_01:        08:00 22:64 30:06 84:02 85:C8 86:00 87:00 88:00 89:07 8A:D0 8B:00 8C:00 8D:07 8E:08  00:00
     2015-09-10 10:38:05   state           231.4
   Helper:
     Role:
       chn        1
   peerIDs    00000000,
   DEF        3BB34306
   NAME       Waesche_SenF
   NR         624
   NTFY_ORDER 50-Waesche_SenF
   STATE      49.99
   TYPE       CUL_HM
   chanNo     06
   device     Waesche
   Readings:
     2015-08-28 10:25:32   R-cndTxCycAbove off
     2015-08-28 10:25:32   R-cndTxCycBelow off
     2015-08-28 10:25:32   R-cndTxDecAbove 200
     2015-08-28 10:25:32   R-cndTxDecBelow 0
     2015-08-28 10:25:32   R-cndTxFalling  off
     2015-08-28 10:25:32   R-cndTxRising   off
     2015-08-28 10:25:32   R-ledOnTime     0.5 s
     2015-08-28 10:25:32   R-sign          off
     2015-08-28 10:25:32   R-transmitTryMax 6
     2015-08-28 10:25:32   R-txThrHiFrq    50.2 Hz
     2015-08-28 10:25:32   R-txThrLoFrq    49.8 Hz
     2015-08-29 09:06:41   RegL_01:        08:00 22:64 30:06 84:00 85:C8 86:00 87:00 88:00 89:13 8A:9C 8B:00 8C:00 8D:13 8E:74  00:00
     2015-09-10 10:38:05   state           49.99
   Helper:
     Role:
       chn        1
   peerIDs    00000000,
Tim (RettungsTim)
frank
ich wollte die daten wissen, die für deine waschmaschine nötig sind. nutzt du leistung oder strom? welche schwellwerte nutzt du für fertig und waschen etc...
wenn dich nur die leistung interessiert, setze auf jedenfall erstmal diese register in chn2:
txThrCur => unused
txThrFrq => unused
txThrVlt => unused
HoTi
Na gut das werde ich jetzt mal machen. Aber das ist doch nicht die Lösung. Ich habe das ding um auch die Spannung den Strom und die Frequens zu wissen.
Da muss es doch noch eine andere Lösung für geben?
Tim (RettungsTim)
frank
ZitatAber das ist doch nicht die Lösung. Ich habe das ding um auch die Spannung den Strom und die Frequens zu wissen.
das bedeutet doch nicht, dass du keine messwerte mehr bekommst! setze dich mal mit den möglichkeiten deiner steckdose auseinander, anstatt solche kommentare zu äussern.
du bekommst sogar noch messwerte, wenn auch noch txThrPwr=unused gesetzt ist. sogar von allen 5 messgrössen. in diesem fall dann aber nur alle 2-3 min. das ist dann die grösst mögliche reduzierung. mit
txThrPwr      100 W
erhälst du zusätzlich, zu den sowieso schon alle 2-3 min gesendeten daten, messdaten, sobald sich pwr um 100w geändert hat. und jeder datensatz der gesendet wird enthält immer alle 5 messgrössen.
ZitatDa muss es doch noch eine andere Lösung für geben?
nicht so oft waschen.  :)
HoTi
ah, jetzt habe ich das verstanden. Danke dir Frank
Jetzt schauen wir mal ob es besser wird.
Tim (RettungsTim)
