Kein Update möglich / 10_CUL_HM.pm failed
Begonnen von GrandJury, 12 September 2015, 16:58:36
GrandJury
ich habe seit einigen Tagen das Problem, dass ich kein Fhem-Update durchführen kann.
Events (Filter:global):
2015-09-12 16:49:11 Global global UPD ./CHANGED
2015-09-12 16:49:11 Global global UPD ./fhem.pl
2015-09-12 16:49:11 Global global UPD FHEM/00_FBAHA.pm
2015-09-12 16:49:11 Global global UPD FHEM/00_MAXLAN.pm
2015-09-12 16:49:11 Global global UPD FHEM/00_ZWDongle.pm
2015-09-12 16:49:11 Global global UPD FHEM/10_CUL_HM.pm
2015-09-12 16:49:12 Global global open ./FHEM/10_CUL_HM.pm failed: Permission denied, trying to restore the previous version and aborting the update
Im Logfile steht folgendes:
2015.09.12 16:52:18 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451.
2015.09.12 16:52:18 0: ERROR: Cannot autoload CUL_HM
2015.09.12 16:52:18 3: CUL_0: Unknown code A0C1784702D601C00000000E337::-96.5:CUL_0, help me!
2015.09.12 16:52:28 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4338.
2015.09.12 16:52:31 2: BalkontuerPush: internal does not exist: [Balkontuer:STATE]
2015.09.12 16:52:38 1: reload: Error:Modul 10_CUL_HM deactivated:
2015.09.12 16:52:38 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232.
2015.09.12 16:52:38 0: ERROR: Cannot autoload CUL_HM
2015.09.12 16:52:38 3: CUL_0: Unknown code A0FAE861026CE570000000AA8E50D044A::-59.5:CUL_0, help me!
2015.09.12 16:53:01 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4338.
2015.09.12 16:53:05 2: BalkontuerPush: internal does not exist: [Balkontuer:STATE]
2015.09.12 16:53:29 1: reload: Error:Modul 10_CUL_HM deactivated:
2015.09.12 16:53:29 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232.
2015.09.12 16:53:29 0: ERROR: Cannot autoload CUL_HM
2015.09.12 16:53:29 3: CUL_0: Unknown code A0F62861026D5450000000AACE30C0053::-71.5:CUL_0, help me!
2015.09.12 16:53:35 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4338.
2015.09.12 16:53:38 2: BalkontuerPush: internal does not exist: [Balkontuer:STATE]
2015.09.12 16:53:39 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4338.
2015.09.12 16:53:43 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4338.
2015.09.12 16:54:08 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4338.
2015.09.12 16:54:11 2: BalkontuerPush: internal does not exist: [Balkontuer:STATE]
2015.09.12 16:54:15 1: reload: Error:Modul 10_CUL_HM deactivated:
2015.09.12 16:54:15 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232.
2015.09.12 16:54:15 0: ERROR: Cannot autoload CUL_HM
2015.09.12 16:54:15 3: CUL_0: Unknown code A0C18865A2D601C000000ACE337::-99:CUL_0, help me!
2015.09.12 16:54:35 1: reload: Error:Modul 10_CUL_HM deactivated:
2015.09.12 16:54:35 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232.
2015.09.12 16:54:35 0: ERROR: Cannot autoload CUL_HM
2015.09.12 16:54:35 3: CUL_0: Unknown code A0C1884702D601C00000000E337::-97:CUL_0, help me!
Kann mir jemand helfen? Komme hier nicht weiter, da ich auch nicht wirklich weiß, wo ich ansetzen muss.
Vielen Dank.
stromer-12
Deine 10_CUL_HM.pm hat falsche Berechtigungen. Lösche sie und mache ohne fhem neu zu starten nochmal das update.
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
GrandJury
Ich danke dir vielmals. Das hat funktioniert.  :D
