10_EIB.pm: cleaned up, implemented DPT16 for sending, implemented DPT6, added EIBanswerOnRead, changed time/date-handling, fixed DPT14-sending, removed Root-Causes for several warnings, fixed set stri...
Begonnen von System, 07 Oktober 2015, 03:00:09
System
10_EIB.pm: cleaned up, implemented DPT16 for sending, implemented DPT6, added EIBanswerOnRead, changed time/date-handling, fixed DPT14-sending, removed Root-Causes for several warnings, fixed set string containing letter g, removed ne-warning, added attribute eventMarker, fixed behaviour if no model defined, fixed DPT14, restructured DPT9, fixed datum and time, improved failure-tolerance for none / wrong model, fixed date/time again, removed eventMarker, removed no get for dummiesView Changes
Source: 10_EIB.pm: cleaned up, implemented DPT16 for sending, implemented DPT6, added EIBanswerOnRead, changed time/date-handling, fixed DPT14-sending, removed Root-Causes for several warnings, fixed set stri...
