PERL WARNING diverse
Begonnen von Steffen, 13 Oktober 2015, 21:13:15
Steffen
Hallo!
Habe diesen Fehler im log gefunden schon öfters gesehen aber habe jetzt Urlaub und kann mich darum mal in Ruhe kümmern und wollte euch mal fragen wo ich da ansetzten könnte das zu finden woran es liegt:
2015.10.13 06:41:58 1: PERL WARNING: Use of uninitialized value in substitution iterator at /opt/fhem/FHEM/98_XmlList.pm line 36.
2015.10.13 06:41:58 3: stacktrace:
2015.10.13 06:41:58 3:     main::__ANON__                      called by /opt/fhem/FHEM/98_XmlList.pm (36)
2015.10.13 06:41:58 3:     main::XmlEscape                     called by /opt/fhem/FHEM/98_XmlList.pm (97)
2015.10.13 06:41:58 3:     main::CommandXmlList                called by fhem.pl (1051)
2015.10.13 06:41:58 3:     main::AnalyzeCommand                called by fhem.pl (922)
2015.10.13 06:41:58 3:     main::AnalyzeCommandChain           called by /opt/fhem/FHEM/01_FHEMWEB.pm (2083)
2015.10.13 06:41:58 3:     main::FW_fC                         called by /opt/fhem/FHEM/01_FHEMWEB.pm (644)
2015.10.13 06:41:58 3:     main::FW_answerCall                 called by /opt/fhem/FHEM/01_FHEMWEB.pm (436)
2015.10.13 06:41:58 3:     main::FW_Read                       called by fhem.pl (3085)
2015.10.13 06:41:58 3:     main::CallFn                        called by fhem.pl (651)
dann noch der:
2015.10.14 08:22:20 1: PERL WARNING: Use of uninitialized value $texts[0] in join or string at /opt/fhem/FHEM/57_Calendar.pm line 1073.
2015.10.14 08:22:20 3: stacktrace:
2015.10.14 08:22:20 3:     main::__ANON__                      called by /opt/fhem/FHEM/57_Calendar.pm (1073)
2015.10.14 08:22:20 3:     main::Calendar_Get                  called by fhem.pl (3085)
2015.10.14 08:22:20 3:     main::CallFn                        called by /opt/fhem/FHEM/57_CALVIEW.pm (189)
2015.10.14 08:22:20 3:     main::getsummery                    called by /opt/fhem/FHEM/57_CALVIEW.pm (76)
2015.10.14 08:22:20 3:     main::CALVIEW_GetUpdate             called by fhem.pl (2699)
2015.10.14 08:22:20 3:     main::HandleTimeout                 called by fhem.pl (583)
und der:
2015.10.14 08:22:20 1: PERL WARNING: Use of uninitialized value $sollZeit in numeric le (<=) at /opt/fhem/FHEM/98_WeekdayTimer.pm line 602.
2015.10.14 08:22:20 3:     main::__ANON__                      called by /opt/fhem/FHEM/98_WeekdayTimer.pm (602)
2015.10.14 08:22:20 3:     main::WeekdayTimer_Update           called by /opt/fhem/FHEM/98_Heating_Control.pm (85)
2015.10.14 08:22:20 3:     main::Heating_Control_Update        called by fhem.pl (2699)
Hoffe es hat jemand ein tip für mich?!
Mfg Steffen
viegener
Hallo Steffen,
vermutlich wirst Du hier im Anfängerboard nicht unbedingt Lösungen für diese Fragen erhalten, denn ich nehme an, dass nicht alle Modulowner hier mitlesen. Wenn Dein Fhem aktuell ist, würde ich versuchen die Nachfrage zu den Meldungen eher in den modulspezifischen Boards zu machen.
Generell sind die Meldungen nicht kritisch und es sind nur Warnungen. Ein Block auf des Source hat mir nur gesagt, dass die Warnungen zum aktuellen Stand passen, vielleicht müssen die Moduowner etwas mehr zum Kontext erfahren, damit sie entsprechende Anpassungen machen könne oder Tipps geben.
Gruss,
Johannes
