74_AMAD: New Mijor Release 0.8.1, fix call statusRequest then screen off is set, fix change room then device modify, insert first code parts of voice input
Begonnen von System, 01 November 2015, 04:00:17
System
74_AMAD: New Mijor Release 0.8.1, fix call statusRequest then screen off is set, fix change room then device modify, insert first code parts of voice inputView Changes
Source: 74_AMAD: New Mijor Release 0.8.1, fix call statusRequest then screen off is set, fix change room then device modify, insert first code parts of voice input
