Warum schreibt er mir das Log voll mit diesen Meldungen:?
Begonnen von moonsorrox, 04 November 2015, 12:37:19
moonsorrox
das geht nun schon munter einige Tage so, das diese Meldungen ins Log geschrieben werden.
Wie kann ich das ändern..?
Ist nur ein kurzer Auszug..
2015.11.04 12:30:01 3:     main::CallFn                        called by fhem.pl (652)
2015.11.04 12:30:01 3:     main::telnet_Read                   called by fhem.pl (3087)
2015.11.04 12:30:01 3:     main::AnalyzeCommandChain           called by ./FHEM/98_telnet.pm (269)
2015.11.04 12:30:01 3:     main::AnalyzeCommand                called by fhem.pl (924)
2015.11.04 12:30:01 3:     main::AnalyzePerlCommand            called by fhem.pl (994)
2015.11.04 12:30:01 3:     (eval)                              called by fhem.pl (974)
2015.11.04 12:30:01 3:     main::_finishedCONDITIONS           called by (eval 281677) (1)
2015.11.04 12:30:01 3:     main::getConditions                 called by ./FHEM/55_GDS.pm (1331)
2015.11.04 12:30:01 3:     main::utf8ToLatin1                  called by ./FHEM/55_GDS.pm (986)
2015.11.04 12:30:01 3:     main::__ANON__                      called by fhem.pl (4134)
2015.11.04 12:30:01 3: stacktrace:
2015.11.04 12:30:01 1: PERL WARNING: Use of uninitialized value $s in substitution (s///) at fhem.pl line 4134.
2015.11.04 12:30:01 3:     main::_readItem                     called by ./FHEM/55_GDS.pm (958)
2015.11.04 12:30:01 3:     main::__ANON__                      called by ./FHEM/55_GDS.pm (1010)
2015.11.04 12:30:01 1: PERL WARNING: Use of uninitialized value $x in substitution (s///) at ./FHEM/55_GDS.pm line 1010.
2015.11.04 12:30:01 3:     main::__ANON__                      called by ./FHEM/55_GDS.pm (1009)
2015.11.04 12:30:01 1: PERL WARNING: substr outside of string at ./FHEM/55_GDS.pm line 1009.
2015.11.04 12:25:13 3: at_KalenderTermine_S: Wrote configuration to fhem.cfg
2015.11.04 12:25:13 3: save : Wrote configuration to fhem.cfg
2015.11.04 12:10:00 3:     main::CallFn                        called by fhem.pl (652)
2015.11.04 12:10:00 3:     main::telnet_Read                   called by fhem.pl (3087)
2015.11.04 12:10:00 3:     main::AnalyzeCommandChain           called by ./FHEM/98_telnet.pm (269)
2015.11.04 12:10:00 3:     main::AnalyzeCommand                called by fhem.pl (924)
2015.11.04 12:10:00 3:     main::AnalyzePerlCommand            called by fhem.pl (994)
2015.11.04 12:10:00 3:     (eval)                              called by fhem.pl (974)
2015.11.04 12:10:00 3:     main::_finishedCONDITIONS           called by (eval 271151) (1)
2015.11.04 12:10:00 3:     main::getConditions                 called by ./FHEM/55_GDS.pm (1331)
2015.11.04 12:10:00 3:     main::utf8ToLatin1                  called by ./FHEM/55_GDS.pm (986)
2015.11.04 12:10:00 3:     main::__ANON__                      called by fhem.pl (4134)
2015.11.04 12:10:00 3: stacktrace:
2015.11.04 12:10:00 1: PERL WARNING: Use of uninitialized value $s in substitution (s///) at fhem.pl line 4134.
2015.11.04 12:10:00 3:     main::_readItem                     called by ./FHEM/55_GDS.pm (958)
2015.11.04 12:10:00 3:     main::__ANON__                      called by ./FHEM/55_GDS.pm (1010)
CoolTux
stacktrace
Falls gesetzt (auf 1), schreibt ins FHEM-Log zusätzlich zu jedem "PERL WARNING" den stacktrace.
Aus der CommandRef
Das TuxNet Wiki:
https://www.cooltux.net
ph1959de
Aktives Mitglied des FHEM e.V. | Moderator im Forenbereich "Wiki"
franky08
#3
Unter global stacktrace auf 0 setzen.
CoolTux war schneller  ;)
Und das GDS Modul scheint da Perl Warnungen zu generieren.
Siehe Ankündigung von betateilchen:
http://forum.fhem.de/index.php/topic,42887.0.html
VG
Frank
mit FHEM aktuell
maxritti
Da das GDS Modul häufig im Log auftaucht, hat es vielleicht etwas mit dem hier zu tun!?
moonsorrox
OK, dass habe ich jetzt erst einmal getan..!  :D
Irgendwann habe/sollte ich das mal auf 1 gestellt/stellen, danach habe ich es wohl vergessen, aber steht ja auch in den Logeinträgen :-\
Dank an Euch
CoolTux
Zitat von: ph1959de am 04 November 2015, 12:46:01
Könnte in diesem (Deinem!) Thread des Rätsels Lösung verborgen liegen?
Peter
Finde ich fast noch besser die Antwort   ;D
Deswegen sage ich Usern so ungerne was sie machen sollen. Sie machen es einfach blind ohne sich im nachhinein wenigstens zu informieren.
Das TuxNet Wiki:
