98_GAEBUS.pm : add support if ebusd returns a list of semicolon separated values. now several readings can be defined to hold the values
Begonnen von System, 09 November 2015, 15:00:01
System
98_GAEBUS.pm : add support if ebusd returns a list of semicolon separated values. now several readings can be defined to hold the valuesView Changes
Source: 98_GAEBUS.pm : add support if ebusd returns a list of semicolon separated values. now several readings can be defined to hold the values
