Raspi und HM-MOD-RPI-Pcb
Begonnen von laxmann, 08 Dezember 2016, 19:12:33
laxmann
Guten Tag zusammen und ruhige Festtage,
es hat sich ergeben, das ich mein Fhem-Raspi mit dem HM-MOD-RPI-Pcb betreibe und in der VCCU eingebunden habe. Seid dem kommen aber folgende Meldungen
2016.12.24 15:57:24.568 1: HMUARTLGW HMRasp1 Adding peer 36D30C failed! You have probably forced an unknown aesKey for this device.
2016.12.24 15:57:51.381 3: CUL_HM set ST_1_Kaffeemaschine on
2016.12.24 15:57:51.387 1: HMUARTLGW HMRasp1 Adding peer 36D30C failed! You have probably forced an unknown aesKey for this device.
2016.12.24 15:57:52.691 3: CUL_HM set ST_1_Kaffeemaschine off
2016.12.24 15:57:52.698 1: HMUARTLGW HMRasp1 Adding peer 36D30C failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:36.503 3: CUL_HM set ST_1_Kaffeemaschine on
2016.12.24 16:02:36.509 1: HMUARTLGW HMRasp1 Adding peer 36D30C failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:37.507 3: CUL_HM set ST_1_Kaffeemaschine off
2016.12.24 16:02:37.513 1: HMUARTLGW HMRasp1 Adding peer 36D30C failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:38.988 3: CUL_HM set ST_2_Ladestation_Essz on
2016.12.24 16:02:38.994 1: HMUARTLGW HMRasp1 Adding peer 36D18F failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:40.008 3: CUL_HM set ST_2_Ladestation_Essz off
2016.12.24 16:02:40.017 1: HMUARTLGW HMRasp1 Adding peer 36D18F failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:42.097 3: CUL_HM set ST_2_Ladestation_Essz on
2016.12.24 16:02:42.103 1: HMUARTLGW HMRasp1 Adding peer 36D18F failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:43.286 1: HMUARTLGW HMRasp1 Adding peer 36D18F failed! You have probably forced an unknown aesKey for this device.
2016.12.24 16:02:50.805 1: HMUARTLGW HMRasp1 Adding peer 36D18F failed! You have probably forced an unknown aesKey for this device.
Im Forum finde ich nichts.
Ich habe die Geräte neu gepairt. Die Installation des HM-MOD-RPI-Pcb und AES-Verschlüsselung ist eigentlich installiert.
Die Geräte funktionieren alle. In der VCCU sind noch zwei HMLAN-Adapter eingebunden.
Wo ist mein Fehler?
laxmann
laxmann
#31
Da bin ich nochmal,
hier habe ich die Lösung gefunden
https://forum.fhem.de/index.php?topic=40400.0 (ftp://forum.fhem.de/index.php?topic=40400.0)
https://forum.fhem.de/index.php?topic=40400.0]http://forum.fhem.de/index.php?topic=40400.0]https://forum.fhem.de/index.php?topic=40400.0
Gruss
laxmann
