ROOMMATE dauerhaft absent
Begonnen von mfeske, 12 Oktober 2015, 15:44:38
mfeske
ich verwende Geofancy zusammen mit egigeozone. Die Lokalisierung funktioniert auch:
   DEF        geo
   NAME       geofancy
   NR         380
   STATE      id:3efaa140-f12d-36c5-858d-e9d83c61ca77 name:home trig:1 date:2015-10-12T13:06:05Z lat:52.6047904 long:13.298567 dev:Michael
   TYPE       GEOFANCY
   Readings:
     2015-10-12 15:06:05   Michael         arrived home
     2015-10-12 15:06:05   currLocLat_Michael 52.6047904
     2015-10-12 15:06:05   currLocLong_Michael 13.298567
     2015-10-12 15:06:05   currLocTime_Michael 2015-10-12 15:06:05
     2015-10-12 15:06:05   currLoc_Michael home
     2015-10-12 15:06:05   lastArr         Michael home
     2015-10-12 14:07:20   lastDep         Michael home
     2015-10-12 15:06:05   lastDevice      Michael
     2015-10-12 14:07:20   lastLocArr_Michael 2015-10-12 13:48:39
     2015-10-12 14:07:20   lastLocDep_Michael 2015-10-12 14:07:20
     2015-10-12 14:07:20   lastLocLat_Michael 52.6047904
     2015-10-12 14:07:20   lastLocLong_Michael 13.298567
     2015-10-12 14:07:20   lastLoc_Michael home
     2015-10-12 15:06:05   state           id:3efaa140-xxxxxxxxxxx-7 name:home trig:1 date:2015-10-12T13:06:05Z lat:52.6047904 long:13.298567 dev:Michael
   Fhem:
     infix      geo
   Helper:
     Device_aliases:
       3efaaxxx61ca77 Michael
     Device_names:
       Michael    3efaa140-f12d-36c5-858d-e9d83c61ca77
   devAlias   3efaaxxxxxca77:Michael
   room       Haus
Auch das notify bekommt die Daten:
   DEF        geofancy:currLoc_Michael.* set location_michael:FILTER=location!=$EVTPART1 location $EVTPART
   NAME       Michael.location
   NOTIFYDEV  geofancy
   NR         381
   NTFY_ORDER 50-Michael.location
   REGEXP     geofancy:currLoc_Michael.*
   STATE      2015-10-12 15:06:08
   TYPE       notify
   Readings:
     2015-10-12 11:09:16   state           active
   room       Haus
Aber roommate bleibt auf absent
   DEF        Bewohner,Eltern
   NAME       location_michael
   NR         388
   NTFY_ORDER 50-location_michael
   RESIDENTGROUPS
   STATE      absent
   TYPE       ROOMMATE
   Readings:
     2015-10-12 15:42:34   durTimerAbsence 18:06:57
     2015-10-12 15:42:34   durTimerAbsence_cr 1087
     2015-10-11 21:35:37   durTimerPresence 00:00:00
     2015-10-11 21:09:12   durTimerPresence_cr 0
     2015-10-11 21:09:12   durTimerSleep   00:00:00
     2015-10-11 21:09:12   durTimerSleep_cr 0
     2015-10-11 21:35:25   lastArrival     2015-10-11 21:35:25
     2015-10-11 21:35:37   lastDeparture   2015-10-11 21:35:37
     2015-10-11 21:35:37   lastDurPresence 00:00:12
     2015-10-11 21:35:37   lastDurPresence_cr 0
     2015-10-11 21:35:37   lastLocation    home
     2015-10-11 21:35:37   lastMood        sleepy
     2015-10-11 21:39:24   lastState       gone
     2015-10-12 13:45:37   location        $EVTPART
     2015-10-11 21:35:37   mood            -
     2015-10-11 21:35:37   presence        absent
     2015-10-11 21:39:24   state           absent
     2015-10-12 08:15:03   wakeup          0
     2015-10-11 21:35:25   wayhome         0
   Timer:
     Location_michael_autogone:
       HASH       location_michael
       MODIFIER   AutoGone
       NAME       location_michael_AutoGone
     Location_michael_durationtimer:
       MODIFIER   DurationTimer
       NAME       location_michael_DurationTimer
   alias      Location Michael
   devStateIcon .*home:user_available:absent .*absent:user_away:home .*gone:user_ext_away:home .*gotosleep:scene_toilet:asleep .*asleep:scene_sleeping:awoken .*awoken:scene_sleeping_alternat:home .*:user_unknown:home
   group      location
   icon       people_sensor
   room       Haus,Residents
   rr_realname group
   sortby     1
   webCmd     state
Wobei mit location        $EVTPART schon stutzig macht.
Micha
Hardware:
1 x Raspberry Pi Mod. B 512 MB
eq-3 2 x MAX! eTRV Heizungssteller, 1 x MAX! Fensterkontakt, 1 x MAX! Cube - LAN Gateway (ausser Betrieb)
Intertechno 1x ITZ-500, 3x ITT-1500, 9x ITR-1500, 3 x ITDL-1000, 2 x ITL-500
1 x CC1101-USB-Lite 433MHz (CUL433)  V3 1 x CC1101-USB-Lite 868MHz (CUL868)
CoolTux
Du prüfst auf $EVTPART1 um dann EVTPART zu setzen? Ich glaube das geht so nicht
geofancy:currLoc_Michael.* set location_michael:FILTER=location!=$EVTPART1 location $EVTPART1
Das sollte aber gehen
Das TuxNet Wiki:
https://www.cooltux.net
mfeske
Der Teufel steckt im Detail ;-) Ich habe wohl beim kopieren aus dem Wiki ein Zeichen übersehen . Das geht jetzt. Mein RESIDENTS Problem behebt sich dabei aber leider nicht. Ich bin immer davon ausgegangen, wenn einer von der Gruppe anwesend ist, das diese auch auf present gesetzt wird.
Das scheint aber bei mir nicht zu funktionieren.
   NAME       Eltern
   NR         390
   NTFY_ORDER 50-Eltern
   STATE      absent
   TYPE       RESIDENTS
   Readings:
     2015-10-11 21:39:25   lastActivity    absent
     2015-10-11 21:39:25   lastActivityBy  location_michael
     2015-10-11 21:39:25   lastActivityByDev location_michael
     2015-10-11 21:39:24   residentsAbsent 1
     2015-10-11 21:39:24   residentsAbsentDevs location_michael
     2015-10-11 21:39:24   residentsAbsentNames location_michael
     2015-10-11 21:35:25   residentsAsleep 0
     2015-10-11 21:35:25   residentsAsleepDevs -
     2015-10-11 21:35:25   residentsAsleepNames -
     2015-10-11 21:35:25   residentsAwoken 0
     2015-10-11 21:35:25   residentsAwokenDevs -
     2015-10-11 21:35:25   residentsAwokenNames -
     2015-10-11 21:39:24   residentsGone   0
     2015-10-11 21:39:24   residentsGoneDevs -
     2015-10-11 21:39:24   residentsGoneNames -
     2015-10-11 21:35:37   residentsGotosleep 0
     2015-10-11 21:35:37   residentsGotosleepDevs -
     2015-10-11 21:35:37   residentsGotosleepNames -
     2015-10-11 21:35:32   residentsHome   0
     2015-10-11 21:35:32   residentsHomeDevs -
     2015-10-11 21:35:32   residentsHomeNames -
     2015-10-11 21:35:25   residentsTotal  1
     2015-10-11 21:35:37   residentsTotalAbsent 1
     2015-10-11 21:35:37   residentsTotalAbsentDevs location_michael
     2015-10-11 21:35:37   residentsTotalAbsentNames location_michael
     2015-10-11 21:35:25   residentsTotalGuests 0
     2015-10-11 21:35:25   residentsTotalGuestsAbsent 0
     2015-10-11 21:35:25   residentsTotalGuestsAbsentDevs -
     2015-10-11 21:35:25   residentsTotalGuestsAbsentNames -
     2015-10-11 21:35:25   residentsTotalGuestsPresent 0
     2015-10-11 21:35:25   residentsTotalGuestsPresentDevs -
     2015-10-11 21:35:25   residentsTotalGuestsPresentNames -
     2015-10-11 21:35:37   residentsTotalPresent 0
     2015-10-11 21:35:37   residentsTotalPresentDevs -
     2015-10-11 21:35:37   residentsTotalPresentNames -
     2015-10-11 21:35:25   residentsTotalWakeup 0
     2015-10-11 21:35:25   residentsTotalWakeupDevs -
     2015-10-11 21:35:25   residentsTotalWakeupNames -
     2015-10-11 21:35:25   residentsTotalWayhome 0
     2015-10-11 21:35:25   residentsTotalWayhomeDevs -
     2015-10-11 21:35:25   residentsTotalWayhomeNames -
   alias      Eltern
   devStateIcon .*home:status_available:absent .*absent:status_away_1:home .*gone:status_standby:home .*none:control_building_empty .*gotosleep:status_night:asleep .*asleep:status_night:awoken .*awoken:status_available:home .*:user_unknown:home
   group      Home State
   icon       control_building_filled
   room       Haus,Residents
   webCmd     state
ich bin ja im home status
   DEF        Bewohner,Eltern
   NR         388
   RESIDENTGROUPS
   STATE      home
   TYPE       ROOMMATE
   Readings:
     2015-10-14 18:49:47   durTimerAbsence 00:00:00
     2015-10-14 18:49:47   durTimerAbsence_cr 0
     2015-10-14 19:32:47   durTimerPresence 00:43:00
     2015-10-14 19:32:47   durTimerPresence_cr 43
     2015-10-14 18:49:47   lastArrival     2015-10-14 18:49:47
     2015-10-14 06:57:38   lastDeparture   2015-10-14 06:57:38
     2015-10-14 18:49:47   lastDurAbsence  11:52:09
     2015-10-14 18:49:47   lastDurAbsence_cr 712
     2015-10-14 06:57:38   lastDurPresence 07:56:36
     2015-10-14 06:57:38   lastDurPresence_cr 477
     2015-10-14 18:45:06   lastLocation    Bus
     2015-10-14 06:57:38   lastMood        calm
     2015-10-14 18:49:47   lastState       absent
     2015-10-14 18:49:47   location        home
     2015-10-14 18:49:47   mood            calm
     2015-10-14 18:49:47   presence        present
     2015-10-14 18:49:47   state           home
   Timer:
   group      location
   icon       people_sensor
   room       Haus,Residents
   rr_realname group
   sortby     1
   webCmd     state
Micha
Hardware:
CoolTux
Deinem Residents Objekt fehlen die Roommates im Internal. So gibt es keine Zuordnung welche Roommates zu diesem Residentsobjekt gehören.
Das TuxNet Wiki:
mfeske
#4
Habe ich hier was überlesen oder versteckt sich die Lösung woanders?
Micha
Hardware:
CoolTux
Zitat von: mfeske am 14 Oktober 2015, 20:17:24
Habe ich [ur=http://www.fhemwiki.de/wiki/Anwesenheitserkennungl]hier[/url] was überlesen oder versteckt sich die Lösung woanders?
Micha
Lese mal die Commandref zu Roommate und Residents.
define <rr_FirstName> ROOMMATE [<Device Name der Bewohnergruppe>]
Das TuxNet Wiki:
mfeske
#6
Hallo CoolTux,
danke für den Hinweis auf die commandref , das wiki beschreibt ja die Vorgehensweise und ich habe ja auch:
define location_michael ROOMMATE Bewohner,Eltern
attr location_michael alias Location Michael
attr location_michael devStateIcon .*home:user_available:absent .*absent:user_away:home .*gone:user_ext_away:home .*gotosleep:scene_toilet:asleep .*asleep:scene_sleeping:awoken .*awoken:scene_sleeping_alternat:home .*:user_unknown:home
attr location_michael group location
attr location_michael icon people_sensor
attr location_michael room Haus,Residents
attr location_michael rr_realname group
attr location_michael sortby 1
attr location_michael webCmd state
gesetzt. Ich gehe mal davon aus, das Firstname nicht zwangsläufig mit rr_ beginnen muss ?! Roommate funktioniert ja jetzt und zeigt mir verschiedene Statis an. Aber RESIDENTSscheint diese nicht auszuwerten obwohl mit define location_michael ROOMMATE Bewohner,Eltern gesetzt.
define Eltern RESIDENTS
attr Eltern alias Eltern
attr Eltern devStateIcon .*home:status_available:absent .*absent:status_away_1:home .*gone:status_standby:home .*none:control_building_empty .*gotosleep:status_night:asleep .*asleep:status_night:awoken .*awoken:status_available:home .*:user_unknown:home
attr Eltern group Home State
attr Eltern icon control_building_filled
attr Eltern room Haus,Residents
attr Eltern webCmd state
define Bewohner RESIDENTS
attr Bewohner alias Bewohner
attr Bewohner devStateIcon .*home:status_available:absent .*absent:status_away_1:home .*gone:status_standby:home .*none:control_building_empty .*gotosleep:status_night:asleep .*asleep:status_night:awoken .*awoken:status_available:home .*:user_unknown:home
attr Bewohner group Home State
attr Bewohner icon control_building_filled
attr Bewohner room Haus,Residents
attr Bewohner webCmd state
Es scheinen ja auch mal Daten dort gelandet zu sein:
   NAME       Eltern
   NR         390
   STATE      absent
   TYPE       RESIDENTS
   Readings:
   alias      Eltern
   group      Home State
   room       Haus,Residents
   webCmd     state
Aber ich werde jetzt für roomate als home angzeigt:
   DEF        Bewohner,Eltern
   NR         388
   RESIDENTGROUPS
   STATE      home
   TYPE       ROOMMATE
   Readings:
     2015-10-16 16:13:45   durTimerAbsence 00:00:00
     2015-10-16 16:13:45   durTimerAbsence_cr 0
     2015-10-16 17:01:45   durTimerPresence 00:48:00
     2015-10-16 17:01:45   durTimerPresence_cr 48
     2015-10-16 16:13:45   lastArrival     2015-10-16 16:13:45
     2015-10-16 07:02:22   lastDeparture   2015-10-16 07:02:22
     2015-10-16 16:13:45   lastDurAbsence  09:11:23
     2015-10-16 16:13:45   lastDurAbsence_cr 551
     2015-10-16 07:02:22   lastDurPresence 12:48:34
     2015-10-16 07:02:22   lastDurPresence_cr 769
     2015-10-16 16:11:30   lastLocation    Bus
     2015-10-16 07:02:22   lastMood        calm
     2015-10-16 16:13:45   lastState       absent
     2015-10-16 16:13:45   location        home
     2015-10-16 16:13:45   mood            calm
     2015-10-16 16:13:45   presence        present
     2015-10-16 16:13:45   state           home
   Timer:
   group      location
   icon       people_sensor
   room       Haus,Residents
   rr_realname group
   sortby     1
   webCmd     state
Was aber RESIDENTS nicht zu interessieren scheint.
Micha
Hardware:
mfeske
#7
Ich habe jetzt alle ROOMMATE neu angelegt und es funktioniert. Wunderbare Welt, vermutlich hatte ich irgendwo einen Syntaxfehler.
Micha
Hardware:
mfeske
Rolle rückwärts,
sobald ich die group auf location und den Alias auf den Vornamen geändert habe. Funktioniert es nicht mehr.
Hardware:
Loredo
Wenn du den Vornamen im Attribut 'alias' führst, dann musst du auch das Attribut rr_realname entsprechend auf 'alias' setzen, damit die Module wissen, woher sie den Vornamen nehmen sollen.
Der FHEM Gerätename kann heißen wie er will. Wenn man ein ROOMMATE oder GUEST Device mit Hilfe des set-Kommandos in einem RESIDENTS Device anlegt, dann übergibt man dort der Einfachheit halber den Vornamen und es wird automatisch das Format rr_Vorname für den Gerätenamen verwendet.
Ein GUEST Device hat den Vornamen dann per Default im alias-Attribut, ein ROOMMATE per Default im group-Attribut. Hintergrund ist, dass ich davon ausgehe, dass man für diesen Bewohner auch noch mehr Einstellungen hat (z.B. einen Wakeuptimer), welcher dann auch in diese Gruppe einsortiert und somit alles zusammen dargestellt wird. Das kann man nach dem anlegen eines Devices beliebig ändern wie man möchte, es ist nur eine initiale Voreinstellung.
Maintainer:
mfeske
Prima, danke. Den Hintergrund hatte ich so nicht gesehen. Jetzt funktioniert es zuverlässig. Zu mindest home und absent. Die Fehler die entstehen dürften eher gerätebedingt sein.
Wichtig war mir erstmal home / absent, wenn jetzt noch egiGeozone zuverlässig funktioniert bin ich glücklich und zufrieden :-)
Micha
Hardware:
