FIBARO System FGRM222 Roller Shutter State
Begonnen von PNinBB, 23 August 2015, 13:37:52
krikan
Hallo Max,
mir sind keine Probleme bekannt. Du müsstest bitte ggfs. ein paar mehr Infos liefern. Am besten list mit den hier beschriebenen Abfragen: http://www.fhemwiki.de/wiki/Z-Wave#Welche_Infos_sollten_Anfragen_im_ZWave-Forum_enthalten.3F
Gruß, Christian
Sirel
Hallo Christian,
anbei die Details:
   DEF        c1c7df23 2
   IODev      zwave
   LASTInputDev zwave
   MSGCNT     4
   NAME       RL_WZ_Mitte
   NR         42
   STATE      versionClassRequest PROTECTION
   TYPE       ZWave
   homeId     c1c7df23
   isWakeUp
   lastMsgSent 1450011555.88694
   nodeIdHex  02
   zwave_MSGCNT 4
   zwave_RAWMSG 0004000206850303010002
   zwave_TIME 2015-12-13 13:58:24
   Readings:
     2015-08-02 16:36:43   CMD             ZW_APPLICATION_UPDATE
     2015-10-20 21:00:26   SEND_DATA       failed:00
     2015-07-29 01:49:22   UNPARSED        WAKE_UP 028406
     2015-06-20 19:54:02   assocGroup_01   Max 10 Nodes 01
     2015-06-20 19:54:09   assocGroup_02   Max 10 Nodes
     2015-06-20 19:54:13   assocGroup_03   Max 01 Nodes 02
     2015-06-18 21:28:29   assocGroup_04   Max 00 Nodes
     2015-12-13 13:58:24   assocGroup_1    Max 16 Nodes zwave
     2015-12-13 13:58:24   assocGroup_2    Max 16 Nodes
     2015-12-13 13:58:24   assocGroup_3    Max 1 Nodes RL_WZ_Mitte
     2015-12-13 13:58:24   assocGroups     3
     2015-12-13 13:58:48   configEnergyReports 10
     2015-12-13 13:58:48   configForcedRollerShutterCalibration Default
     2015-12-13 13:58:48   configInRollerBlindModeOrVenetianBlind17 10
     2015-12-13 13:58:48   configInVenetianBlindModeTheParameter12 150
     2015-12-13 13:58:51   configManagingLamellasInResponseTo35 SetLamellasToTheirExtreme1
     2015-12-13 13:58:51   configMotorOperationDetection 10
     2015-12-13 13:58:51   configMotorOperationTime 240
     2015-12-13 13:58:51   configPeriodicPowerOrEnergyReports 3600
     2015-12-13 13:58:51   configPowerReports 10
     2015-12-13 13:58:54   configReportsType BlindPositionReportsSentToThe1
     2015-12-13 13:58:54   configResponseToFloodingAlarm NoReaction
     2015-12-13 13:58:54   configResponseToGeneralAlarm CloseBlind
     2015-12-13 13:58:55   configResponseToSmokeCOOrCO2Alarm OpenBlind
     2015-12-13 13:58:55   configResponseToTemperatureAlarm OpenBlind
     2015-12-13 13:58:55   configRollerShutterOperatingModes RollerBlindModeWithPositioning
     2015-12-13 13:58:55   configScenesAssociationsActivation AssociationsActivation
     2015-12-13 13:58:55   configSelfMeasurement SelfMeasurementInactive
     2015-12-13 13:58:55   configSetLamellasBackToPrevious13 LamellasReturnToPreviouslySet1
     2015-12-13 13:58:55   configSwitchType MomentarySwitches
     2015-06-18 21:54:53   energy          0 kWh
     2015-06-18 21:17:01   meterSupported  type: energy scales: 0:kWh, 2:W resetable: yes
     2015-07-06 18:30:34   model           FIBARO System FGRM222 Roller Shutter Controller 2
     2015-07-06 18:30:34   modelConfig     fibaro/fgrm222.xml
     2015-07-06 18:30:34   modelId         010f-0301-1001
     2015-12-13 11:52:43   pct             89
     2015-12-13 11:33:39   position        80
     2015-12-13 13:59:15   position_2      89
     2015-07-06 18:41:19   power           0.0 W
     2015-07-06 18:41:38   reportedState   dim 50
     2015-12-13 13:59:15   state           versionClassRequest PROTECTION
     2015-12-13 13:59:15   transmit        OK
     2015-06-18 21:54:30   versionClass_01 00
   Alle_Rolläden struc_RL_Alle
   IODev      zwave
   RL_EG_alle struc_RL_EG_Gesamt
   RL_Wohnzimmer struc_RL_Wohnzimmer
   alias      RL Wohnzimmer Essbereich
   classes    MANUFACTURER_SPECIFIC VERSION CONFIGURATION ASSOCIATION SWITCH_BINARY POWERLEVEL METER SENSOR_MULTILEVEL FIRMWARE_UPDATE_MD SWITCH_BINARY MANUFACTURER_PROPRIETARY PROTECTION MARK METER SENSOR_MULTILEVEL MANUFACTURER_PROPRIETARY SCENE_ACTIVATION SWITCH_MULTILEVEL SWITCH_BINARY
   devStateIcon Hoch:fts_shutter_10@red Runter:fts_shutter_100@green ....10\d:fts_shutter_100 ....9\d:fts_shutter_10 ....8\d:fts_shutter_20 ....7\d:fts_shutter_30 ....6\d:fts_shutter_40 ....5\d:fts_shutter_50 ....4\d:fts_shutter_60 ....3\d:fts_shutter_70 ....2\d:fts_shutter_80 ....1\d:fts_shutter_90 up:fts_shutter_up down:fts_shutter_down
   eventMap   on:Hoch off:Runter stop:Stop
   group      RL_Wohnzimmer
   room       Aktoren,Wohnzimmer
   userReadings position_2 {ReadingsVal("RL_WZ_Mitte","state","") =~"dim"?ReadingsNum("RL_WZ_Mitte","state",""):ReadingsVal("RL_WZ_Mitte","pct","")}
   userattr   Alle_Rolläden Alle_Rolläden_map RL_EG_alle RL_EG_alle_map RL_Wohnzimmer RL_Wohnzimmer_map group_map structexclude
   vclasses   ASSOCIATION:02 CONFIGURATION:01 FIRMWARE_UPDATE_MD:01 MANUFACTURER_PROPRIETARY:01 MANUFACTURER_SPECIFIC:01 METER:02 POWERLEVEL:01 PROTECTION:02 SCENE_ACTIVATION:01 SENSOR_MULTILEVEL:02 SWITCH_BINARY:01 SWITCH_MULTILEVEL:03 VERSION:01
   verbose    3
   webCmd     Hoch:Runter:Stop
Über das Userreading habe ich mir das Reading Position_2 gesetzt.
Heißt, bei dir aktualisiert sich das Positionsreading automatisch?
Vielen Dank vorab und viele Grüße,
Max
krikan
Hallo Max,
das funktioniert bei mir mit Raffstores; wäre schlimm wenn nicht, habe Rudi schließlich den Patch eingereicht.
Bei Dir fällt mir auf:
Ist wirklich NodeId 2 Dein Controller? Typischerweise ist das 1. Bitte mal kontrollieren und ggfs. abändern.
Gruß, Christian
Sirel
Hi Christian,
du hast Recht, da ist die falsche Controller ID. Müsste 01 heißen.
Habe es eben mit RL_WZ_Mitte associationDel 3 2 versucht, lässt sich aber nicht löschen. Gibt es da einen Trick?
Vielen Dank und daran wird es sicherlich liegen!
Max
krikan
Nein, der Befehl sieht richtig aus. Ich habe es bei mir gerade noch mal getestet. Hier funktioniert es. Hast Du noch mal das Reading mit "get RL_WZ_Mitte association 3" neu abgerufen? Keine Löschung?
Sirel
Hi Christian,
ja, habe es gerade noch mal gecheckt und nun läuft es! Danke für Deine Hilfe!
Dir noch einen schönen Abend und super Arbeit die Du hier machst!
Viele Grüße und nochmal besten Dank,
Max
