Hm threeStateSensor Fensterkontakt event-min-interval ohne Funktion
Begonnen von rainer1962, 29 November 2015, 17:20:37
rainer1962
leider funktioniert bei meinen threeStateSensoren von Homematic (HM-Sec-SC-2) das event-min-interval nicht.
Es kommen immer nur events wenn der Kontakt betätigt wird.
Weiss jemand woran das liegen kann?
   DEF        24D132
   HMLAN1_MSGCNT 48
   HMLAN1_RAWMSG E24D132,0040,0B8D6964,04,FFCD,80A24124D132257868013BC8
   HMLAN1_RSSI -51
   HMLAN1_TIME 2015-11-29 16:32:10
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     48
   NAME       Sensor_Badtuer
   NR         187
   NTFY_ORDER 50-Sensor_Badtuer
   STATE      open
   TYPE       CUL_HM
   lastMsg    No:80 - t:41 s:24D132 d:257868 013BC8
   peerList   Heizkoerper_Bad_WindowRec,
   protEvt_AESCom-ok 12 last_at:2015-11-29 16:32:10
   protLastRcv 2015-11-29 16:32:10
   protSnd    12 last_at:2015-11-29 16:32:10
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-48.37 min:-57 max:-45 lst:-51 cnt:24
   Readings:
     2015-11-29 14:30:43   Activity        alive
     2015-10-14 08:11:50   CommandAccepted yes
     2015-10-14 08:07:05   D-firmware      2.2
     2015-10-14 08:07:05   D-serialNr      KEQ0951296
     2015-10-14 08:11:50   PairedTo        0x257868
     2015-10-14 08:12:01   R-Heizkoerper_Bad_WindowRec-expectAES on
     2015-10-14 08:12:01   R-Heizkoerper_Bad_WindowRec-peerNeedsBurst on
     2015-07-11 12:42:42   R-cyclicInfoMsg on
     2015-07-11 12:42:43   R-eventDlyTime  0 s
     2015-07-11 12:42:42   R-pairCentral   0x257868
     2015-07-11 12:42:42   R-sabotageMsg   on
     2015-07-11 12:42:43   R-sign          on
     2015-10-14 08:11:50   RegL_00:        02:01 09:01 0A:25 0B:78 0C:68 10:01 14:06 00:00
     2015-10-14 08:11:51   RegL_01:        08:01 20:60 21:00 22:64 30:06 00:00
     2015-10-14 08:12:01   RegL_04:Heizkoerper_Bad_WindowRec 01:81 00:00
     2015-11-29 16:32:10   aesCommToDev    ok
     2015-10-14 08:11:49   aesKeyNbr       08
     2015-11-28 06:48:49   alive           yes
     2015-11-29 16:32:10   battery         ok
     2015-11-29 16:32:10   contact         open (to HMLAN1)
     2015-11-29 14:30:43   peerList        Heizkoerper_Bad_WindowRec,
     2015-11-28 06:48:49   recentStateType info
     2015-11-28 06:48:49   sabotageError   off
     2015-11-29 16:32:10   state           open
     2015-11-29 16:32:10   trigDst_257868  noConfig
     2015-11-29 16:32:10   trig_aes_HMLAN1 ok:59
     2015-11-29 16:32:10   trigger_cnt     59
   Helper:
     HM_CMDNR   128
     mId        00B1
     rxType     28
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +24D132,01,04,02
       nextSend   1448811129.54812
       prefIO
       rxt        2
       vccu
       p:
         24D132
         01
         04
         02
     Mrssi:
       mNo        80
       Io:
         HMLAN1     -49
     Prt:
       bErr       0
       sProc      0
       sleeping   0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMLAN1
       flg        A
       ts         1448811130.49441
       ack:
         HASH(0x188b8d0)
         80800225786824D1320101C800
     Rssi:
       At_hmlan1:
         avg        -48.375
         cnt        24
         lst        -51
         max        -45
         min        -57
     Shadowreg:
   Role:
   IODev      HMLAN1
   actCycle   028:00
   actStatus  alive
   aesCommReq 1
   autoReadReg 4_reqStatus
   devStateIcon open:fts_door_open@red closed:fts_door@green .*:fts_door@orange
   event-min-interval .*:900
   event-on-change-reading .*
   expert     2_full
   firmware   2.2
   fp_Grundriss 359,1037,0,,
   model      HM-SEC-SC-2
   peerIDs    00000000,30971E03,
   room       Bad
   serialNr   KEQ0951296
   subType    threeStateSensor
2xFHEM auf Raspi3,MAXLAN,HMLAN,KeyMatic,MAX Heizung,2x HM-WDS10_TH-O,3xHM-SEC-SD,3xHM Wandtaster 2-Kanal, 2xWandtaster 6-Kanal,1xHM Bewegungsmelder,4xHM EinbauActor,4x Jalousien Actor,2xEGPM2LAN,2xHM DimAktor,2xFritzbox 6840/6490,4-20ma Levelsensor-Ina219,PIP5048,Raspi2 als Floorplan,4xJeeLink
justme1968
natürlich funktionieren die attribute. wann soll denn sonst ein event kommen?
fhem 'erfindet' keine events. die beiden attribute beeinflussen nur wie die events weiterverarbeitet werden wenn dein device welche liefert. wenn das device nichts sendet passiert auch nichts.
  andre
rainer1962
interessant ist nur dabei dass bei dem 'attribut event-min-intervall' auch ein event gesendet werden soll wenn das device keinen event sendet !!
und dieses passiert eben nicht ...
bei anderen devices funktioniert dies, aber eben nur bei diesem einen Devicetyp nicht.
frank
Zitatbei anderen devices funktioniert dies,
kann nicht sein. liefere beweise.
FHEM: 6.0(SVN) => Pi3(buster)
rainer1962
hier ein Auszug aus der connadref:
event-min-interval
Dieses Attribut enthält eine durch Kommata getrennte Liste von "readings:minInterval" Paare. readings kann ein regexp sein. Ein Event wird nur dann generiert, falls seit dem letzten Auftreten des gleichen Events mindestens minInterval Sekunden vergangen sind.
rainer1962
hier funktioniert es :
   CHANGED
   NAME       USV
   NR         17
   SMBus_exists 1
   STATE      RPI / 4.12 V (Bat) / 5.02 V (PRI)/ 33 °C
   TYPE       UPSPICO
   Readings:
     2015-11-29 17:50:36   BatTemp         33
     2015-11-29 17:50:36   ErrorCode       00000000
     2015-11-29 17:50:36   FanSpeed        0
     2015-11-29 17:50:36   FanTemp         e8
     2015-11-29 17:50:36   LED_Blue        0
     2015-11-29 17:50:36   LED_Red         0
     2015-11-29 17:50:36   PowerSource     RPI
     2015-11-29 17:50:36   VoltageBAT      4.12
     2015-11-29 17:50:36   VoltageRPI      5.02
     2015-11-29 17:50:36   logging1        1 4.12 5.02 33
     2015-11-29 17:46:32   powerstatus_last RPI
   event-on-change-reading Power.*,Voltage.*:0.4,BatTemp:5,Error.*
   poll_interval 5
   room       Geräte Status,System
   stateFormat PowerSource / VoltageBAT V (Bat) / VoltageRPI V (PRI)/ BatTemp °C
justme1968
#6
fhem erzeugt oder erfindet keine events. wenn das device nichts sendet gibt es keine events. niemals.
die beiden attribute beeinflussen nur was mit den events passiert die vom device kommen. welche ausgefiltert und welche weitergeleitet werden. wenn von device nichts kommt wird auch nichts weitergeleitet.
wenn du bei deiner usv das attribut löschst wirst du sehen das sie minütlich ein event erzeugt. mit gesetztem attribut wird dann so ausgefiltert das nur noch alle 15 minuten eines durchgelassen wird. wenn du deine usv abziehst kommen auch keine events mehr. auch nicht alle 15 minuten.
rainer1962
stimmt,
und ich dachte immer dass event-min-interval auch dann einen event erzeugt wenn das device mal keinen event sendet ....
dann muss ich das irgendwie nachbilden damit die plotabrisse minimiert werden  ...
hier ,
http://forum.fhem.de/index.php/topic,29970.msg226690.html#msg226690
wird es aber irgndwie anders erklärt .... ?????
oder versteh ich das völlig falsch ?
stromer-12
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
rainer1962
Habe es jetzt anders gelöst und lass über eine Funktion aller 15 minuten prüft ob das reading was ich plotten möchte länger als 15 Minuten keine Änderung erfahren hat.
Wenn ja wird dann ein Logeintrag mit "trigger device reading" erzeugt.
99_myUtils.pm
sub set_log_hm($$){
my ($device,$reading)=@_;
my $zeit=900; #aktualisierungszeit
my $logentry = ReadingsVal($device,$reading,"addLog: invalid reading");
my $last_time = ReadingsTimestamp($device,$reading,'1970-01-01 01:00:01');
$last_time = time_str2num($last_time);
if (time() - $last_time > $zeit) {  # 900 secunden = 15Minuten
    # wenn aenderungszeit laenger als 15 minten her ist dann einen trigger auf das Geraet ausloesen um einen Logeintrag zu bekommen
    if ($reading =~ m,state,i) {
            fhem "trigger $device $logentry   << addLog";
            } else {
             fhem "trigger $device $reading: $logentry   << addLog";
at device:
define set_log_hm_at at +*00:15:00 {
   set_log_hm('Sensor_Badtuer','state');
   set_log_hm('Sensor_Wohnungstuer','state');
Vielleicht hilf es jemanden ...
justme1968
