Absturz beim Öffnen von SVG Plots
Begonnen von chunter1, 06 Dezember 2015, 01:26:36
chunter1
hat jemand eine Idee warum beim Öffnen eines SVG Plots FHEM abstürzt?
Folgendes steht in der Log-Datei:
2015.12.06 01:23:25 1: PERL WARNING: Argument "25"" isn't numeric in subtraction (-) at ./FHEM/98_SVG.pm line 1721.
2015.12.06 01:23:25 3: stacktrace:
2015.12.06 01:23:25 3:     main::__ANON__                      called by ./FHEM/98_SVG.pm (1721)
2015.12.06 01:23:25 3:     main::SVG_render                    called by ./FHEM/98_SVG.pm (1117)
2015.12.06 01:23:25 3:     main::SVG_doShowLog                 called by ./FHEM/98_SVG.pm (992)
2015.12.06 01:23:25 3:     main::SVG_showLog                   called by ./FHEM/01_FHEMWEB.pm (726)
2015.12.06 01:23:25 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (440)
2015.12.06 01:23:25 3:     main::FW_Read                       called by fhem.pl (3162)
2015.12.06 01:23:25 3:     main::CallFn                        called by fhem.pl (656)
2015.12.06 01:23:25 1: PERL WARNING: Use of uninitialized value $data{"currval5"} in sprintf at ./FHEM/98_SVG.pm line 2027.
2015.12.06 01:23:25 3:     main::__ANON__                      called by ./FHEM/98_SVG.pm (2026)
2015.12.06 01:23:25 1: PERL WARNING: Use of uninitialized value $data{"currval6"} in sprintf at ./FHEM/98_SVG.pm line 2027.
