98_RandomTimer: generating Log-entries, when the Value()-Funktion of the device does not respond with on/off. The Value()-Funktion is used to get the actual switching-state of the device
Begonnen von System, 07 Januar 2016, 01:00:07
System
98_RandomTimer: generating Log-entries, when the Value()-Funktion of the device does not respond with on/off. The Value()-Funktion is used to get the actual switching-state of the deviceView Changes
Source: 98_RandomTimer: generating Log-entries, when the Value()-Funktion of the device does not respond with on/off. The Value()-Funktion is used to get the actual switching-state of the device
