Irrometer Company WEM-II Watermark Electronic Module Bodenfeuchtesensoren
Begonnen von thghh, 28 Februar 2016, 20:43:41
thghh
NEU und unbenutzt!
Aufgrund einer Änderung unserer Gartenplanung, verkaufe ich unsere Bodenfeuchtesensoren für Bewässerungssysteme oder um diese direkt in die Ventilleitung zu schalten.
Die Geräte sind neu! Die Sensoren sind voll funktionsfähig.
Es handelt sich hier um Profisensoren!
Es sind insgesamt 4 Einheiten zu verkaufen und der Preis beträgt 150 Euro pro Einheit (WEM + 2 Sensoren, wie im Bild dargestellt)
Anbei die englische Beschreibung:
Brand New Watermark Electronic Module II
Soil Moisture Automation For any 24VAC Irrigation Controller
Overrides valve operation when soil becomes wetter than the moisture setting. Allows any 24 VAC solenoid valve to be controlled individually by two moisture sensors located in the soil at different depths of the irrigated area. Takes a reading each time the valve is programmed to operate. Also used to interrupt controller master valve circuit or common, to override entire irrigation controller. Select from 11 moisture levels or bypass position for sensor control override. Includes WEM control module and two WATERMARK #200SS-5 sensors. Weather resistant solid state electronics.
The WATERMARK Electronic Module (WEM) is an electronic unit designed to control valves based on soil moisture requirements. Adjustable to plant requirements from 10 to 120 Centibars, the WEM uses input from WATERMARK Soil Moisture sensors to control individual valves, valve groups, or all valves. Irrigation controllers equipped with WATERMARK Electronic Modules control irrigation based on measured soil moisture, rather than the theoretical assumptions made by a climate based controller. The WEM includes a manual override and works with all 24 VAC controllers. Solid state electronics and potting ensure the module is maintenance free and long lasting.
WEM Features:
Control your irrigation costs
Saver water, labor, and energy
Deliver water only when and where necessary
Grow healthier turf and plants
Mitigate pest and disease problems
Reduce fertilizer leaching
Protect groundwater by minimizing runoff
No more re-programing controllers for seasonal changes
Umfangreiche Haussteuerung auf Basis der Eltako Serie 14 inkl. DALI und GFVS Save II
