Kein Webinterface
Begonnen von noxx, 25 März 2016, 10:29:48
noxx
Hallo
ich habe FHEM hiernach installiert:
http://www.benjaminroesner.com/blog/fhem-auf-dem-raspberry-pi-installieren/
Leider komme ich nicht auf die Webgui.
Im Log steht:
2016.03.25 10:21:59 1: Including fhem.cfg
2016.03.25 10:21:59 3: telnetPort: port 7072 opened
2016.03.25 10:21:59 3: WEB: port 8083 opened
2016.03.25 10:21:59 3: WEBphone: port 8084 opened
2016.03.25 10:21:59 3: WEBtablet: port 8085 opened
2016.03.25 10:21:59 2: eventTypes: loaded 0 events from ./log/eventTypes.txt
2016.03.25 10:21:59 1: usb create starting
2016.03.25 10:22:00 3: Probing CUL device /dev/ttyACM0
2016.03.25 10:22:00 3: Probing TCM_ESP3 device /dev/ttyACM0
2016.03.25 10:22:00 3: Probing ZWDongle device /dev/ttyACM0
2016.03.25 10:22:01 3: Probing FRM device /dev/ttyACM0
2016.03.25 10:22:55 1: Including fhem.cfg
2016.03.25 10:22:55 3: telnetPort: port 7072 opened
2016.03.25 10:22:55 3: WEB: port 8083 opened
2016.03.25 10:22:55 3: WEBphone: port 8084 opened
2016.03.25 10:22:56 3: WEBtablet: port 8085 opened
2016.03.25 10:22:56 2: eventTypes: loaded 0 events from ./log/eventTypes.txt
2016.03.25 10:22:56 1: Including ./log/fhem.save
2016.03.25 10:22:56 3: Probing CUL device /dev/ttyAMA0
2016.03.25 10:22:56 3: Can't open /dev/ttyAMA0: Permission denied
2016.03.25 10:22:56 1: usb create end
2016.03.25 10:22:56 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at fhem.pl line 556.
2016.03.25 10:22:56 1: PERL WARNING: Use of uninitialized value $motd in string eq at fhem.pl line 561.
2016.03.25 10:22:56 1: PERL WARNING: Use of uninitialized value $motd in string ne at fhem.pl line 564.
2016.03.25 10:22:56 1: PERL WARNING: Use of uninitialized value $motd in substitution (s///) at fhem.pl line 565.
2016.03.25 10:22:56 1: PERL WARNING: Use of uninitialized value $text in concatenation (.) or string at fhem.pl line 828.
2016.03.25 10:22:56 0: Featurelevel: 5.7
2016.03.25 10:22:56 0: Server started with 9 defined entities (version $Id: fhem.pl 9893 2015-11-15 08:43:05Z rudolfkoenig $, os linux, user fhem, pid 4190)
2016.03.25 10:22:59 0: Server shutdown
2016.03.25 10:23:15 1: Including fhem.cfg
2016.03.25 10:23:15 3: telnetPort: port 7072 opened
2016.03.25 10:23:16 3: WEB: port 8083 opened
2016.03.25 10:23:16 3: WEBphone: port 8084 opened
2016.03.25 10:23:16 3: WEBtablet: port 8085 opened
2016.03.25 10:23:16 2: eventTypes: loaded 0 events from ./log/eventTypes.txt
2016.03.25 10:23:16 1: Including ./log/fhem.save
2016.03.25 10:23:16 1: usb create starting
2016.03.25 10:23:17 3: Probing CUL device /dev/ttyACM0
2016.03.25 10:23:17 3: Probing TCM_ESP3 device /dev/ttyACM0
2016.03.25 10:23:17 3: Probing ZWDongle device /dev/ttyACM0
2016.03.25 10:23:17 3: Probing FRM device /dev/ttyACM0
Jemand eine Ide?
KölnSolar
log sieht doch gut aus. liegts an Deinem Aufruf, den Du nicht gepostet hast ?
z.B. http://192.168.abc.xyz:8083/fhem/ eingegeben ? Und wie fällt die response aus ?
noxx
#2
rufe mit
http://192.168.1.224:8083
auf, aber der Browser zeigt nichts an.
Was ist mit der PERL WARNING ? Kann da das Problem liegen?
MadMax-FHEM
Wie Browser zeigt nichts an???
Also "leere" Seite?
Fehlermeldung?
Geht ein "ping"??
FHEM PI3 Buster (Test)
Puschel74
#4
Der Aufruf von FHEM im Browser ist schon falsch.
Es fehlt das /fhem am Schluss
Edith: siehe weiter unten.
Benni
Es fehlt das /fhem am Schluss.
Das funktioniert aber normalerweise auch ohne (eben getestet auf 2 Instanzen!)
Puschel74
Korrekt.
Da scheine ich was verpasst zu haben - zumindest hänge ich aus Gewohnheit immer selbst ein /fhem an.
Der Browser ergänzt das aber selbst.
Sorry.
Benni
#7
Jemand eine Ide?
Dein FHEM wird 3 Sekunden nach dem der Server gestartet wurde schon wieder neu gestartet (bzw. heruntergefahren).
Hast du evtl. einen Watchdog (außerhalb von FHEM) eingerichtet, der auf inaktivität von FHEM prüft und dieses ggf. neu startet.
Dann solltest du dort mal die Wartezeit, bzw. die Aktivitätsprüfung checken.
