[FHZ] follow-on-for-timer
Begonnen von Dr. Boris Neubert, 17 November 2008, 21:19:02
Dr. Boris Neubert
this is for discussion:
if the attribute follow-on-for-timer is set for a FS20 device, an additional
at command is scheduled each time a on-for-timer command is issued. The at
command issues a setstate off. We thus get the following after the
timer has run down:
list hr.Pumpe
   STATE      off      <<< setstate did this
   TYPE       FS20
   Code:
     1          b9d1 00
   Readings:
     2008-11-17 17:40:00   state           on-for-timer 640   <<<< no change
   follow-on-for-timer 1
Do you think it would be appropriate to also change the readings from
to
     2008-11-17 17:50:40   state           off
as well? The advantage of such a change would be pgm3 to show the correct off
state instead of the on-for-timer state.
What do you think?
Regards,
Boris
You received this message because you are subscribed to the Google Groups "FHZ1000 users on Linux" group.
To post to this group, send email to FHZ1000-users-on-unix@googlegroups.com
To unsubscribe from this group, send email to FHZ1000-users-on-unix+unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/FHZ1000-users-on-unix?hl=en
