[FHZ] Seagate DockStar "von innen" ;)
Begonnen von Guest, 06 Januar 2010, 17:25:20
Guest
Da der DockStar ja auch mal kurz Thema war und ich nichts
neues dazu hier gelesen habe, kurz zur Info: das Passwort
ist nun bekannt ;)
wusel@greebo:~$ ssh root@dockstar-1
Warning: Permanently added 'dockstar-1' (RSA) to the list of known hosts.
root@dockstar-1's password:
sh: /usr/X11R6/bin/xauth: No such file or directory
-bash-3.2# uname -a
Linux Pogoplug 2.6.22.18 #57 Mon Aug 31 16:31:01 PDT 2009 armv5tejl unknown
-bash-3.2# free
               total         used         free       shared      buffers
   Mem:       126064        20512       105552            0            0
  Swap:            0            0            0
Total:       126064        20512       105552
-bash-3.2# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/mtdblock2           32.0M     16.3M     15.7M  51% /
none                     61.6M     12.0k     61.5M   0% /tmp
-bash-3.2# dmesg (Auszug)
[    0.000000] Memory: 128MB 0MB 0MB 0MB = 128MB total
[    0.000000] Calibrating delay loop... 1192.75 BogoMIPS (lpj=5963776)
[    0.240000]   Marvell Development Board (LSP Version KW_LSP_4.2.7_patch21_with_rx_desc_tuned)-- SHEEVA PLUG  Soc: 88F6281 A0 LE
[    0.890000] serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
[    0.900000] serial8250.0: ttyS1 at MMIO 0xf1012100 (irq = 34) is a 16550A
[    0.980000]     o eth0, ifindex = 1, GbE port = 0
[    0.990000]     o eth1, ifindex = 2, GbE port = 1
[    1.040000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit)
[    1.150000] Creating 4 MTD partitions on "nand_mtd":
[    1.160000] 0x00000000-0x00100000 : "u-boot"
[    1.160000] 0x00100000-0x00500000 : "uImage"
[    1.170000] 0x00500000-0x02500000 : "root"
[    1.170000] 0x02500000-0x10000000 : "data"
-bash-3.2# mkdir /tmp/opt
-bash-3.2# mount /dev/mtdblock3 /tmp/opt
-bash-3.2# df -h
/dev/mtdblock3          219.0M      5.0M    214.0M   2% /tmp/opt
Also 128 MB RAM, 256 MB NAND Flash und wenn ich die LEDs an meinem
Switch richtig deute, ebenfalls GBit-Ethernet - und 'nen 4-Port-USB-
Hub gleich eingebaut. Details, das Passwort und mehr Spaß mit dem
Pogoplug in weiß über http://openpogo.com/forum/viewtopic.php?id=76
         kai
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en.
Guest
Hallo Kai,
du bist genial, danke für die Info.
Eine Frage bleibt bei mir, wie schauts hier mit alternativen Linuxen
(Debian etc) aus?
Weniger Ram hat die Dockstar (Sheeva 512, Dockstar 256 oder 128),
ansonsten sieht es gleich aus.
Perl, Apache, PHP, da dürfte die Dockstar dem Sheeva unterlegen sein,
allein wegen dem Ram.
Danke, Viele Grüße
Stefan
On Jan 6, 5:25 pm, "Kai 'wusel' Siering"
> ist nun bekannt ;)
> -bash-3.2# uname -a
> -bash-3.2# free
>   Swap:            0            0            0
> -bash-3.2# df -h
> -bash-3.2# df -h
> Hub gleich eingebaut. Details, das Passwort und mehr Spa mit dem
> Pogoplug in wei berhttp://openpogo.com/forum/viewtopic.php?id=76
>                         kai
Guest
You're welcome.
> (Debian etc) aus?
Da sinniere ich auch noch; im Prinzip sollte man (vorsichtig, weil
noch kein Consolen.Zugang bekannt ist IIRC) wie bei Pogoplug vor-
gehen können. Andererseits, die Android-Anwendung von Pogoplug ist
auch nett; wenn ich nur deren Zugriff auf andere Daten verhindern
könnte, hätte ich gerne beides ;)
Depends, denke ich, je nachdem, welche Datenmassen Du bewegen willst.
Als "dock" ist die gut dabei, vgl. NSLU2 ;)
         kai
Guest
On 6 Jan., 17:25, "Kai 'wusel' Siering"
> ist nun bekannt ;)
Super! dann ist es nur noch eine Sache der Zeit, bis es auch hierfuer
fertige HowTos (WIKI ;-) ) gibt, bis da ein komplettes Debian drauf
laeuft.
>                         kai
Da Teil gibt es fuer 80EUR inkl Porto und wie geschrieben inkl 4-Port
HUB. Alleine ein *guter* 4-Port-Hub kostet schon 25.-EUR.
Kai: deine Empfehlung? Sheevaplug im Original mit 512MB RAM oder
diesen Seagate-Plug (der Sheeva-Plug in der dmesg stehen hat)  mit
128MB inkl. 4-Port-Hub? Sind das wirklich die einzigen Unterschiede
(ausser Bauform)?
Du hast ja offenbar beide.
Martin
Guest
> (ausser Bauform)?
Das sind die mir bekannten Unterschiede:
SheevaPlug                        DockStar
512 MB RAM                        128 MB RAM
512 MB NAND Flash                 256 MB NAND Flash
1 USB-Port (Host)                 4 USB-Ports
1 USB-Port (Slave: Console, JTAG) Pfostenstecker intern, Belegung (mir) noch unbekannt
1 SDCard-Einschub                 -
1 GBit-Ethernetport               1 GBit-Ethernetport
1 tty (Console, an USB slaveport) 2 tty lt. dmesg, nirgends rausgeführt
rd. 90 UKP                        rd. 80 EUR
Wichtige Unterschiede, neben RAM & Flash, sind wohl die rausge-
führte Console + JTAG beim SheevaPlug, was sich hinter der Pfos-
tenleiste beim DockStar verbirgt: keine Ahnung.
Außerdem hat SheevaPlug 'nen SD-Slot, der naturgemäß beim Desk-
Star weggelassen wurde. dmesg listet beim DeskStar ein zus.
Ethernet sowie 2x Seriell; rausgeführt ist davon nichts, ob das
irgendwo mit viel Bastellei abgreifbar wäre: keine Ahnung.
Aufgrund des (geringen) Preisunterschiedes würde ich eher unbe-
darften Bastlern den SheevaPlug weiter ans Herz legen; De-brick-
ing ist da so einfach wie das versehentliche zum-Backstein-machen
durch einen falsch gebauten Kernel ;) Der Plug *ist* eben zum
Entwickeln vorgesehen, der DeskStar hingegen ist eigentlich nur
ein überdimensionierter USB2SMB-Adapter ;)
Der fehlende SD-Slot und der kleiner Flash schränken den Einsatz-
bereich des DeskStar jenseits des "Dock seins" etwas ein; dafür
ist der Preis imho im Vergleich zum Plug zu hoch. Wer aber "nur"
einen Slug ersetzen will, der dürfte mit etwas Bastellei auch
mit dem DeskStar glücklich werden. Imho stehen "wir" da noch am
Anfang der Entwicklung (vgl. WRT54G) ...
Marvell hat jetzt allerdings PlugComputer 3.0 angekündigt, mit
angeblich 2 GHz -- auf den "Stecker" bin ich jetzt richtig ge-
spannt. Vgl. Golem ...
         kai
Guest
Apropos ...
Wie erkennt man denn einen guten? Mein self-powerd Logilink hat
7,90 bei Amazon gekostet und damit gehen CUL868 + CUL433 + Außen-
webcam (Philips PWC) plus jetzt noch 80G-2,5"-HDD (bus-powered).
Aber es stimmt schon, nicht jeder USB-Hub, auch wenn er 35,99
kosten mag, taugt was :(
         kai
Mr. P
Ja, der PlugComputer 3.0 lässt hoffen. Jedoch sind noch keine Details
(Preis, genaue technische Daten) bekannt - also wer weiß, ob es der
Kleine wirklich wert ist.
On 6 Jan., 21:36, "Kai 'wusel' Siering"
wrote:
> Apropos ...
> 7,90 bei Amazon gekostet und damit gehen CUL868 + CUL433 + Au en-
>                         kai
Greetz,
   Mr. P
Guest
Danke fuer den Vergleich. Morgen werde ich mir eine Sheeva bestellen
(fest vorgenommen), zu basteln habe ich auch so genug, und so viel
teurer wird das auch nicht zumal ich fuer FHEM, Festplatte und CUL
wohl keinen teuren USB-HUB brauchen werde (schauen wir mal).
Das wird jetzt OT und sollte bei Verlaengerung verlegt werden:
Mein aktuelles Bastelobjekt ist es an meine zweite NSLU2 aus Timeout-
Gruenden 5 (in Worten fuenf) Bluetooth-Sticks, einen USB-Stick mit
Debian Squezze und noch ein 8fach USB-Relais (Conrad, Quancom)
anzuschliessen.
Ziel ist es, mit max fuenf verschiedenen bekannten Handys, die vor der
Tuere mit aktiviertem Bluetooth stehen, auf Druck eines FS20-
Schalters  (Keymatic CAC) aus Sicherheitsgruenden mit einem USB-Relais
(nach Entfernungmessung mit RSSI-Wert und zusaetzlichen Bluetooth-
Sicherheitsabfragen) die Haustuere mit Keymatic IQ+ zu oeffnen.
FHEM koennte dann auch noch, je nach erkanntem Handy, z.B. Bier
holen ;-)
Nur, schon bei z.B. mit drei Bluetooth-Sticks (ok, selber Treiber) ist
das Debian einfach abgestuerzt. Es hat mich Tage gekostet, um
herauszufinden, dass mein 8.-EUR-USB-Hub (mit externem Strom) Schrott
ist.
In den Bewertungen bei Alternate habe ich genau mein Problem gelesen
(z.B heiss werden und Schrott) und habe einen *teuren* 7-fach-USB-Hub
gekauft (D-Link DUB-H7 fuer 31.-EUR). Das Problem ist weg :-) Mein
Prototyp hier laeuft seit Wochen stabil und wird in Kuerze verbaut :-)
Also: Qualitaet kann man von aussen nicht erkennen, am Preis auch
nicht immer, aber die Erfahrung anderer ist Gold wert :-)
Waere sicherlich ein Projekt fuer ein Wiki ;-)
Martin
Guest
Martin Haas wrote:
Danke.
Kurze Verständnisfrage:
1 Schalter, 5 Handies *gleichzeitig* vor diesem? Okay, selbst wenn,
die findet doch 1 BT-Dongle?
wusel@greebo:~$ hcitool scan
Scanning ...
         00:xx:xx:xx:xx:xx       Milestone
         00:xx:xx:xx:xx:xx       N810
         00:xx:xx:xx:xx:xx       N95
Und, um ehrlich zu sein, wäre da nicht RFID + Keycode sinniger? (Wo-
bei ich den altmodischen Schlüssel bei *meiner* Wohnungstür schon
haptisch l33t34 finde als Zahlenschlösser und dgl. Ok, ich könnte
mich auf den Klingeldruck außen über TFE & Asterisk auf dem Handy
anrufen lassen und in der Verbindung das Türöffnungs-Digit senden.
Das ist mir nahe genug dran an Die Hard 4.0 ;))
Also, Deinen Plan würde ich gerne mal, ggf. off the list, erörtern,
spannend klingt das ja, (1) BT-Dongle könnte ich außen montieren,
zusammen mit dem Ritto-Twin-Bus und der TFE5, ... ;)
         kai
Guest
On 7 Jan., 00:03, "Kai 'wusel' Siering"
Nein, fuenf verschiedene Familienhandys. Wenn ein BT-Dongle die
einzeln abfragt und auf den Abstandswert RSSI abfragt (l2ping, hcitool
-i rssi usw.), dauert es bis zu zwanzig Sekunden pro Geraet, wenn das
Geraet nicht da ist. Ein BT-Dongel kann nur seriell abfragen und nicht
parallel. So wuerde es bis zu hundert Sekunden dauern, bis der Rechner
eine Entscheidung faellen kann -- unakzeptabel.
> Scanning ...
Ein scan (auf offene BT-Devices!) dauert alleine 15-20 Sek (behaelt
das dann zwar im Cache, hilft aber nichts, wenn man von draussen
kommt). Eine direkte Abfrage kommt dann noch oben drauf. Abstandswert
RSSI + div. Sicherheitsabfragen sind erforderlich, sonst findest er
immer irgend ein Familienhandy im Haus ;-)))
Der einfachste Weg sind 5 BT-Dongle (a 8 EUR), fuer jedes Handy eines.
So ist nach max. 5sek. eine Entscheidung gefaellt.
> Und, um ehrlich zu sein, w re da nicht RFID + Keycode sinniger?
Die genannte Keymatic-Anlage Keymatic CAC (inkl. FS-20 Schalter) und
Keymatic IQ+ (siehe ELV) ist eine Keycode-Anlage. Sie laeuft bei mir
auch seit Jahren. Die Family beschwert sich aber ueber zu oft
vertippen mit anschliessender Sperrung ;-). Diese BT-Anlage (in
unmittelbarer Naehe der Tuer) ist eine Ergaenzung. Die notwendige
Keymatic KM300 laedt dann auch die Akkus in der IQ+.
Die Anlage ist somit Bestandteil von FHEM (z.B. in FHEM loggen,  je
nach Handy *Bier kalt stellen*, Alarmanlage ausschalten etc.)
Ich denke, ich werde ein WIKI dazu schreiben (wenn ich die Tage dazu
Zeit finde).
Martin
