Temperature Logging
Begonnen von Guest, 07 Februar 2012, 12:47:18
Guest
Hi all,
first of all - sorry for asking in English rather than in German.
I am currently using the FHEM software with an FHZ1000 device.
Logging to
that I have 3 FHT 80b devices in different rooms.  So far this works
excellently and I cannot complain.
Now the question.  I want to add a device to the system to log the
outside
temperature so I can see how hard the heating in working relative to
the
outside temperature.  At first glance I would guess the FS20 UTS
(Universal
Thermostat Sender) is the right device for this but I am not sure.
Can the
FS20 UTS broadcast the temperature to the FHZ100 and be picked up by
FHEM
and logged like the temperature from the FHT 80b's?
Many thanks in advance.
tiptronic
Hi user7743,
if you just want to get current temperature/humidity, you could also use the S300TH, wich is less than half the price
<http://www.elv.de/Funk-Temperatur-Luftfeuchteaußensensor-S-300-TH-fuuml;r-z-B-ELV-WS-200300,-ELV-WS-300-PC,-USB-WDE1-und-IPWE-1/x.aspx/cid_74/detail_10/detail2_20690/flv_/bereich_/marke_>
(Link to a german site)
I use a couple of those (and bought them 5.- Euros each).
andy
Am 07.02.2012 um 12:47 schrieb user7743:
> Hi all,
> Logging to
> outside
> the
> (Universal
> Can the
> FHEM
Guest
Sorry for hijacking this a bit
The S300TH does basically the same as the HMS100TF^, bust costs like
half the price? Is there any difference?
Thanks.
On 7 Feb., 12:17, Andy Fuchs wrote:
> Hi user7743,
> <http://www.elv.de/Funk-Temperatur-Luftfeuchteaußensensor-S-300-TH-fuuml;r-z-B-ELV-WS-200300,-ELV-WS-300-PC,-USB-WDE1-und-IP WE-1/x.aspx/cid_74/detail_10/detail2_20690/flv_/bereich_/marke_>
> andy
> > Hi all,
> > Logging to
> > outside
> > the
> > (Universal
> > Can the
> > FHEM
tiptronic
Am 07.02.2012 um 13:22 schrieb Dennis:
Yes - the price :-)
And the HMS sensor is outside the housing.
Otherwise for measuring temperature/humidity - no.
andy
> Thanks.
>> Hi user7743,
>> andy
>>> Hi all,
>>> Logging to
>>> outside
>>> the
>>> (Universal
>>> Can the
>>> FHEM
Guest
Bloody rip off, I wish I could build that device myslf,, would cost
around 2 Euros I reckon ^^
> Yes - the price :-)
> andy
> > Thanks.
> >> Hi user7743,
> >> andy
> >>> Hi all,
> >>> Logging to
> >>> outside
> >>> the
> >>> (Universal
> >>> Can the
> >>> FHEM
Guest
Thanks for the quick replies.  Andy, you are correct - all I want to
do is to log the temperature outside and display that in FHEM as a
graph that can be used to see that when it was 10 degrees outside,
inside was 20 degrees and the actuator was open 50% for example.
To clarify - would the S300TH talk to FHEM via my FHZ1000 directly or
do I need something else in the middle?  I ask for clarification
because on fhem.de under hardware it states "S300 devices via an
attached WS300".  I currently have no WS300.
> > Yes - the price :-)
> > andy
> > > Thanks.
> > >> Hi user7743,
> > >> andy
> > >>> Hi all,
> > >>> Logging to
> > >>> outside
> > >>> the
> > >>> (Universal
> > >>> Can the
> > >>> FHEM
Yes, the S300TH cannot be received by the FHZ1x00 family, and you cannot use
more than 8 of them (well, without hacking).
Guest
Is there still a source for 5 EURs each?
On 7 Feb., 13:17, Andy Fuchs wrote:
> Hi user7743,
> andy
> > Hi all,
> > Logging to
> > outside
> > the
> > (Universal
> > Can the
> > FHEM
> > fhem-users+unsubscribe@googlegroups.com- Zitierten Text ausblenden -
> - Zitierten Text anzeigen -
tiptronic
Dunno, but I got mine at Conrad....
andy
Am 07.02.2012 um 13:56 schrieb Marc:
>> Hi user7743,
>> andy
>>> Hi all,
>>> Logging to
>>> outside
>>> the
>>> (Universal
>>> Can the
>>> FHEM
Guest
Thanks everyone.
Based on the fact that the S300TH cannot talk to my FHZ1000 and the
fact that the HMS100T has a the external temperature probe - I have
ordered a HMS100T.
Guest
Hi Rudolf,
is there a link to, or any description of a "S300TH adress enhancement
hack" ?
Or was it "just a thought"?
My neighbour uses 4 of these sensors and i use already 3 of them.
So I´m very interested... ;o)
Thanks in advance
Frank
> hack" ?
You have to search this group, although the discussion was in german.
One method is to re-solder the s300th to 433 MHz, and use a CUL-433, the other
one is to identify it via ID+RSSI-Range in the fhem module. Don't ask me any
details for the latter, I don't want headaches again.
Guest
Thanks a lot!
I do´nt want you to get headaches! ;o)
Your tips will help me to find out more and that´s all i need.
Best regards
Frank
> > hack" ?
