SVG Temperature/Humidity strange plot
Begonnen von feryy, 29 September 2016, 09:35:40
feryy
I have a problem with SVG. I have probably set incorrectly. :(
Filelog looks like this:
define SVG_Teplomer_Obyvak_Teplomer SVG FileLog_ESPEasy_Teplomer_Obyvak_Teplomer:temp4hum4:CURRENT
2016-09-29_06:37:40 ESPEasy_Teplomer_Obyvak_Teplomer Temperature: 18.00
2016-09-29_06:37:40 ESPEasy_Teplomer_Obyvak_Teplomer Hum:23.00 Tem:18.00
2016-09-29_06:37:40 ESPEasy_Teplomer_Obyvak_Teplomer Humidity: 24.00
2016-09-29_06:37:40 ESPEasy_Teplomer_Obyvak_Teplomer Hum:24.00 Tem:18.00
2016-09-29_06:43:41 ESPEasy_Teplomer_Obyvak_Teplomer Humidity: 23.00
2016-09-29_06:43:41 ESPEasy_Teplomer_Obyvak_Teplomer Hum:23.00 Tem:18.00
2016-09-29_06:43:41 ESPEasy_Teplomer_Obyvak_Teplomer Temperature: 19.00
2016-09-29_06:43:41 ESPEasy_Teplomer_Obyvak_Teplomer Hum:23.00 Tem:19.00
SVG looks like this:
add. attachments
What am I doing wrong?
I assume you have modified you temp4hum4 file, as the standard temp4hum4 would not show any lines, since it searches with the regexps temperature and humidity and the search is not case insensitive.
Can you show your modified .gplot file or a screenshot of the PlotEditor?
