virtueller aktor und peerChan...
Begonnen von layer8, 25 September 2016, 02:17:51
layer8
ich schlage mich gerade mit dem HM-PB-6-WM55 rum - generell funktioniert alles, ABER: ich bekomme nach einem Tastendruck immer eine rote LED, was für mich bedeutet, dass der virtuelle Aktor keine Rückmeldung an die Taste sendet.
Hier mein Log:
2016-09-25 02:10:55 CUL_HM HM_3EC5A3 battery: ok
2016-09-25 02:10:55 CUL_HM HM_3EC5A3 HM_3EC5A3_Btn_01 Short
2016-09-25 02:10:55 CUL_HM HM_3EC5A3_Btn_01 Short (to Vact_dev)
2016-09-25 02:10:55 CUL_HM HM_3EC5A3_Btn_01 trigger: Short_1
2016-09-25 02:10:55 CUL_HM HM_3EC5A3_Btn_01 triggerTo_Vact_dev: Short_1
2016-09-25 02:10:55 CUL_HM HM_3EC5A3_Btn_01 trigger_cnt: 1
2016-09-25 02:10:55 CUL_HM Vact_Taster ON
2016-09-25 02:10:55 CUL_HM Vact_Taster trigLast: HM_3EC5A3_Btn_01:short
2016-09-25 02:10:55 CUL_HM Vact_Taster trig_HM_3EC5A3_Btn_01: Short_1
2016-09-25 02:10:55 CUL_HM Vact_Taster virtActState: ON
2016-09-25 02:10:55 CUL_HM Vact_Taster virtActTrigNo: 1
2016-09-25 02:10:55 CUL_HM Vact_Taster virtActTrigRpt: 1
2016-09-25 02:10:55 CUL_HM Vact_Taster virtActTrigType: short_Release
2016-09-25 02:10:55 CUL_HM Vact_Taster virtActTrigger: HM_3EC5A3_Btn_01
2016-09-25 02:11:01 CUL_HM HM_3EC5A3 CMDs_pending
Meine Taste:
   CFGFN
   DEF        3EC5A301
   NAME       HM_3EC5A3_Btn_01
   NOTIFYDEV  global
   NR         766
   STATE      Short (to Vact_dev)
   TYPE       CUL_HM
   chanNo     01
   device     HM_3EC5A3
   peerList   Vact_Taster,
   Readings:
     2016-09-25 02:06:19   R-Vact_Taster-expectAES set_off
     2016-09-25 02:06:19   R-Vact_Taster-peerNeedsBurst set_off
     2016-09-25 02:07:01   R-sign          off
     2016-09-25 02:07:01   peerList        Vact_Taster,
     2016-09-25 02:10:55   state           Short (to Vact_dev)
     2016-09-25 02:10:55   trigger         Short_1
     2016-09-25 02:10:55   triggerTo_Vact_dev Short_1
     2016-09-25 02:10:55   trigger_cnt     1
   Helper:
     BNO        1
     BNOCNT     1
     getCfgList all
     getCfgListNo ,4
     peerIDsRaw ,33221101,00000000
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Role:
       chn        1
     Shadowreg:
       RegL_04.Vact_Taster  01:00
   model      HM-PB-6-WM55
   peerIDs    00000000,33221101,
Und der virt. Aktor:
   CFGFN
   DEF        33221101
   NAME       Vact_Taster
   NOTIFYDEV  global
   NR         733
   STATE      ON
   TYPE       CUL_HM
   chanNo     01
   device     Vact_dev
   peerList   HM_3EC5A3_Btn_01,
   Readings:
     2016-09-25 02:06:19   peerList        HM_3EC5A3_Btn_01,
     2016-09-25 02:10:55   state           ON
     2016-09-25 02:10:55   trigLast        HM_3EC5A3_Btn_01:short
     2016-09-25 02:10:55   trig_HM_3EC5A3_Btn_01 Short_1
     2016-09-25 02:10:55   virtActState    ON
     2016-09-25 02:10:55   virtActTrigNo   1
     2016-09-25 02:10:55   virtActTrigRpt  1
     2016-09-25 02:10:55   virtActTrigType short_Release
     2016-09-25 02:10:55   virtActTrigger  HM_3EC5A3_Btn_01
   Helper:
     trgLgRpt   0
     Expert:
       def        1
       det        0
       raw        0
       tpl        0
     Role:
       chn        1
       vrt        1
   model      virtual_1
   peerIDs    3EC5A301,
   webCmd     press short:press long
Was mach ich denn (mal wieder) falsch? Wäre wirklich für Hilfe dankbar!
chris1284
wozu ein virueller actor? du musst doch nur den wandtaster button mit einem virtuellen button der vccu peeren. schon gibts ne grüne lampe. per notify kannst du dann den tastendruck weiterverwerten
layer8
Danke! Habs jetzt wirklich direkt mit nem virtuellen Taster der vccu gepaired. Das Geheimnis scheint zu sein, nach dem Pairen so oft die Anlerntaste zu drücken, bis endlich CMDs_done zurück kommt. Ich habs immer nur einmal gemacht und dachte dann, ich hätte was falsch gemacht ;-)
Danke für die Hilfe!
